Question about GE D52GW12 52" Rear Projection HDTV-Ready Television
I have a projection tv that has a module that sparks on the circuit board when it is turned on.
  • williamchadp Nov 12, 2009
    btw. the part has lettering on it for the screen and focusing and adjustments also. it is a coil-like part. does anyone know what this part is?
    the actual coil-like part in the back of the tv on the circuit board is melted. the part has two adjustments on it for the screen and the focus. i am pretty sure the part is fried. where can i get a new part and what is it called?
  • GE Master
  • 11,800 Answers
Most likely in the high tension module some wires are too close to the board - move the components apart and put some ceramic insulators. But in any case fix it quickly or you risk burning your house down.
Posted on Nov 12, 2009
  • Azrael SRL Nov 13, 2009
    It's the High tension line transformer, it's sold in specialized electronic parts shops. Since the circuit board is melted it should be completely replaced - it will be expensive. This is a job for qualified repairman.
Jvc projection tv
it will still be the lamp ,it took a spark its been damaged it will cause all the lines in the tv it has nothing to do with the circuit board
Jul 05, 2008 | Televison & Video
Panasonic PT-51G50CU
HEY !!
ITS A CIRCUIT BOARD PROBLEM ... IC MAY HAVE BLOWN OFF ...
Jan 01, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Problem With Colors
You need to re-solder the circuit board that contains the STK convergence modules. They're on the center circuit board attached to an aluminum heat sink that's about 8" long and 6" tall, about dead center in the circuit board. You may be able to recreate the problem (hour glass effect) by gently moving the heat sink (which the modules are connected to). This gives the hour glass effect on the picture and the advanced convergence screen. This is an indication that the modules pins aren't solidly connected (meaning soldered) properly. Remove the circuit board and clean the old solder off & resolder the modules pins to the circuit board reconnected the board and then retest by again pushing on the heat sink. This is a caused by a minimum effort (a.k.a. minimum cost) solder job, probably done in some 3rd world sweat shop. The "factory" job was good enough for 3-4 years but the heat (and these modules do create a lot of heat) and stress created from repeated use eventually takes it's toll, weakens the pin connections and our problem occurs. take the appropriate cautions working around the high voltage of the set & use a non-conduting piece of wood to push the heat sink when we doing tests.
If this doesn't work, the modules need replacing.
Best of luck, hope ya fix it.
Feb 01, 2008 | RCA P52926 52" Rear Projection Television
RCA projection tv Model # P52927
You need to re-solder the circuit board that contains the STK convergence modules. They're on the center circuit board attached to an aluminum heat sink that's about 8" long and 6" tall, about dead center in the circuit board. You may be able to recreate the problem (hour glass effect) by gently moving the heat sink (which the modules are connected to). This gives the hour glass effect on the picture and the advanced convergence screen. This is an indication that the modules pins aren't solidly connected (meaning soldered) properly. Remove the circuit board and clean the old solder off & resolder the modules pins to the circuit board reconnected the board and then retest by again pushing on the heat sink. This is a caused by a minimum effort (a.k.a. minimum cost) solder job, probably done in some 3rd world sweat shop. The "factory" job was good enough for 3-4 years but the heat (and these modules do create a lot of heat) and stress created from repeated use eventually takes it's toll, weakens the pin connections and our problem occurs. take the appropriate cautions working around the high voltage of the set & use a non-conduting piece of wood to push the heat sink when we doing tests. Best of luck, hope ya fix it.
Jan 03, 2008 | RCA P52939 52" Rear Projection Television
CONVERGENCE GRID IS OFF ON MY RCA P61929
You need to re-solder the circuit board that contains the STK convergence modules. They're on the center circuit board attached to an aluminum heat sink that's about 8" long and 6" tall, about dead center in the circuit board. You may be able to recreate the problem (hour glass effect) by gently moving the heat sink (which the modules are connected to). This gives the hour glass effect on the picture and the advanced convergence screen. This is an indication that the modules pins aren't solidly connected (meaning soldered) properly. Remove the circuit board and clean the old solder off & resolder the modules pins to the circuit board reconnected the board and then retest by again pushing on the heat sink. This is a caused by a minimum effort (a.k.a. minimum cost) solder job, probably done in some 3rd world sweat shop. The "factory" job was good enough for 3-4 years but the heat (and these modules do create a lot of heat) and stress created from repeated use eventually takes it's toll, weakens the pin connections and our problem occurs. take the appropriate cautions working around the high voltage of the set & use a non-conduting piece of wood to push the heat sink when we doing tests. Best of luck, hope ya fix it. If that doesn't work the nodules need replacing.
Jan 03, 2008 | RCA P61927 61" Rear Projection Television
Mitsubishi projection TV
do the self test first to get the error codes
Jan 02, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Problem with convergence
Try re-soldering the circuit board that contains the STK convergence modules. They're on the center circuit board attached to an aluminum heat sink that's about 8" long and 6" tall, about dead center in the circuit board. You may be able to recreate the problem (hour glass effect) by gently moving the heat sink (which the modules are connected to). This gives the hour glass effect on the picture and the advanced convergence screen. This is an indication that the modules pins aren't solidly connected (meaning soldered) properly. Remove the circuit board and clean the old solder off & resolder the modules pins to the circuit board reconnected the board and then retest by again pushing on the heat sink. This is a caused by a minimum effort (a.k.a. minimum cost) solder job, probably done in some 3rd world sweat shop. The "factory" job was good enough for 3-4 years but the heat (and these modules do create a lot of heat) and stress created from repeated use eventually takes it's toll, weakens the pin connections and our problem occurs. take the appropriate cautions working around the high voltage of the set & use a non-conduting piece of wood to push the heat sink when we doing tests. Best of luck, hope ya fix it.
Jan 02, 2008 | Philips Magnavox 51MP392H Rear Projection...
Rca d52w20b
Unless your a tech ....it would not be wise... the crt board as it called has very high voltages... which board was it red green or blue .. right center or left... usally when one of these boards are bad that indicates a possible problem with the actually crt.. very diffcult repair.. be carefull please
Nov 22, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Loss of picture
First thing to do is look at the boards at the bottom of this TV set. If you see a puddle of liquid, or see any eveidence of liquid on the printed circuit boards, you will need to install new "O" rings in the picture tubes as well as new collent, as the collent is leaking onto the boards and the boards will need to be cleaned or replaced. another possiblity is that you have a bad DM module. The DM module has three capacitors that will be all around each other and will be 1000MFD @ 16VDC. You will see if they are bad as the tops of them will look swollen. Good Luck
Mar 27, 2007 | Hitachi 51UWX20B 51" Rear Projection...
Need help
A power supply is a very complex circuit that changes the voltage that comes from an outlet to voltages the tv can use and is a circuit that need to be repaired because in Tv's is only a section of a circuit board and the rest of the board has other functions. Computers use a single module that you can replace as a whole but not tv's.Be safe an call a qualified technician because there is danger involved.Get an estimate.
Sep 17, 2006 | Pioneer SD-P5795W 57" Rear Projection...
GE D52GW12 52" Rear Projection HDTV-Ready Television Logo
67 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
