Good morning. I have a notebook zd 7000.The problem is that XP home sp.1 start but block on the microsoft xp screen loading. I've format the hard disk and reinstalled XP but the problem is the some.
    Guru:
  • 480 Answers
1.Partition the hdd and try
2.use another cd of windws
Posted on Nov 12, 2009
Hi, I am adil. I am trying to install Windows XP on my Dell mini Inspiron 1020 but failed. Please provide me details steps.
Method 1: Perform a clean install of Windows XPA clean installation consists of removing all data from your hard disk by repartitioning and reformatting your hard disk and reinstalling the operating system and programs to an empty (clean) hard disk. For more information about important things to consider before you partition and format you hard disk and how to partition and format your hard disk by using the Windows XP Setup program, click the following article number to view the article in the Microsoft Knowledge Base: 313348 How to partition and format a hard disk by using Windows XP Setup programTo perform a clean installation of Windows XP, follow these steps:
  1. Back up all important information before you perform a clean installation of Windows XP. Save the backup to an external location, such as a CD or external hard disk.
  2. Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
    Note To boot from your Windows XP CD, the BIOS settings on your computer must be configured to do this.
  3. When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.
  4. At the Welcome to Setup screen, press ENTER to start Windows XP Setup.
  5. Read the Microsoft Software License Terms, and then press F8.
  6. Follow the instructions on the screen to select and format a partition where you want to install Windows XP.
  7. Follow the instructions on the screen to complete the Windows XP Setup.
If you have successfully installed Windows XP, you are finished.
May 23, 2011 | Dell Inspiron Mini 1012 Netbook...
How to install winxp to laptop dell inspiron 910. dell inspiron 910 no hdd but 8gb flash drive
313348 (http://support.microsoft.com/kb/313348/ ) How to partition and format a hard disk by using Windows XP Setup program To perform a clean installation of Windows XP, follow these steps:
Post back if it is not working we will be happy to help you.
Thank you.
Cheers!!!
Jan 09, 2011 | Dell Inspiron Mini 10 Notebook
Unistalling Microsoft VISTA HOME Edition
Are booting the laptop from the XP CD? If so it should just give you an option to delete partitions then format and install starts. If you try installing XP after Vista has loaded it wont let you as XP is older. Cheers from Scott
Mar 19, 2010 | Compaq Presario Notebook
I HAVE A COMPACQ PRESARIO CQ40 108TU WHICH HAS INTEL DUAL CORE 2.0GH, 1 GB RAM,AND SAMSUNG 150 HARD DISK. I CAN INSTALL WINDOW VISTA BASIC, WINDOW 7, WHICH I HAVE ALREADY TRY. BUT WHEN I TRY TO INSTALL XP...
what happen is this once you see such again change the Operating CD you are using and get another XP CD to try it again it might be the fault of the CD but if it persist then find a system that you will us it to format your harddisk and load the operating CD then later you change it back and ready for use
Feb 20, 2010 | Compaq Presario Notebook
My daughter (aged 12) has loaded a copy of Vista (which were discs from a computer her grandmother no longer owns and has been scrapped) onto her laptop which had Windows XP installed. She does not have a...
Hi.
If she did not format the hard disk, then the Windows XP startup option will be present in boot option. When computer startup you will get a choice like this:
1 Microsoft Windows Vista Home Edition.
2 Microsoft Windows XP Professional SP2
In that case you can restore XP, starting on XP and editing the file winboot.ini, that is an hidden system file located on C:/ drive.
See:How to edit the Boot.ini file in Windows XP.
If instead Windows XP does not start, or if you do not get the boot option, that means that Windows XP system file had been deleted.
In that case the only way to get back Windows XP is reinstalling the system from scrap, using a Windows XP install disk, and the number listed on the licence sticker.
Regards.
Oct 23, 2009 | Microsoft Windows XP Home Edition
How to install windows xp into compaq presario cq40
compaq cq40 is one particular model from compaq which is literally designed for vista and when you want to install win xp ;it doesn't work becoz the BIOS block it;the only way out is to downgrade the system BIOS which is a risky thing.check your bios model and version and google for a lower version and download it and flash the ealier BIOS.gooogle more on How to downgrade BIOS
Sep 21, 2009 | HP Compaq Presario CQ50Z-AMD Sempron(TM)...
Can't boot windows xp
it sounds like the easiest solution would to either run the repair sequence from a windows xp disk (may not be a perminant fix) if that doesent work just use the xp disk to format the drive and install a new operating system
May 10, 2009 | Microsoft Windows XP Home Edition
DEll Latitude c610 laptop computer
put in the windows 2000 or xp disk
98 is not supported by microsoft , youll have many problems online
but you need to format the hard drive , 20 gb is good
with the windows xp cd boot from it
you will see just one letter drive if more delete them and format just one drive, you can use the quick format , so the windows xp files will go on after that, but youll have 30 day trial
Jan 27, 2009 | Dell Latitude C610 Notebook
Error report...XP Home SP 3
The hard disk maybe is starting to crash or try also replacing the PATA or SATA cable that you are using, it maybe a faulty cable or something... have a nice day!!!
Aug 10, 2008 | Microsoft Windows Xp Home Edition English...
Microsoft office
If your version of Microsoft Office 2003 came from a legitimate CD, then re-run the CD. If it is not taking your product registration key, then call Microsoft and have them override the blockage. I had to do the same when I wiped my hard drive clean - I found their tech support in this area to be most helpful.
May 16, 2008 | Microsoft Windows XP Home Edition
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
