Question about Citizen CBM1000-II Receipt Printer PC Desktop
Paper cutter stops on its way back across track
  • 691 Answers
Is the cutter start position correct?
there is an adjuster
Posted on Nov 12, 2009
Embassy shredder keeps running after it's done shredding. It won't stop running.
Hi Brenda:
My shredder, different make, occasionally has the same problem, especially when I try to put too many sheets of paper through at one time.
It happens because the paper jams in the cutter wheels and holds
a switch lever in the on position.
Step 1) Use the reverse switch (mine has one) to back the paper up a bit, then switch it to forward. Repeat this a few times and it might clear itself.
Step 2) If step 1 did not work, unplug the machine and use needle nose pliers, a small swrew driver, or any other handy tool, and remove all of the paper bits from the cutter assemble. Once this is done, it should work fine.
Jun 28, 2015 | Shredder Office Equipment & Supplies
1600mx wont run in forward over load light comes on
Most common reason is that there is paper would around the cutters, imposing an additional load on the machine. You will need to access the cutter assembly (disconnect all power) and manually remove all of the paper that has impinged between the cutters.
If you have run any labels or paper with gummed strips through the cutters, you may wish to consider throwing this one away and buying new. (In all fairness, it "can" be cleaned, but it is going to be a real dickens of a job to do).
If you decide to keep your shredder and clean the cutter assembly, remember to oil it on a regular basis per the instruction manual.
As for me, I use Fellows shredder oil
Fellowes Shredder Oil 12 oz Bottle with Extension Nozzle 35250
and oil my machine every time I dump the cuttings. I run a bead of oil in a serpentine pattern over a sheet of paper and then just shred it. (If you have never oiled the cutters, it may be too late to do so now. Something you need to do on an on-going basis).
Jan 23, 2015 | Royal 150MX Cross-Cut Shredder
Can I replace the blade on my paper guillotine?
On a paper cutter with blades that slide on a track you are able to replace the blades but not on a guillotine, it appears the only solution is to buy a new one.
Sep 29, 2013 | Office Equipment & Supplies
Paper cutter
You should try replacing the cutter assembly with a new one. They are rather inexpensive ($50) to purchase and easy to install.
The only other thing I can think would cause your problem is if something is stuck in the groove by the cutter guide that would cause it to disengage while cutting.
Jun 07, 2013 | HP DesignJet 500 InkJet Printer
There is 2 inch black smudges (tire tracks) across every page I print.
This would indicate that either the developer ,Drum or Fuser requires attention .If you stop the paper before the fuser unit is the mark there? if not then it would point to the fuser unit.
Jan 24, 2013 | Kyocera Mita FS 3800 Laser Printer
Motor and cutter do not rotate - strip cut model
Soak the clog with dishwashing detergent and a little bit of water overnight. This should dissolve the paper.
Jan 07, 2010 | Fellowes Manufacturing C220 (Strip-Cut)...
The error light on the Epson TM-T88IV keeps flashing whats wrong with it?
The following is from the Epson Users Manual:
Troubleshooting
No lights on the control panel
Check the power supply cable connections and the power outlet.
ERROR LED on (not flashing) with no printing
If PAPER OUT is on, the roll paper is not installed or is near the end.
If PAPER OUT is off, the printer cover is not closed properly.
ERROR LED flashing with no printing (and no paper jam)
Printing stops if the head overheats and resumes automatically when it cools.
If overheating is not the cause, turn the printer off, and after 10 seconds, back on.
Removing Jammed Paper
CAUTION:
Do not touch the thermal head because it can be very hot after printing.
1. Turn the printer off and press the cover open button.
2. Remove jammed paper, reinstall the roll, and close the cover.
3. If paper is caught in the cutter and you cannot open the printer cover, open
the cutter cover as shown in illustration J.
4. Turn the knob until you see a triangle in the opening. This returns the cutter
blade to the normal position. There is a label near the cutter to assist you. See
illustration K.
5. Close the cutter cover.
6. Open the printer cover and remove the jammed paper.
Cleaning the Thermal Head
CAUTION:
After printing, the thermal head can be very hot. Be careful not to touch it and
to let it cool before you clean it. Do not damage the thermal head by touching
it with your fingers or any hard object.
Turn off the printer, open the printer cover, and clean the thermal elements of the
thermal head with a cotton swab moistened with an alcohol solvent (ethanol, or
IPA).
Epson recommends cleaning the thermal head periodically (generally every
3 months) to maintain receipt print quality.
It sounds like your print head is overheating. Clean as instructed above.
Oct 23, 2009 | Epson TM T88 Thermal Printer
My star tsp600 has stopped working properly. The auto cutter no longer works and the receipt paper does not advance fully.
You will need to take the printer in for a service. The cutter is Jammed and that causes the fault on the paper feed.
Aug 05, 2009 | Star Micronics TSP600 Thermal Printer
Cut err
Paper Cutter Error - Guiliteen isnt sliding across the  rail it runs on properly  try lubing rail that cutter runs on with a LITTLE light oil , near front paper exit area
Oct 19, 2007 | Citizen CLP-7201E Thermal Label Printer
TS-4500 not working
It is a light duty model. Probably jammed the cutter assembly. Will it reverse? Try oiling the cutter. Drop a few drops of vegetable oil at various spots through the cutter.
Jun 30, 2007 | Tech Solution TS-4500 Shredder
Citizen CBM1000-II Receipt Printer PC Desktop Logo
Top Citizen Computers & Internet Experts
john h
mtranch
Level 1 Expert
Are you a Citizen Computer and Internet Expert? Answer questions, earn points and help others
