Question about NetGear WGR614 Wireless Router
How to set up Power backup using Batteries and an Inverter
I have wireless antena which i want to put a powe back up for. I have two batteries and an Inverter. how can I set them up?
  • NetGear Master
  • 32,281 Answers
Having only two batteries and an inverter is not an UPS (uninterrupted power supply) does not make a backup power system.
How are the batteries charged up and maintained?
What is the output voltage from the inverter?
Does this voltage suit the Netgear wireless router?
I suggest you get a proper UPS and connect the Netgear power adapter to the UPS. There are small UPS units available 350VA which will suit your needs.
I use a larger UPS from APC for my computer and my wireless router and found the unit very reliable.
Check out APC WEB site - click on this link - then your country and select back-UPS ES for home computers :-
www.apc.com
Posted on Nov 12, 2009
Inverter battery charging
Probably batteries have developed high internal resistance.
Replace with new batteries.
Dec 24, 2013 | Computers & Internet
APC Back-UPS ES500. Battery is new replacement UB1280, and battery has charge and runs fine if unit not plugged in. However, if unit is plugged in to power back-up side outlets in unit don't work.
there are 2 parts of a UPS .
the charge side
and (battery is obvious)
the inverter side.
if the charger fails, all is lost. (are the batteries in backwards?)
if the charger works (volt meter tells you that)
then the inverter is bad. (this unit is not full time UPS , but part time, this means it switches over to inverter at power fail.
(on full time sys. inverter runs full time, like the name states)
the unit, you mean the load right.?
the UPS side plugged into a load. and the load is now dead.
the Backup plugs should work if the mains are hot.
if you kill mains, the inverter will fire off, (hear the squeal?)
and give you 500 watts for some minutes, sucking the batteries dry. (see load run time curves)
I used to do service on HUGE UPS systems, some with 100s of batteries. 3 to 5kw too.
on ours there is a port on the rear , we connect and can
check everything "BEST brand" even charge voltage.
did you look on APC site for special software and connections?
the manual does cover trouble shooting, ever read that?
RTM? start there, its online, for sure.
Oct 03, 2013 | APC Back-UPS® CS 500 UPS System
GE LP33 UPS inverter failed to start
Dear Yared,
Did you try to give the UPS some time to recharge the batteries?
Seems like the batteries have reached their cut-off voltage and are not supplying enough voltage to the inverter.
Normally the dc boos circuit of the UPS will supply voltage to the DC BUS so maybe the problem can be found in the dc boost circuit or BUS if recharging the batteries is not helping.
Let me know.
Best Regards,
Ron
Jan 22, 2013 | MGE Computers & Internet
Replaced battery but system is still chirping. replace unit?
i suspect the inverter circuit of your UPS is already faulty... btw can you give us more detail on this problem?
Mar 22, 2012 | TriPro Power Tripro Maruson Technology UPS...
My inverter (500 va) (battery based electric generator for power backup) keeps on charging batteries even when the charging light goes off making the inverter, wires and battery very hot.
This a possible failure of the voltage detection circuit in the inverter main board and requires the fault be identified by checking the voltage/current feed/limiter to the battery.
Once when the battery voltage has reached the threshold set up the charging should stop and then the circuit will analyse the voltage on the board to trigger the charging to be put ON.
This can be a failure of the detection circuit and if not checked can damage the battery.
Jun 20, 2011 | APC American Power Conversion Back Ups Es...
My ups is not working. it is not responding on main power supply neither backing up.
Batteries in the UPS typically last 3 to 5 years and it depends upon several factors. including the number of times the unit must go on battery power and environmental conditions. There are usually several batteries in the UPS and while the battery voltage may show 13 volts, this may only be a float charge/voltage and a true indication of the battery voltage and condition requires the batteries to be tested under a load. There maybe one battery in a set of batteries that is faulty and causes the whole battery system to fail and indicate a battery fault.
These lower powered and cheaper KVA type UPS are switch over types, when the mains supply fail, the UPS switches over to the battery and inverter in milli-seconds which then supplies mains power but the power waveform is a pseudo sine wave (ie not a true sinewave. A faulty inverter circuit and or flat batteries won’t deliver standby power when the mains supply fails.
Nov 07, 2009 | APC Back-UPS CS 500VA UPS System
How to get a better signal
1. Put yor adapter WIFI to open location,,like a top on building but u mus cover to protect from rain and sun
2. using external antena..
3. buy the best product.
4st your powe on laptop to powerfull performance
Aug 11, 2009 | Computers & Internet
BATERY NEW, BUT NOT GETTING OUT PUT FROM THE UPS.
The is a fairly large fuse that connect between MOST APC 24V system.
If there is TWO batteries inside your system them check the fuse in between the two batteries.
The is a safety loop back plus on larger APC unit. If it's missing it will not power up.
Jul 15, 2009 | APC Back-UPS CS 500VA UPS System
Ups in problem
Your inverter shorted. Get another one.
Sep 06, 2008 | TriPro Power (POW-1000AS) UPS System
Clicking
that's a sure sign that you are in low battery condition, and the inverter is approaching shutdown. You may need to either deep recharge the batteries, with NO load, or replace them completely.
Got Backup?
Feb 10, 2008 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
NetGear WGR614 Wireless Router Logo
122 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
