Question about HP Computers & Internet
I have a dv9700 laptop running vista os everytime i restart my computer i either have no audeo output device installed or when i m computer does recognize it if i use ''any'' program that uses sound it freezes the .program plz help me with this i believe i have tried everything
  • kumusaki Nov 13, 2009
    already did i set it back to factory setting nothing is on the computer and i scaned
    Prodigy:
    An expert who has answered 500 questions.
  • 674 Answers
Disable Unnecessary Services
There are too many hidden services running in the background at system startup which may be a cause of laptop freezing. You can disable unnecessary services from the start up by following the guide below:
  1. Click Start button
  2. Open Run
  3. Type msconfig and press Enter
  4. Click on Services tab
  5. Remove all unwanted services from start up
  6. Press OK
Run Disk Checkup
Disk Checkup is a very good method to fix laptop freeze. Disk checkup helps you to remove the errors that are causing laptop freezing problem. You can follow the steps below to run disk checkup:
  1. Open My Computer
  2. Right-click on any one of the drive
  3. Go to Properties
  4. In Properties click on Tools
  5. Now click on Check Now
  6. Select the option "Automatically fix file system errors"
  7. Press Start
Disable Startup Programs
Disabling Startup programs can help you to fix laptop freezes randomly problem. Follow the steps below to disable unwanted startup programs.
  1. Click Start
  2. Click on Run
  3. Type Msconfig in the blank space
  4. Press OK button
  5. Click on Startup tab
  6. Disable all the unwanted programs
  7. Reboot your computer
Clean Registry Errors
Corrupt registry causes many problems due to which laptop freezes randomly. Registry gets corrupted when it is overloaded and it starts generating errors. To fix registry errors quickly, use a powerful registry cleaner and PC optimization software.
Tired of Laptop freezing? Want to fix this problem for good? The easiest way to do so is to install the Intel Software Partner RegInOut. To download RegInOut click here.
Posted on Jul 25, 2011
    Genius:
  • 2,785 Answers
Plz scan your pc for viruses and then download latest drivers and install it
Posted on Nov 12, 2009
No display on laptop screen and external monitor to perform any action on hp PAVILION DV9700
use some special function key combination you activate it for output vedio device such key combication start fn key + function key to display output
May 19, 2012 | HP Computers & Internet
I'm having problems with the audio for my hp dv6929wm laptop. Windows does not detect and audio device and everytime i go to update the drivers the installation stops because it can't detect and audio...
If you've ensured the correct services are running and the correct drivers are installed/attempted to be installed, I'd say there's a good chance you're experiencing a hardware problem. The easiest way to test that is w/ a Linux Live CD or to perform a factory OS reinstallation. If you don't want to restore the the computer, try booting a computer up w/ a Ubuntu install cd, and try running the OS live (w/out reformatting/installing the OS), and test the sound. I recommend Ubuntu because the driver support is pretty good. With that said, if it doesn't have the correct sound driver for your hardware, this solution will not help us out, so at that point, I'd recommend reinstalling Windows and see if your sound works. If it doesn't work after the OS reinstallation it's a hardware problem.
Mar 25, 2011 | HP Pavilion dv6000z Notebook
Download free audeo device for my acer laptop
Download the drivers from the Acer WEB site. Make sure youselect the model of your laptop and the XP or Vista version of the drivers youthat require and it matches the Windows version that is installed on yourlaptop. Use this link to get to the Acer support: -
http://www.acersupport.com/drivers_download.aspx
Dec 19, 2010 | Computers & Internet
My computer keeps on restarting everytime I connect a USB device like, flash drive, printer etc. I tried restarting my computer, then when everything's done loading, i connected a flash driver and after a...
I would reinstall xp OS... you should be able to do a restore without loosing any of your own files. After an os restore you may have to reinstall a few programs but your data files should be ok if you do the correct type of install.
Sep 22, 2010 | Microsoft Windows XP Professional
MOBO Computer freze or stops or restarts when installing an O.S
I'd try the RAM modules individually, see if any difference.
Try Resetting BIOS Defaults, make sure the RAM timing is correct
install crashes are generally RAM possibly the video card
Jul 19, 2010 | Computers & Internet
My hp webcam doesn`t seem to be enabled
drivers for webcam hp....
windows Xp
I assumed that for vista you have the drivers cause the laptop came with a vista os on it ...anyway you can get them on a search on google cause it is an easy to find..download...
ok ...what you have to do if it do not see your cam ..is fist go to the add remove software ...in the control panel ...and remove any driver related to the camera..
than take a look into the device manager ...by right click on my computer icon ..than properties/...hardware ...and device manager ...
Here you look for the webcam ...it should be presented in yellow ..with an ask sign ..if it has no driver....
If there is nothing like a web-cam around...press the last icon (scan for hardware changes) ..or right click on computer and same ..scan for hardware changes...this will scan for any devices that are added and not yet installed...
The same thing can be made ...from the control panel by using the add new hardware wizard ...but ..sometimes it is hard to find it in the list ...
Anyway..., after you located the camera...eiter run first the driver you downloaded for xp ...or you already have for vista.....and than restart ...or ...right click on the camera in the device manager ...and run update driver wizard ...and durring this ...you will choose the driver by browsing from list ...
beter do it both way ...run the installer ...and after that update from the device manager to find it ...
or if the driver is not an instaler but a folder ...run update driver ...and point it to the folder by browsing to choose driver manually ...
Restart ...and beware that during the installation the windows os ..may not recognize the driver as a digitally signed on e...but choose to run it anyway ..
Good luck ! and do not forget to rate ...Thanx!
Jan 10, 2010 | HP Pavilion dv9000z Notebook
How can i install audio divice by motherboard cd
Installing a driver is not a problem...
simply open my computer, and autorun the cd (If Autorun is enabled)
If Not, Follow these steps :
-Go to my computer,
-Right click, go to its property,
-Go to devie Manager, Click Yes to .UAC notification.
-Now go to sound & audio, expand it.
- When u find ur prefered audio device, select it & make a right click over it,
- Now click update driver,
- follow the steps & let it search the best driver from the CD
- Be patient as it would take time to surf 700MB's of cd.
- After this is done, it will install the driver software & its done..
Restart Ur System & its done..
And My Personal Advice For Vista Users,
Turn off the .UAC notification that comes everytime u click somethin to install or somethin, its really harassing.
To Disable it Follow these steps (It wont Hard Anything)
Click on start
Click on ur Photo (User Account Control)
Once it gets open, select ur profile,
U'll see a tab,
TURN OFF/ON USER ACCOUNT CONTROL FEATURE
Open it & unmark it..
Restart it & see how fast ur system can be
Hope This Helped u out...
Thanks....
Aug 27, 2009 | Acer Aspire 4315 Notebook
No Audio Output Device is Installed
try installing a sound driver for it again
Feb 06, 2009 | Computers & Internet
NO AUDIO OUTPUT DEVICE IS INSTALLED
windows key + R = open : devmgmt.msc
Sounds, video and game controlers > (right click) Realtek high definition audio > update driver sofware > browse my computer for driver software > let me pick from a list...> double click on Realtek high definition audio > YES to update driver warning > AND SWEET SOUND IS AUDIBLE :D
Dec 14, 2007 | Microsoft Windows Vista Ultimate Edition
Installation
do you have any operating system disks or restore disks, if so re-install with the restore disks and it will be just as it would have been, what operating system are you using, probably windows xp or vista, but most likely solution is to re install the OS, or try exploring any other options given by the error dialog.
Mar 24, 2007 | AST Wireless Storage Device 300Gb (gs180w)...
Computers & Internet Logo
98 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
