Paper jams I have a minolta pageworks 12 printer that has constant paper jams. I've changed out the image cartridge for a new one, and there continues to jam. The paper rolls up to the cartridge and stops. I've cleaned the rollers and removed any possible pieces of paper. What could be the problem?
    Genius:
  • 2,785 Answers
Its seems your printer needs servicing plz take it for serving
Posted on Nov 12, 2009
I have a Konica Minolta Magicolor 1600w which has not been very reliable. After a year I had to replace the fuzer. When the toner ran out, I decided to buy another one since it's cheaper than buying...
the second printer who made that? you bought a new 1600w?? and no you can not use the new cartridge in the old. go out buy new OEM cartridges for the printer the first one. on the new printer. did you clean the rollers did you ensure the printer setting for the media (paper) was the same as on the computer. was paper properly installed landscape versa porait.
Mar 24, 2017 | Konica Minolta Magicolor 1600W Printer
I've got a 4 by 6 photo paper jam in my Lexmark S405 all-in-one printer.
Please follow the steps below to fix the problem:
1. Remove the sheets of paper from the feeder.
2. Try to reach for the paper jam.
3. If paper jam can't be reached, open the printer cover to access the cartridge area. You may be able to get a better hold of the paper jam in the cartridge area.
4. Remove the paper jam and make sure not to tear or leave any torn piece of paper in the printer.
When paper jam is clear, try to print a document again to verify that the problem is fixed.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 01, 2011 | Lexmark All-in-One Printer with PictBridge
I have a problem. When I turn on my printer, the first symbol from top constantly blinks and it doesn't print anything. How can I solve this issue?
Welcome to FixYa!
If the first symbol on the top is constantly blinking as shown in the picture below, It means that a paper or a foreign object has jammed your printer.
Jam can occur in 3 areas. Please refer to the image below.
1. Internal Areas
2. Input Trays
3. The Output Bins
To clear the jam, turn the printer off and disconnect the power cord. Be careful not to tear the paper in case of a paper jam. If a small piece of paper remains in the printer, it could cause additional paper jam.
Let's clear out the Internal Areas first. Push the button to open the print-cartridge door, and then remove the print cartridge. To prevent damage, do not expose the print cartridge to light. Cover it with a piece of paper. Please refer to the image below.
If jammed paper is visible, grasp it with both hands and slowly pull it out of the printer. Please refer to the image below.
If no paper was jammed inside the print-cartridge door, open the Output Bin or the back door
of the printer. To avoid damaging the printer, do not attempt to clear a jam in the top output bin by pulling the paper straight out.
Again, if jammed paper is visible, grasp it with both hands and slowly pull it out of the printer.
If no paper or foreign object is visible, close the back door of the printer.
Next, let's take a look at the Input Tray. (We have already taken out the print cartridge.)
Lift the Tray 1 roller cover, grasp the jammed paper or foreign object, and slowly pull it out of the printer. Please refer to the image below.
If no jammed paper is or foreign object is visible, open Tray 2 and see if a paper is visible. Again remove it slowly with both hands. Please refer to the image below.
Close Tray 2.
If no jammed paper is visible in the second tray area, pull down the upper media guide (we have already taken out the print cartridge). With both hands, grasp the jammed paper and slowly pull it out of the printer. Please refer to the image below.
Close the upper media guide and return back the print cartridge. Please refer to the image below.
These steps should clear out any jams that you are experiencing.
Connect back the power cord again and turn on your printer. You should be able to print now.
Thanks for using FixYa. Keep me posted.
Jas247
Mar 03, 2011 | HP LaserJet Black-and-White Laser Printer
Hi my samsung clp 310 printer regularly jams paper halfway to completion. ....
Hi
Please look at the printer properties under Paper, you will see that the type of paper used can be chosen.
1. This apparently makes the printer behave differently when the default is not chosen.
For example, when I choose Thick Paper, the printer feeds the paper inside the printer much slower than when default is chosen. This, most likely, is done to prevent the paper from jamming up somewhere inside from feeding too quickly.
Therefore, if one is finding that their printer is constantly having a paper jam, changing the paper type may have positive results.
2. Heat maybe another source of paper jams. Although there is no paper jammed in the laser printer, the laser printer may stop printing due from overheating. Therefore, if heat is the culprit, changing the paper type may not work.
Hope this helps !
Jul 22, 2010 | Samsung CLP 315 Laser Printer
Removed paper after paper jam and have opened all the doors to check everything, however it still reads 'switchback jam open front cover up scanner unit'
  • Step 1 Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
  • Step 2 Turn off the printer.
  • Step 3 Remove any paper trays. Inspect them for wrinkled or damaged paper.
  • Step 4 Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  • Step 5 If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
  • Step 6266_a1.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep6 span.image a:first').attr('href','http://i.ehow.com/images/ehows/steps/books/266_b1.jpg'); }); If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  • Step 7266_a2.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep7 span.image a:first').attr('href','http://i.ehow.com/images/ehows/steps/books/266_a2.jpg'); }); If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
  • Step 8 Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  • Step 9 If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  • Feb 19, 2010 | Konica Minolta Magicolor 4695MF All-In-One...
    Misfeed detected but no paper jam
    Di 251 is legacy Minolta machine, Minolta is now Konica Minolta
    for the image unit try this site
    Precision Roller Printer Toner Cartridges Parts and Supplies Office...
    as for the adf replace!!! the rollers all three try the same site above
    Nov 03, 2009 | Minolta Di251 All-In-One Printer
    Konica Minolta PagePro 1350W laser printer. Have
    your carteidge OPC duram is faulty .
    so change cartedige
    Apr 25, 2009 | Konica Minolta PagePro 1350W Laser Printer
    2400w Konica Minolta Magiccolor
    dont understand your problem quite well, but, for a connection problem, update driver, change usb cable and last if nothing helps, update firmware.
    for a paper take up problem,:
    turn off printer,
    remove cover,
    remove drum cartridge,
    under that there is take up roller, pull the knob and move the roller to right, then you can pull the take up roller out.
    first try to clean it and also clean plate under the take up roller. if thats not helping, then you have to cut the biger (larger) plastic sides of the take up roller a little smaller..
    should help.
    good luck
    Feb 10, 2008 | Konica Minolta magicolor 2400 Laser...
    Faded left hand copies
    Pleas check that you inserted the K toner correctly, check, that transfer belt and/or drum cartridge is installed correctli. also check that 2transfer roller, its one big black roller.
    Jan 23, 2008 | Konica Minolta magicolor 2400 Laser...
    jasbo
    jasbo
