Question about Panasonic KX-TG5632 Phone
Panasonic Phone KX-TG2432
Whenever I push the 'talk' button, I continually receive this message: "no link to base, need to move closer to base" Battery looks to be 100% charged.
Can you help?
Thank you.
Karen
  • 5 more comments
  • chezeric Feb 18, 2008
    YES!
  • Jay98 Feb 25, 2008
    I tried the suggestion offered, but still no luck.
    Our phones are the Panasonic KX-TG2432.
  • Anonymous May 24, 2008
    Well i went to a sale and she said that the base got hit buy lighing and. she sold me one out of four phones. but there is three left. So what i did is I plug the phone in to see if it works but it comes up with no link to the base, try again.
  • Anonymous Jun 03, 2008
    Get the no link to base problem on handset #2. Try the Menu 0,0 solution suggested, but it doesn't work right away. Stick the phone into the charger and eventually it registers, but the area around the battery gets very hot and within a day the problem recurs. Panasonic tells me to go to a service centre.
  • Anonymous Mar 12, 2014
    I placed the cordless phone into the cradle and plugged the cradle into a working electrical outlet overnight. The cordless phone did not charge. How can I get the cordless to charge?
  • Anonymous Mar 28, 2014
    The keypad on one of my kx-tg5453m handsets will charge. The screen will light and beep when lifted from base but no button pushed has any effect as if the keypad is locked out but instructions do not describe any such feature as far as I can tell. The battery is new.
  • Anonymous Mar 29, 2014
    message says no power to base but phone is charging. Phone will not work
We had the same problem tonight. We unplugged the phones, plugged them back in, pressed the MENU button and followed other suggestions. However, as the charge light was not on for the base, I eventually figured it was a power source problem. Upon checking the outlet, I discovered that the breaker must have tripped. Once that was reset (in this house, it was a matter of resetting the GFI button on another outlet in the area) the phone worked fine.
Posted on Mar 11, 2010
Tengo un juego de telefonos modelo kx-tg2822la y la unidad uno no es reconocida por la base si es posible me orienten para ver si puedo solucionar este daño
Posted on Apr 12, 2008
The problem was resolved, but i don't remember how it was done.
Thanks.
Posted on Apr 10, 2008
Olá tudo bem estou com dificuldade para instalar o meu telefone sem fio de marca PANASONIC modelo KX-TG 7120 porque o manoal está todo em ALEMãO pois eu sou BRASILEIRO e estou no brasil e adoro produto alemão porisso se podere me ajudar eu agradeço muito mande resposta pra o endereço eletronico agradeço atodos BRIGADA.
  1. santos-niuzete@ig.com.br
  2. lncniuzete@uol.com.br
***:Niuzete Trindade
Salvador 10 de Abril de 2008
I had the same problem, it was solved when I replaced the batteries.
Good Luck
Alex P.
Posted on Jan 28, 2008
  • 4 Answers
I have the same probloem with a KX-TG 5672. I am going to call 1 800 2111 7262 on Monday and ask for technical support. If you get a solution, pls notify me.
Posted on Jan 26, 2008
  • maxww Jan 28, 2008
    First step is to put your phone on the base unit.
    press menu; press zero(0) two times. Enter the number of your extension that you want on the phone. By doing this on the working phones, you can check the extension number for each phone,i.e. have your base phone as #1, 2nd phone ext. 2, and third phone as ext. # 3. After you get the number set, the "charge" light will start flashing. OK should come on in bottom right corner and press "OK". Page 46 of my handbook for a TG5672/kx
When I press the talk button it says: No link to base. Move closer to base. Try again
Hand each phone up on the base and it will marry it. If you continue to have no link to base make sure everything is plugged in correctly. If it persists you probably have a defective phone.
Jan 25, 2011 | Panasonic KX-TG5632 Phone
Panasonic Kx-TG2432 Displays E9
Same here on KX-TG2248:
"Answer on" is flashing rapidly.
"Message/Slow Talk" is flashing rapidly.
"In Use/Charge" is flashing irregularly.
LED displays "E3" (and "set clock" symbol is flashing).
Removing and restoring power, many times,
produced one "spontaneous remission"
(it worked fine for several hours)
but next time moved (having to disconnect power),
it's now quite "committed" to remaining "insane" as above.
Jul 28, 2009 | Panasonic KX TG5100M Cordless Phone
My phone won't turn on
unplug it from the wall and wait for about 15minutes
Mar 13, 2009 | Panasonic KX-TG1033S Cordless Phone
No link to base.
unplug the base and when you plug it back in
the handset should work
Dec 13, 2008 | Panasonic KX-TG2356 Cordless Phone
Model#kx-tg6071b when talk button is pushed, screen shows" no link to base move closer, try again". That is what appears on both handsets.
Press MENU, scroll down to INITIAL SETTINGS (press select), scroll down to REGISTRATION (press select), then select HS REGISTRATION, and follow the instructions on the handset screen. This is for the KX-TG6071B, but is similar for most Panasonic Cordless phones. That will link the handset to the base, and YOU MUST DO IT WITH EACH HANDSET.
Jun 22, 2008 | Panasonic KX-TG2313 Cordless Phone
Telephone problem
I think you not try one place just try this put in to baladiya(baladiya means waste box)
May 01, 2008 | Panasonic GigaRange KX-TG2432 Cordless...
No link to base move closer to base
Your getting this message because the radio portion of the handset or/and base is not communicating with each other. This can be temporary or fatal. You can try re-registering the handset(s) to the base by following the directions in the manual, its fairly easy to do for any model. If that does not work,and you have more than one handset not working with this problem, then it sounds as if your base needs repair or replacing.
Feb 04, 2008 | Panasonic KX-TG5632M Twin Cordless Phone
Panasonic cordless KX-tg5432
Message on phone is "get closer to base
Jan 03, 2008 | Panasonic GigaRange KX-TG2432 Cordless...
Link to Base
unplug both wires at back of base and replug after about 5 minutes - it should work now
Dec 30, 2007 | Panasonic KX-TG2357 Cordless Phone
Panasonic KX-TG5632 Phone Logo
995 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
