Question about Cell Phones
Voicemail modifications how do I change my samsung voicemail greeting to a tone I downloaded instead of having to put my name or phone number for it?
How to change voicemail on a galaxy 5
  • From the Home screen, tap , then tap Call icon.
  • Follow the tutorial to create a password, record a greeting, and record your name.
Note: These steps may be different depending on your network.
Accessing Your Voice Mail
  • From the Home screen, tap Call icon, then tap Voice Mail icon. You may be prompted to enter a password.
  • When connected, follow the voice prompts from the voice mail center.
Accessing Your Voice Mail From Another Phone
  • Dial your wireless phone number.
  • When you hear your voicemail greeting, press the asterisk key on the phone you are using.
  • Enter your password and you are connected to your Voice Mail.
May 18, 2015 | Samsung Cell Phones
Our school has a Siemens 500 OptiPoint 500 advance phone that has a greeting one. Can't find out in any of the manuals as to how I can go about changing it. Can anyone out there help me?
We always programme the voicemail to 555. If you have something different change what is below, which is our 'one sheet' user guide from www.dschiltern.co.uk
All Types of Phones
1. Your mailbox number will be the same as your extension number.
2. Default password is 1 2 3 4
3. Voicemail group number is 555 (unless programmed differently)
Before callers can leave voicemail messages you must activate your mailbox and record your greeting message. We would suggest something along the lines of
"You are through to the voicemail of . . . . I am sorry I am unable to take your call at the moment but please leave a message after the tone and I shall get back to you "
To Record Your Greeting Message
1. Dial the voicemail group number (usually 555)
2. Enter your password (default is 1234)
3. Keep pressing 3 to scroll to greeting messages
4. Press 8 to toggle between your two greeting messages
5. Press 0 to change the message and follow the instructions.
To leave voicemail just press 'Release' or hang up.
Responding to Voicemail
On a display phone you will see "You have messages" on the top line and "Display messages?" on the bottom line. Press tick twice to go to voicemail and then enter your password.
On Siemens 'Entry' phone or display phones with a 'voicemail' button, just press this button and enter password when asked.
On ordinary analogue phones you will get broken dial tone. Dial the voicemail group number (usually 555) and enter password.
In all cases you will then be able to listen to your messages.
To delete a message press 0. It will ask you to confirm by pressing 0 again.
Sep 17, 2014 | Siemens optiPoint 500 Advance - Corded...
How to change voicemail greeting on Mitel 5330
If you want to change your voicemail greeting, go into your voicemail and press 4 on the keypad. This is usually the number for personal options such as Voicemail greeting, name in the directory, and changing your voicemail password. If you need more specific instructions just let me know and I'll be happy to help.
Apr 16, 2014 | Mitel 5330 IP Phone
Voicemail change message
How To Change Your Personal Greeting:
1. Press the Check Voicemail key or press the Feature button, then 981
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
How To Record Your Alternate Greeting (Used when on vacation or out of the office.:1. Press the Check Voicemail key or press the Feature button, then 981
5. Pres the REC softkey
6. Press the ALT softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording, then the OK softkey again to accept the new recording.
9. You then need to have your voicemail box now play the Alternate Greeting, Press the GREET softkey
10. Press the Choose softkey
11. Press ALT softkey
12. Display will show: "Accept msgs: Y", Press the OK softkey to have your voicemail box accept messages while your Alternate Greeting is turned on, or press the CHNG softkey to change the "Y" to an "N" if you do not want your voicemail box to accept messages.
13. When you return to the office, make sure you go back into your voicemail box and have it play the PRIME greeting.
Nov 21, 2013 | Nortel T7316E 2-Line Corded Phone
How to put on my voicemail the machine with my number instead of my first and last name
When you call your voicemail, there will be an option for settings. In the settings menu, you will be able to choose between greetings and it will let you listen to the type of greeting before you select it.
Jul 15, 2011 | Cell Phones
Trying to listen to voicemail grettings.
If your talking about listening to the individual mailbox greetings without calling into the system then you could use feature 980 (leave message)
enter in the mailbox number you want to check and press ok.
Jul 09, 2010 | NorStar M7310 Corded Phone
Change voice mail message from one person to another person
Step 1 Lift the handset for your telephone and listen for the dial tone. Dial the access code you were given by Verizon when you signed up for residential telephone service. Dialing the access code will call the voicemail system. If you do not have an access code, you will need to call Verizon Customer Servicemag-glass_10x10.gif (see link in Resources).
  • Step 2 Identify the telephone number you are setting up voicemail services for. If you are calling from that telephone number, enter the temporary passcode and then press "#." The temporary passcode is the last 4 digits of your residential telephone number. If you are calling from a different phone, press "*" when the system greeting starts to play, then enter the 10-digit telephone number when prompted. After this, you will be asked to input the temporary passcode.
