Question about Electrical Supplies
Lets see if i can remember what i am dealing with ,electricall 3 way switchs, have 2 -3ways right inside the patio door they are switches that have a matching pair at the end of walk way mounted on the side of a redbrick pedistal or column what ever you wnt to call it ,now these switches have in between them 4-{four lights}] on pedistals and the colors of wires are prety awesome light blue runners yellow runners red runners and dark blu runners, along with these runners there are couple black ,white& grounds@the box by the patio, if you can tell me why so many runners i sure would apprciate it and if you are following what i just wrote im sure you answer has a long descrption also , so point me to a diagram and im there thank you Richard
  • 484 Answers
The travelers are just different colors to distinguish them from line and load (black). i would guess that whoever wired the house just used what they had on-hand at the time. There are two travelers per switch, so that makes for four wires, the four colored ones that you counted. The black/white/ground is the power (line) and the load.
Posted on Nov 16, 2009
Testimonial: "thank you very mich "
  • matthew kuhl Nov 16, 2009
    i forgot; there are two wires between each switch to allow for the two throws of the switch. When the first switch sends power out one of the wires, the second switch must be on the same pole to let the power through to the light. If they are not, the lights remain off.
Child lock on, tried open Door Handle from inside, is the handle broken no longer open Door from inside even when child latch off 2003 Cadallac Deville
Hi. Try : unlock the car ( push open 3 times) open doors from outside ( make sure they unlocked) switch child lock to lock position and back to open. Pull again on the handle after you switch before you close the door. Let me know if it helped.
Apr 27, 2017 | Cars & Trucks
Replaced rollers on dryer put back together door closed but keep getting message that it is not closed and wont run?
In order to replace the rollers you had to take off the dryer front. You probably had to unplug the wires to the door switch which if I remember right is in the top left corner of the front panel. Check those connections to the push button switch. If it is not connected, the door will show as open even though it is closed. Or the switch got damaged and is not making contact inside when door is closed. If i remember it is a 3 wire 1 piece plug.It also operates the drum light.
Mar 06, 2015 | GE Profile Harmony DPGT750EC Electric...
BernzOmatich3200n
Repairing Benzomatic Patio Heater
The above link unfortunately states Benzomatic no longer provides parts for their patio heaters. There may be a comparable generic part out here that you can substitue for the original part.
Tall Propane Patio Heater Starting Striker Switch
The second link shows an igniter switch that may work. You can find other possiilities by doing a search on the web for" Propane Heater igniter switch"
May 16, 2014 | Stainless Patio Heaters - Steel Deluxe...
2007 yaris door wont lock when driver door is open
sounds like the ignition lock is worn out.
Mar 01, 2017 | 2007 Toyota Yaris 1.4
How do i wire a chamberlain opener to work with push button 3 way switch, on/off/on and bypass logic board. mine burned out and i want to use motor to raise /lower patio roll up bamboo shade
Run wires from your switch and connect to terminals #1 and #2 on the motor unit. This will run the motor and it will automatically run in the opposite direction when you once again toggle your switch. You will need to adjust the up and down limits to stop the motor in the right spot for each direction. Before connecting the shade you should remove the cover from the motor unit and watch the operation of the limit switches.
Dec 17, 2011 | Sears Craftsman LiftMaster Chamberlain...
Do you place the propane tank in the heater base
The gas tank should sit inside the housing on top of the base. There is usually a cut out section to allow access to switch on/off the tank. Always best to switch the tank off when not in use. If you need some more info found this site very useful patio heater gas.
Nov 28, 2011 | Endless Summer 1501 Patio Heater
I have a Classic Coffee Concepts GB360 maker that needs switches
I have the same coffee maker which has a heater problem but the wiring is intact. The switches are wired like this:
Right Rear Warmer Switch: Top - White from other two switches
Middle: Black from other switches
Bottom: Red
Right Front Warmer Switch: Top: White shared with other two switches.
Middle: Black with connector to Black on other switches
Bottom: Blue
Lower Front Warmer Switch: Top: White from other switches and connector to white from inside.
Middle: Black and Purple together
Bottom: Black from inside and Purple from inside on a connector.
Jul 07, 2010 | Classic Coffee Concepts SSU50 Stainless...
No heat in car blower works,thermostat was changed coolant level good car runs hot
problem could be in the mode switch + check fuse to heater and ac mode switch.if blown your air door wont open and let heat enter inside car.if fuse look good you could have faulty mode switch.if you have climate control if you have a bad in vechicle sensor that will effect air door to open let heat in.this problem would be best for dealership.if dealing with climate control units.you need a quick fix.too cold outside not to have heat in car.
Dec 14, 2009 | 2003 Nissan Altima
Inside top of refrigerator hot light don't turn off.
There is a service bulletin related to this, dealing with deformation / melting of the lamp cover. The fix is to change the lamp wire harness to one that now has a thermal protector incorporated in it (part number 6621JK2003B) along with changing the main PCB board to one that uses a larger relay for this function (part number 6871JB1423N).
In case you want or need to replace the following,
The lamp cover is part number 3110JA1096A and the lamp holder is part number 3034JA1009A
I tried to cut and paste a few photo's, but was unsuccessful. Sorry. Make sure to test that fans and light switches work after part changes.
Apr 11, 2009 | LG LFC21760 Bottom Freezer French Door...
Ice maker does not make ice and the in-door water is not working properly - it keeps running.
the water in the door problem after you fill up your cup with water it keeps running all over the floor.. it sounds like its a stuck contact on a micro switch inside the door compartment. that lever you are pushing your glass onto is atached to a little switch and if the contacts stay closed (like when a glass is pushing on it) the machine thinks "hey he still wants water". next time it does that try pushing on the spot you put the glass onto a couple of time to see if it stops the water. if so it most likely is the switch. to confirm that is the case you will have to open the plastic moulding from the fridge door to gain access to the switch.( always unplug any electricall device before openning to ensure your hair doesnt end up standing striaght up like a punk rocker) you will know which switch is the one you want to check by depressing the water lever on the front. Ohm check the switch for continuity to see if it gives you proper readings or it is in fact a bunk switch. it also could be a mechanical problem as the lever once unpressed is not opening the switch back up once the glass is removed but that is not as likely unless you are ramming the glass into the water dispensor
hope it helps
VeeDubb
Apr 23, 2008 | Refrigerators
Electrical Supplies Logo
99 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
