Question about Canon imageRUNNER 5000 Copier
Canon copier 3300how to break password
How to break password of it as it display on main page and restrict to enter into
    Problem Solver:
  • 9 Answers
You DO NOT need to format the hard drive or reload firmware... try this press * with head near ? mark button then simultaneous 2 and 8 .then same asterisk ,LCD display change, press COPIER>FUNCTION>CLEAR>PWD CLEAR> OK switch off/on the machine hope this can help
Posted on Nov 30, 2009
    Problem Solver:
  • 14 Answers
Fomate the hard disk & reinstall fineware
Posted on Nov 17, 2009
How do I reset the admin password for a Canon iPF605?
The least painful method. Approach the copier and view the operator control panel as we are going to go into service mode and delete the admin password. I am about to describe a "fluid 3 step keystroke " function which will put you into service mode. Before we start , locate the "ADDITIONAL FUNCTIONS" button located between the LCD screen and the 9 key pad. Now, press additional functions, then the numbers 2 and 8 simultaneously, then back to additionalfunctions in a smooth three step flow. The screen will change as you have entered service mode. Depending on the configuration of the device you will have several tabs in your display and copier will be at the top. Press copier. A new display appears with several tabs across the top. Press the function tab. New display again, and now press "clear". New display again. Look for "PWD-CLR". Once found, press it. It will be highlited,and then press the "OK" button in the lower right corner. The ok button will indicate you have touched it by beeping or highlighting or both (depends on the model). Then turn the main power off (the actual switch not the button on the op panel. If you are in doubt unplug the machine. After a few seconds re-energize the copier. If the previous administrator merely used a password then it is now deleted and you are home free. If not, then you will need to enter service mode again.......copier........function.......clear..... and then find MMI . Clearing this field will delete ALL customer inputs(IP address, favorites etc). If it is necessary press MMI and then ok. Usually you wont have to do this. But if you do you can have the fun of re-entering all your old settings as it will go back to factory settings.
Jun 29, 2012 | Canon Office Equipment & Supplies
Reset password
The default password for the router's Web Configuration Manager is password. NETGEAR recommends that you change this password to a more secure password.
To change the administrator password: 1. On the main menu, under Maintenance, select Set Password to display the Set Password screen. 2. To change the password, first enter the old password, then enter the new password twice. 3. Click Apply.
Best of luck!
Sep 06, 2011 | NetGear WNR2000 Wireless Router
When we load the cartridge of Canon LBP 3460 cartridge on scrre we seen error no 14
To change your password:
  1. You need to be logged in with the ID that you want to change.
  2. From Yahoo! Homepage, click on your username in the upper-right corner.
  3. From the pull-down menu select Account Info.
  4. You will be asked to sign in again before you can access your "Account Info" page.
  5. Click Change your password.
  6. The "Change Your Yahoo! Password" page will open.
  7. Enter your current password.
  8. Choose your new password then enter and confirm it.
  9. Click Save. You will see notification that your changes have been made.
  10. Click Continue.
Thanks and Regards
TRinoj
Aug 05, 2011 | Canon LASER SHOT LBP-3460 Printers
Another business we share an office with wants to use our photocopier. How do we set up their own password to enable this to work.
You can always find solutions to Xerox problems @ www.xerox.com/support Once you set this up both you and your neighboring business will BOTH have to use individual codes. Hope it helps!
Solutions for : How To Set up or Modify Auditron User Accounts Solution : Set up or Modify Auditron User Accounts The following information describes how to register userIDs and usernames, login names, and passwords for authenticating accesses attempted through the network for scanning services, and impose restrictions on the maximum number of pages to be copied or scanned. Up to 500 user accounts can be registered.
NOTE: You must be a System Administrator to perform this solution.
  1. Press the [Log In / Out] button on the Control Panel. The Login screen will be displayed.
  2. Enter the System Administrator userID using the numeric keypad on the Control Panel, or select the [Keyboard] button on the Touch Screen to enter the userID, and then select [Save] on the Touch Screen.
  3. If necessary, enter the System Administrator password using the numeric keypad, or select the [Keyboard] button to enter the password, and then select [Save] on the Touch Screen.
    NOTE: The default userID is 11111, and the default password is x-admin (must be entered in lower case). If the userID and / or password have been forgotten, a service call must be placed.
  4. Select [Confirm] on the Touch Screen. The System Administrator Menu screen will be displayed.
  5. Select [System Settings]. The System Settings screen will be displayed.
  6. Select [Login / Auditron Administration]. The Login Setup / Auditron Administration screen will be displayed.
  7. Select [Create / Check User Accounts]. The Create / Check User Accounts screen will be displayed.
  8. Select a user account number or use the numeric keypad to enter a user account number in the Go to (001-500) field.
  9. Select [Create / Delete]. The User Account screen will be displayed.
  10. Enter a userID using the keypad on the Touch Screen, and then select [Save]. The Create / Delete screen will be displayed.
  11. Select from the following options:
    • UserID: Allows a userID to be entered using the keyboard on the Touch Screen. Up to 32 alphanumeric characters can be entered including spaces.
    • User Name: Allows a username to be entered using the keyboard on the Touch Screen. Up to 32 alphanumeric characters can be entered including spaces.
