Question about Mitsubishi VS-60719 60" Rear Projection Television
Convergence My blue convergence does not respond. Is this worth fixing and is it somehthing I can easily do?
  • Mitsubishi Master
  • 8,617 Answers
If you can solder you can fix this. You have bad convergence ICsthey are located on a huge aluminum heat sink they have a number stamped on them such as STK392-110 you can purchase these for around 6 dollars each at the following link
http://electronix.com/ Hope this helps. Let me know how you make out.
Posted on Jan 08, 2008
6ya staff
SOURCE:
Top left of unit, there is a blue green stripe the covers five inches of the TV. When I hit the cable guide, the letters curve down to the right and look like they are in 3d. With a blue green and red...
Tv will get worse and will dies completely causes more damages to the other tv boards if continue using the tv this way.The tv have a problems known as a convergence problems,it dead.The tv convergence board require replacing 2 STK convergence ICS and some or all of it resistors to fix the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 20, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
I HAVE A TOSHIBA 43H70 I BOUGHT IN 2001 AND THE RED AND BLUE ARE OFF ON THE RIGHT SIDE. I HAVE TRIED TO USE THE CONVERGENCE BOARD TO STRAIGHTEN BUT MY RED WILLNOT MOVE TOWARD THE BLUE OR GREEN. ON NUMBER...
This tv the convergence board are dead.Any colors R,G,B mis alignment,don't matches any colors lines.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts are dead,must be replaced to solved convergence problems.The Shop will cost u $300-350 for parts and labors.
Jul 08, 2010 | Toshiba 43H70 43" Rear Projection...
Tv shows double vision in blue color. how to fix this problem?
This is a problem with your convergence settings found under your tv's menu. its very easily fixed, you just need to open the setting for convergence and use the arrows on your remote to adjust. inproper convergence can cause either a red or blue haze around almost any object displayed on the tv screen
Apr 14, 2010 | Samsung HC-P4363W 43 in. TV/DVD Combo
My RED Convergence is OFF and giving me a RED Blurr. When I try to adjust it manually with my remote, the RED doesnt respond, only the BLUE responds. Does anyone know how to fix this issue? Is it WORTH...
Your TV may have a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jul 19, 2009 | Mitsubishi VS-60609 60" Rear Projection...
Blue shift on Mistubishi WS55411
It is fixable, It is the convergence circuit causing the problem. Unless you are familiar with electronics and with Projection TVs I would not attempt to fix it. Plus the way the convergence board is mounted with hidden screws makes it even more difficult. I would estimate cost would be around 300.00 to 350.00. The set is worth putting the money into it. I recommend a professional to do it.
Hope this helps,
Skyassoc
Jul 03, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Convergence Problem
Unfortunately you will have to replace the convergence board in this unit. it has failed. this particular board regulates the alignment procedure that you are having issues with. replacing this board will fix this issue.
May 21, 2009 | Mitsubishi VS-5047 50" Rear Projection...
Concaved screen image, no response on vertical blue converge
I've read some similar problems that tend to indicate that it is a convergence chip problem, so i ordered a convergence kit. I will update you as soon as I get it fixed. Thanks
Mar 22, 2009 | Philips Televison & Video
Convergence problem?
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in but stationary.
>>>Solution<<<<
You need to replace the convergence chips and convergence resistors.
Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Jan 14, 2009 | Sony KP-65WS510 65" Rear Projection...
I recently purchased an RCA rear-projection TV from a friend, and I'm having some trouble with the convergence. It's model # P60925BL, serial #904251165. When I try to use it, the red and blue convergence...
since two colors are affected I would suggest checking the solder on the convergence power supply. If the solder is good you will most likely need a new power supply. The power supply board is the one without all the heatsinks next to the convergence board
Jun 24, 2008 | RCA Televison & Video
Bottom of projection tube is another color
Yes, worth fixing, sounds like convergence is out on the tip ends. Check papers for Convergence controls. See if have auto fix.
Aug 12, 2007 | Philips 60PP9202 60" Rear Projection...
Mitsubishi VS-60719 60" Rear Projection Television Logo
59 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