  • Step 3 Choose a new passcode. The passcode must be from 4 to 8 digits in length. It should be easy for you to remember, but difficult for others to guess. Do not use easy to guess numbers, such as 1234 or 1111. Also do not re-enter the same temporary passcode, since it will be easy for anyone to guess.
  • Step 4 Record your name. Simply say your name, without a long complicated message. This recording is used by the voicemail system to identify you whenever you forward a message to another user. It is not used as the standard greeting when a caller is directed to your voicemail to leave a message.
  • Step 5 Record or change your personal greeting. This greeting is played any time someone reaches your voicemail box. Record a friendly greeting to announce that you are unavailable and will return all calls upon your return.
    Decide if you want to set up a different mailbox for each family member. Verizon residential telephone service allows you to set up multiple mailboxes so that everyone can have his own private message center. Callers who reach voicemail will be prompted to press "1" to leave a message for one person, press "2" for the next person, and so on.
  • Step 6 Hang up the telephone. When you have finished setting up the voicemail system on your Verizon residential phone line, hang up the phone to end the call and exit the voicemail system.
  • Nov 08, 2009 | Uniden Cordless Phone
    I have a problem with voice mail with a meridian hooked to NT5806DA-93. The system on voice mail every second pulse off so that only half of each message is played at a half second interval
    Voicemail Features Norstar Common To Check Your Voicemail:
    3. From here you can listen to messages, change your greeting, change your password, etc.
    To Leave a Message for Someone in Your Office:
    1. Press the Leave Message key or Feature 980
    2. Enter the mailbox number (extension number. of the person you want to leave a message for
    3. The display will show the name of the mailbox owner, press OK
    4. Leave message
    To Access Your Voicemail box from Another Phone:
    2. Press the OTHER softkey
    3. At the LOG: prompt, enter your mailbox#(extension #. and your password all together followed by the "#" sign
    4. Press the OK softkey
    To Access Your Mailbox from Outside of the Office:
    1. Call the main office number or your DID (if applicable.
    2. If the call is answered by a receptionist, have them transfer you to your voicemail box
    3. If the call is answered by the company greeting, or your personal greeting, Enter: * *
    4. At the prompt, enter your mailbox #(extension #. and password all together
    To Transfer Someone to a Voicemail Box:
    1. Press the Transfer to Voicemail key or press the Feature button, then 986
    2. Enter the mailbox # (extension#.
    3. The display will show: Call Transferred
    10. Press the ChOOSE softkey
    Norstar Voicemail Administrative Programming Programming must be done from any M7310, T7316, or M7324 model phone set.
    To Log Into System Administration:
    1. Enter Feature 983
    2. The display will show "LOG", enter your login password
    a. If your company extensions are 2 digits long enter "120000"
    b. If your company extensions are 3 digits long enter "1020000"
    c. If your company extensions are 4 digits long enter "10020000"
    3. Press the softkey under "OK"
    To Create a New Mailbox:
    1. Log into system administration
    2. Select the softkey under "MBOX"
    3. Select the softkey under "ADD"
    4. Enter the mailbox number (extension. you want to add
    5. Mailbox type: Subscriber and then select "OK"
    6. Extension: Usually the same as the mailbox number
    7. Service Class: Enter 1
    8. Name: Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma, and then enter the first name. When spelling the name, press # to move to the next character
    9. Directory: Y (Yes.
    10. Message Waiting: Y (Yes.
    11. Out dial: Pool, enter 1 and then OK
    12. Accept: 1, select OK
    To Delete a Mailbox:
    1. Log into the system administration
    3. Select the softkey under "DEL"
    4. Enter the mailbox number (extension. you want to delete
    5. Select the softkey under "Delete"
    To Reset a Mailbox Password:
    3. Select the softkey under "Chng"
    4. Enter the mailbox number you want to reset the password for
    5. The display shows "Reset Password"
    6. Select the softkey under "RESET"
    7. Press the release key
    *The new password will be "0000", the system will ask the user to change this the first time they log into their mailbox using this password.
    To Change the Name on a Mailbox:
    4. Enter the mailbox number (extension. you want to change the name on
    6. Select the softkey under "Next", keep hitting "Next" until the display shows the name
    7. Select the softkey under "Chng" to enter a new name
    8. Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma and then enter the first name. When spelling the name, press "#" to move to the next character
    9. Select the softkey under "Next" to save the change
    10. Hit the release button
    Apr 15, 2009 | NorStar Lands Phones
    Voicemail reset
    Norstar Common Voicemail Features To Check Your Voicemail:
    4. Leave message
    took this from a guide i found, helped me out
    Apr 30, 2008 | NorStar M7310 Corded Phone
    Resetting company voicemail
    4. Leave message
    took this from a guide i have, might help you guys out
    Jan 07, 2008 | NorStar M7310 Corded Phone
    Cell Phones Logo
    91 people viewed this question
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