    • Password: Allows a password to be entered using the keyboard on the Touch Screen. 4 to 12 alphanumeric characters can be entered. The Password button is also displayed if a password was selected on the Login Setup / Auditron Mode screen.
    • Remote Login Settings: The following settings can be modified on this screen:
      • Login Name - Allows a login name to be programmed that needs to be entered when the machine is accessed through the network.
      • Password - Allows a password to be programmed that needs to be entered when the machine is accessed through the network.
    • Account Limit: Select [Copy Service] or [Scan Service], and then select [Account Limit]. Using the numeric keypad on the Control Panel, specify and restrict the maximum number of pages to be copied or scanned for the account. The maximum number can be entered within the range of 1-9,999,999 pages.
    • Reset Total Impressions: Deletes all data tracked for the selected account.
    • Reset Account: Clears all settings and data for the selected account.
  12. Select [Save].
  13. Select [Close] three times.
  14. Select [Exit].
Feb 03, 2011 | Xerox CopyCentre C123 Copier Copier
Docs in memory and can't retrieve
1. At the copier, press the "Box" button
2. Press the “System User Box” on the display screen
3. Press the “Print User Button” on the display screen
4. At the “Access” field, enter your username that you created
5. At the “Password” field, enter your password that you created
6. Select the document that you want to print on the display screen
7. Press the “Print” button on the display screen
8. Press the “Start” button on the copier/printer
Thanks for contacting Fixya.
Jun 02, 2009 | Canon Office Equipment & Supplies
Canon iR3045
Did you try with password manager under user menu on the copier? There could be a way to restrict, but then every user would have password.
Mar 27, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Need to establish PIN/Code for machine - help xerox c123
  12. Select [Save].
  14. Select [Exit].
Jan 08, 2009 | Xerox CopyCentre C123 Copier
Turning off job headers
You have to turn that off , it is called a banner Page, I will sent you a few ways of disabling it.
When enabled, the Banner Page prints for each job. The Banner Page consists of the following:
  • Username
  • Job Name
  • Date
  • Time
  1. From the WorkCentre, enter the Tools mode. See the Related Items below for additional information. The Tools Mode screen will be displayed.
  2. Select [System Settings] from the Touch Screen. The System Settings screen will be displayed.
    NOTE: Depending on the model and configuration, there will either be 2 or 3 main screens available in System Settings. For example, the initial screen will be noted as System Settings screen 1 of 2 or 1 of 3.
  3. Select the [Job Sheets] button. The Job Sheets screen will be displayed.
  4. Select the [Banner Sheets] button. The Banner Sheets screen will be displayed.
  5. Select [Enabled] or [Disabled].
  6. Select [Save].
  7. Select [Exit Tools].
Oh yeah
How to enter tools mode would help huh LOL
NOTE: The Tools mode is password protected. The factory set default password is 1111. It is recommended to modify the default password. See the Related Items below for additional information. The Administrator (Tools mode) password used to enter the Tools mode directly at the WorkCentre and the CWIS Administrator password are the same password. If one is modified, it affects the other.
Oct 18, 2008 | Xerox WorkCentre 4150 Black and White...
Canon ir C3100 Admin Password
Hello skunkel,
Yes, I believe I can help you. Hopefully these previous admin person did not go nuts with the security thing. But I can help you either way. The least painful method. Approach the copier and view the operator control panel as we are going to go into service mode and delete the admin password. I am about to describe a "fluid 3 step keystroke " function which will put you into service mode. Before we start , locate the "ADDITIONAL FUNCTIONS" button located between the LCD screen and the 9 key pad. Now, press additional functions, then the numbers 2 and 8 simultaneously, then back to additional functions in a smooth three step flow. The screen will change as you have entered service mode. Depending on the configuration of the device you will have several tabs in your display and copier will be at the top. Press copier. A new display appears with several tabs across the top. Press the function tab. New display again, and now press "clear". New display again. Look for "PWD-CLR". Once found, press it. It will be highlited,and then press the "OK" button in the lower right corner. The ok button will indicate you have touched it by beeping or highlighting or both (depends on the model). Then turn the main power off (the actual switch not the button on the op panel. If you are in doubt unplug the machine. After a few seconds re-energize the copier. If the previous administrator merely used a password then it is now deleted and you are home free. If not, then you will need to enter service mode again.......copier........function.......clear..... and then find MMI . Clearing this field will delete ALL customer inputs(IP address, favorites etc). If it is necessary press MMI and then ok. Usually you wont have to do this. But if you do you can have the fun of re-entering all your old settings as it will go back to factory settings.
Jul 30, 2008 | Canon imageRunner C3100 Copier
Canon pixma mp780
From the front panel (Macintosh and Windows)Press MENU or SETUP (depending on the model).
Press the right ARROW repeatedly until the display window reads Maintenance.
Press ENTER.
Press the right ARROW repeatedly until the display window reads Align Print Cartridges.
Press ENTER. The unit will begin the alignment process and the display window will read Printing Alignment Page
Verify that the alignment was successful after the page is complete.
Jul 11, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon imageRUNNER 5000 Copier Logo
323 people viewed this question
old marine
old marine
