Question about Konica Minolta magicolor 2430 DL Laser Printer
The printer has started coming up with the screen blank. After a number of off and on cycles it comes up with a visible display, but I think it is complaining about an empty red cartridge, which isn't. To complicate matters it has gotten switched to a non-English language and I can't reset it. Maybe because of the cartridge problem. There doesn't appear to be a master reset, just a multi-step menu process which I can't do since it isn't starting from a regular reset.
  • 4,472 Answers
First off how long have you owned the printer? How much use has the printer been through and when did these problems start. With the amount of problems you are having the unit you may want to consider replacing/upgrading the unit. Once I have more information I will be able to assist you further.
Thank you,
Lee
Posted on Nov 12, 2009
The display screen on M475 dw is blank but peripheral lights on. Computer doesn't find printer. What to do?
well, this issues it seems formatter issues..and sometimes its causes on relay between primary / secondary having crudded contack or unable to switch to secondary section under on mainboard.
note : scanner function,formatter or usb interface and high voltage ground were connected on secondary circuit.
Jul 08, 2014 | HP LaserJet Pro 400 M401DN Laser Printer
My HP DV5 1159se was working fine last night and then this morning I go to turn it on as usual and a blank white screen comes up. The start tones are the same and I could even type my password in to log on...
If the inverter board or the back light behind the screen were bad your display would be blank, "but windows would be visible barely" the white screen indicates a bad LCD and must be changed. It is also possible the video cable from the motherboard to the screen has come loose and will need to be reseated back into place to fix it.
Mar 23, 2011 | HP Pavilion dv5-1159se Laptop
HTC P3400i display is not working,blank white screen is visible. incoming call is OK. What can be done on this? What is the cost of new Display to upgrade?
Oct 18, 2010 | Cell Phones
Just plugged it in from being stored and it is blinking H 4
On the control consol. Press #,*,c,* the display should pop up with a screen to enter a code. Press 14, then enter 1. If the screen comes up blank, then enter 14 as if making 14 copies. Press start, and the machine should reboot and come to ready.
On your machine I believe the screen will go blank and you just enter 14 then start.
if not and a screen comes up with 00-00 displayed, enter 14 then start, then 1 then start.
Feb 16, 2010 | Sharp AR-M205 Copier
I have an MP530 printer - error message 5C10 is
You could try resetting the printer:
1) On the panel, press and hold the <On/Off> button until the display goes blank (approx. 1 second). If the display does not go blank, unplug the power cord.
2) Wait approx. 10 seconds, plug in the power cord (if removed in previous step), press the <On/Off> button to power on the unit.
3) Wait for the printer to cycle through its startup routine before trying another print job.
I hope this helps!
Jan 05, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Compaq f756NR laptop won't boot.
I think this is a problem with the laptop's LCD display. To verify this connect the laptop to an external display and see if it resolves the issue. If it does then its confirmed that its a display related issue. Since the issue has appeared suddenly I dont think its a serious problem. May be just loose/disconnected connectors. Should be a 10 minute job for a qualified technician.
If the external display too doesn't come on then its an issue with the graphics card and you may need to replace it.
Oct 24, 2009 | HP Compaq Presario F756NR Notebook
ViewSonic VA720 Screen displays briefly then goes blank.
it looks like the Inverter's gone in your screen, it works like a starter in a florescent tube, it 'kick starts' your screen to come on. Turning it on/off many times eventually 'kick starts' your screen and makes it come on eventually.
Jan 15, 2018 | ViewSonic VA720 17" LCD Flat Panel Monitor
HP 2600N Power up problem
try to plug in ur printer in some other grounded wall outlet directly.this may solve ur problem.
Jun 03, 2008 | HP Color LaserJet 2600n Printer
Konica Minolta magicolor 2430 DL Laser Printer Logo
18 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
