Question about Nokia 6610i Cellular Phone
Clicking goto and it will suddenly restart - Nokia 6610i Cellular Phone
My Doro phone keeps saying unfortunately my settings has stopped working.
Method:1
Goto settings-apps-all-setting and settings-apps-all-setting storage
click clear data and then click force stop.
Method:2
Goto settings-apps-all-launcher
click clear data option and then your launcher is restarted.
finally once reboot your android the error is fixed.
Mar 11, 2017 | Doro Cell Phones
Tip
Dvd Not Recognized /Itunes Registry Hack
goto start type in regedit right click on it and run as administrator then goto hkey local machine click the + sign then goto then click on system then the + sign then goto current control set then click + sign then goto control click the + then goto class click the + sign then goto 4D and delete the upper and lower filters in that folder located on the right side of screen.
here is the comp[lete key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
then navigate to this key
6D
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{6D807884-7D21-11CF-801C-08002BE10318}
then to this key
CE
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{CE5939AE-EBDE-11D0-B181-0000F8753EC4}
under each key delete the upper and lower filters from the folders once that is done close registry editor. then goto start control panel device manager goto dvd/cd rom click the + sign and right click on the dvd drive and delete and when the warning message comes up check the box underneath to delete the drivers for this device then close device manager and restart the notebook.
on Jun 22, 2010 | Computers & Internet
Printer spooler stopped working
Goto Control panel, click Administrative tools then Services.
Scroll down the list to Print Spooler and you should be able to start the spooler service. It should say Start and Stop in the left hand pane.
You can also look at the properties by double clicking on it, then you can change the Startup type to Automatic. Then click Apply.
Or goto the start menu and type services.msc in the search / run box and press enter. Then scroll as before.
Or goto start menu and type msconfig in the search / run box and press enter. When it appears click on the Services tab next to Startup and scroll down to Print Spooler, if the little box is empty click it to tick it.
Then click apply and ok, you may have to restart you computer.
If you restart and you get a warning box popup saying that you have been in to the configuration etc, just click the little box on the left and it wont show up again.
Feb 08, 2012 | Toshiba Satellite P35-S611 Notebook
Ethernet control driver is not working
Did this suddenly start on its own?
Have you checked for Malware?
You can download the
malwarebytes scan tool on a different computer and transfer it to you GX260.
I would also remove the ethernet device and let the system find it again without changing anything else.
  1. Start device Manager
  2. Find the ethernet device and click unistall
  3. reboot
To check for malware:
  1. Goto Malwarebytes.org
  2. Download free scan tool
  3. Install tool
  4. goto the software directory for Malwarebytes and rename the application file to scanme.exe
  5. Run the application
  6. Start the quick scan
  7. Follow the suggested fix/removal
  8. Reboot
I have seen this happen on more than one machine. Trojans and malware disable the ethernet driver to prevent access to security updates.
Mar 25, 2010 | Dell OptiPlex GX260 PC Desktop
Display suddenly becomes pixelated or fuzzy
just goto mycomputer then right click select properties
display setting adjust the bit of the color make it 32 bit
or if your O.S vista just right click on the desktop click personaliza display setting. change the color into 32bit .
Mar 05, 2010 | Dell Vostro 1310 Notebook
Screen suddenly goes white with toshiba l505d
Hi there, please restart your laptop when its booting press F8 key . You will find few option asking for selection. Select that by using up/down arrow key. Select " Last know good configuration" & press Enter. Next page asking for selecting operating system, for example: windows vista or Windows XP etc. Just select the operating system & press Enter again. ( Hope your laptop showing only one operating system ). Your laptop will start normally. Another suggestion is run your Toshiba l505d driver DVD for installing Display drivers. When finish restart your laptop and watch whats going. If no success then format the Operating system & reinstall again.
Thanks & waiting for your feedback.
Feb 09, 2010 | Computers & Internet
My computer get no sound at all
1. make sure the sound is not muted. double click the sound icon beside the time and check to see nothing is muted.
2. make sure the speakers are switched on and plugged into the corect hole on back of computer normally its the green one.
3. goto start settings control panel , system
then goto hardware , then device manager. if there is anything in this list with a exclimation mark, ! right click it and goto uninstall.
4. restart computer.
5. if it ask for drivers when you return to windows try find your system driver cd.
6. if you cannot find this click here to download your sound drivers and install.
7. then restart.
Dec 03, 2009 | Dell Dimension 3100 PC Desktop
My laptop wont boot completley it gets to a certain spot to where io can see the mouse but a black screen, then it shuts down and some how it turns back on again and does the same thing all over again.
>Restart your system
>Goto Safe mode by clciking F8 when your system restart
>Login using admin account
>Goto Msconfig from run
>Goto startup and uncheck the unwanted process and click apply and restart your computer
Aug 14, 2009 | Computers & Internet
I have a problem with sound
Try uninstalling the driver and restart pc, goto start, control panel, (if you haven't already, chainge it over to classic view) double click on "system" click on the tap "hardware" click on device manager, go to sound,vido and game controllers, right click on your audio divers, click delete, restart pc to reinstall the drivers, please let me know if this doesn't work we will go a differant direction.
Jun 20, 2009 | Compaq Audio card Sound Card
Shuts Down
Start your computer and goto safemode and enter intot the windows and right click the my computer icon and goto properties and Hardware tab and device manager in that see the usb driver is correctly installed and if not installed correctly .reinstall the usb driver and before that dont connect the any pendive and usb hard drive in the usb port and reboot it. try it and inform to fixya.com if it porb continues bye.
May 14, 2008 | HP Compaq Presario V2000 Notebook
Nokia 6610i Cellular Phone Logo
44 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
