Buttons on the slide of j700 donot work while opening slide
hello,
the problem seem to be from the flex that connects the keypad to the screen. it is repairable, first you flash the phone to see if it would work then if it doesnt then you replace the slide of the phone then it would work perfectly. the process is complicated so i'll advice you take it to an expert and if you insist on fixing it yourself.
then you'll have to get a complete set of screw driver, and a replacement flex, then you'll carefully unscrew the phone, then you locate the flex after carefully dismantling both sides of the phone then you replace the flex and recouple it back carefully. the try to turn it on and test the keys.
