Question about NetGear WGR614 Wireless Router
How do i change my NAT setting to open - NetGear WGR614 Wireless Router
  • 2,263 Answers
On your router you can try to reduce the MTU settings .
If MTU is 1500 then make it 1365.
Also disable the firewall on the router.
You will also need to open the port number for the gaming Device.
You want the NAT open for the X-box or Play station ?
For this you will need to access the router set up.
After opening the ports , power cycle the router.
I hope the following link will help you.
Click Here for more info
Posted on Nov 12, 2009
NAT IS STRICT
STEPS TO CHANGE NAT SETTINGS TO "OPEN":
1- Using your Browser, Log on to your router (by normally typing in the 192.168.1.1 address check your router's manual to see what the default gateway address)
2- If you already know how to log in to your router, then skip this step. If you have never logged on to your router then more than likely you still have the default initial log in credentials (username: admin - Password:1234 ..... Again check your router's manual to be sure). The minute you log in you need to change that password immediately, most network-savvy folks know that 90% of the people out there never reset their router's initial password and they can log on and make any changes to suit their needs, including locking you out of your own router.
3- Once you are logged in, you should be able to find two advance settings (One if for NAT - and the other is for Upnp)
4- Let's start with the NAT setting changes, and we will move on the Upnp at the end. I have personally tried the NAT setting changes and it didn't fix anything, I still had a "Strict" NAT setting on my xbox360, Only when I checked for the Upnp "allow authorized incoming traffic" options when the NAT settings on my XBOX finally came back as "Open" and not "Strict". But I will still explain what I did anyways with the NAT table cause I know it may work for some other routers.
5- So what I did with the NAT setting is this. I located the NAT advanced setting on my router, I click on the NAT (Edit List setting) or whichever link/button you have on your router advanced NAT settings to access the table needed to open certain ports (TCP and UDP - 88 & 3074) .
6- You will need to find out what the static/dynamic (preferably Static) IP address you xbox360 has. To do so, go to the Dashboard, go to the Console settings page, and click on the network settings to see the IP address (should be something like 192.168.1.x). You will need that IP address to enter into your NAT table on your router.
7- Once you got your XBOX's IP address enter it in the NAT Port Forwarding table (From - To - IP address: those are the 3 fields you should have on the table if you are using SUA NAT)
8 - In the first line enter 88 under both "From" and To" fields, then enter the IP address of the xbox in the field where you are to enter an IP address. (this is for UDP port)
9 - Repeat the same step for port TCP (which is 3074)
10- If these changes do not help open your NAT settings, then try the Upnp option. Click on your Upnp Advances settings and click on the "Allow Traffic" option, this is mostly secure because you are only accepting the incoming traffic that matches your outgoing traffic.
Mar 02, 2011 | Belkin Basic Wireless Router
I want to change my nat type
You are trying to open the NAT on the router for X-box.
For this you will need to reduce the MTU settings on the router to 1365.
You will also need to trigger some ports on the router.
For this you will need to open the router set up page.
Router set up page is the page where you can change the settings of the router
Click Here to know more about router and network
Apr 19, 2010 | Linksys WRT160N Wireless Router
I need to change my nat type from strict to open
This router does not have the typical "strict or open" NAT types. Looking at the manual, it looks like what you want is NAT enabled and SUA only enabled.
http://www.zyxel.com/web/support_download_list.php?indexflag=20040906173729&ModelIndexflags=0,420041221102511,420041221102520,420050117110858,420050117110916,420050117110934,420050831093216,420050831095441,420060420160946,420060420161739,420060816160116,420080815092146,420090427144843
Page 133 has the details.
Log into router
go to the NAT tab
Enable NAT
Enable SUA only
Apply the change.
Nov 18, 2009 | Zyxel P660HW-D1 Router
Change NAT to open
maybe instead of nat, set you xbox as a DMZ host. This would be done on the router itself. It will allow the Xbox to bypass the firewall and nat on the router/gateway, and at the same time keep your computer safe.
Apr 16, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Change NAT to open
First make sure your security type on the router is WEP-Personal. You may need to get the port range for that game or manufacturer. Then enter them in to the gaming tab. This will keep ports open all the time. NAT 2 is acceptable but you want NAT 1. Some internet connections cannot get NAT1.reply if you need further assistance
Mar 13, 2009 | Dynex DX-E401 Router
Change NAT to open
You need to open all the ports for the xbox live. The NAT of that router model cannot be configured to open. Its just a simple NAT for internet connection.
Feb 09, 2009 | Linksys WRT160N Wireless Router
Change NAT to open
Go to portforward.com and then set your xbox to conenct using the DMZ option on your router.
Jan 20, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Change NAT to open
Ok kids... all you hve to do is log in to your belkin 54g at http://192.168.2.1
Find out what ip address your xbox is using and then Click on the DMZportion of your settings on the left hand side of the page.
Enter the xbox's ip address and click the enable box.
Click apply.
Your NAT will now be OPEN!
Cheers!
Mar 24, 2008 | Linksys WRT54GL Wireless-G 54Mbps...
Change nat settings on a us5461
It sounds like your having trouble with your xbox live. You just need to set up port forwarding.. Go to the link below then select the type of router that you have out of the list and you will get instructions to set nat to open.
http://www.portforward.com/english/routers/port_forwarding/routerindex.htm
This should help!
Dec 27, 2007 | U.S. Robotics MAXg USR5461 (738168036790)...
NetGear WGR614 Wireless Router Logo
190 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
