Question about Dell Vostro 1510 Motherboard System Board - J475C
My cd is strucked and how can i get it back - Dell Vostro 1510 Motherboard System Board - J475C
  • 691 Answers
Do you mean stuck in something, what is it stuck in?
Posted on Nov 12, 2009
Cd cganger struck
its busted,
you have only 2 choices. (or 3 )
1: take it in.
2: take it out and then take it to any ET service tech center.
3: take it out, and open it and unjam it. (look for debris, and broken parts inside, clean it.
me? id do 4 th, id ignore it and use, my USB stick, (no moving parts)
Dec 25, 2013 | 2007 Toyota Camry Hybrid Sedan
Got cd struck in factor 6 dis changer 00 mitsubishi diamante
If the disk is stuck in the changer then the changer has a defective part and will need to be removed and sent out for repair, Send a note with it that you want your CD back with the repaired changer.
Sep 12, 2012 | Cars & Trucks
I have a 2004 Mazda 3 w/ a single disc CD player...which has not been working for several months. There is a cd in the player but nothing happens when I press the eject button nor the CD button; won't...
Possible that the cd disc has jammed due to a change in the disc- warming can bend some cd's, also if the cd is struck inside as the loading mechanism is struck. In both cases the set must be pulled out if there is no hope with trying to retrieve the cd softly assisting while ejecting. If you do not hear any noise while the eject is pressed then the loading drive is faulty , you need to remove the cd , open to check, If this is mechanical then you can softly push the cd out, if not the electonic section needs a check.
May 03, 2011 | 2004 Mazda 3
Toyota Stereo CD Player giving error 1
Possible that the mechanism is struck as there can be a CD which has struck within the mechanism. You will need to remove the set from the dash and check the mechanism , remove the top cover and manually remove the cd. check the power to the mechanism, servo section.
Nov 05, 2010 | Car Audio & Video
I put a cd in the player and its stuck inside. how do i get it out without smashing the player?
Possible that there was a fault in the CD , maybe warped that has caused the CD to get struck inside. It can also be due to the failure off the loading mechanism of the player.
Hence you will require the hexahead tools to remove the mechanism so as to retieve the cd from the struck up mechanism.Remove the lid , then observe the mechanism , remove the mounts and release, thereafter check if the motor works , if not the loading motor drive IC , motor or the processor can be defective. ,
Oct 30, 2010 | Philips HTS-6500/37 System
The deck does not want to eject the CD - Emergency eject also not working what do i do
Possible that the Cd is struck within the head unit. It can be due to mechanism being faulty or the loading motor drive or driver being faulty.
Need to open to check if this can be due to a warped CD that is struck into the mechanism and is not allowing space to be ejected out. Release using soft pressure so as not to damage the delicate mechanism.
However if there is no mechanical problem seen then the fault can be in the servo section/control board.
Sep 14, 2010 | JVC KD-AVX2 Car DVD Player
My cd has been strucked in cd rom can u help me
Guest
If the disk is stuck in the drive you arre going to have open the system to get the disk out because there is something wrong with the drive. This is the downside to a slot base ROM drive.
So if you are still under warranty I would call Dell. If you are not in warranty I would contact your local repair shop.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
May 20, 2010 | Dell Studio 15 Laptop
I have lost product key of windows vista and strucked up in the middle of the installetion please help me out
Hey Hi ,
Dear Here's What You Need
MICROSOFT WINDOWS VISTA ULTIMATE :
1)-----> VMCB9-FDRV6-6CDQM-RV23K-RP8F7
2)-----> GLAD2-SEEUH-AVEAS-ENSEO-FHUMR
3)-----> VMCB9-FDRV6-6CDQM-RV23K-RP8F7
Please Take Some Time Out And Rate This Solution...
If U Need Further Help Please Reply Back To The Post...
May 27, 2009 | Microsoft Windows Vista Ultimate Edition
Cd is struck in the dvd player. how to take it out
Find someone not afraid of screwdrivers. UNPLUG the unit from everything and remove the cabinet screws ( most likely a few on the sides and 2 or 3 in back. Put the screws in a ziplock or something so's your dont loose them. Remove said CD and put screws back.
Dec 30, 2008 | Aragon 2002 2-Channel Amplifier
Cd is struck in my kenwood?
if you have a screw in the side of the deck, unscrew it a little and the cd should come out, i did the same thing
Feb 17, 2008 | Kenwood KDC-2025 CD Player
Dell Vostro 1510 Motherboard System Board - J475C Logo
52 people viewed this question
Alun Cox
