Question about Sony RDR-VX560 DVD Recorder/VCR
How do you change the setting from dvd 1 to dvd 3
I just had this problem. The way I fixed it was to program the remote to dvd 1 by holding down "enter" and "1" together for more than 3 seconds.
Posted on Nov 16, 2009
I bought my dvd player from Malaysia but I am using it in Middle East where I am currently residing. Initially, we are able to play all dvds (which we bought original) but suddenly, it kept popping a...
Are you using WMP or any third party players to play the dvds ?
I suggest you to check if the DVD region code is set to one (US) or not. If not, change it to one.
The region can only be changed five times, before its set permanently.
How do I change my DVD region?
DVD movies are encoded for different world regions, and your DVD-ROM drive must be configured for the appropriate region in order to play the DVD.
If you have DVD-decoder software installed on your computer, you can usually change the DVD region setting in the DVD decoder program. Follow the instructions in the program's Help file for changing the DVD region setting.
If you have a software or a hardware DVD decoder installed on your computer, you can use Device Manager to change the DVD region setting in your DVD-ROM configuration:
1. Click Start, right-click My Computer, and then click Properties.
2. On the Hardware tab, click Device Manager.
3. In the list of devices, double-click DVD/CD-ROM drives, right-click the DVD drive for which you want to change region settings, and then click Properties.
4. On the DVD Region tab, make the desired changes.
You must be logged on as an administrator or be a member of the Administrators group in order to change the DVD region.
Note that the DVD region for most DVD-ROMs can only be changed up to five times, and the number of changes still available is located on the DVD Region tab. If the tab shows that you can only change the setting one more time (Changes remaining = 1), you won't be able to play DVDs that use a DVD region that is different from your last selection. If you run out of opportunities to change the setting (Changes remaining = 0), contact your DVD-ROM's manufacturer to reset this value.
Also install DVD decoder as an issue with codec or DVD decoder could even cause the issue with DVD region code.
http://www.microsoft.com/windows/windowsmedia/player/plugins.aspx (Also applies to Windows 7)
Mar 26, 2011 | Vacuums
Locked on DVD 1 and remote will not work on Sony RDR-VX 521 how can I reset remote or get into system menu to change back to DVD 3
on remote there are 3 settings on the bottom controls it has tape covering
them uncover and switch to dvd 1 then you can go into settings and change to dvd3
Jan 12, 2011 | Sony RDR-VX521 DVD Recorder/VCR
How to set as master
u need change in the mother board settings by seeing IDE 0 / SATA 0 , 1 or change in device in jumper settings by seeing in the device cover.
Apr 17, 2010 | LG GSA-H10A Burner
Getting Region 1
All the recent DVD drives have the region set in the hardware. This can be changed, however it can only be changed a small number of times, ( usually 5 ), after which it locks.
Because you do not live in region 1, I recommend that you get a second drive and set it to region 1. When you buy a DVD drive the default region code is the same as the region in which the store is..
Not sure on the details, but I think the software that came with the drive can change the region. Read help.
Region codes are a curse and one of several reasons why people illegally copy movies.
Feb 16, 2009 | Samsung DVD-VR320 DVD Recorder/VCR
Our Sony DVD player will not playimported DVDs from the UStates
1) those DVDs are coded in Region 1(Canada, United States; U.S. territories; Bermuda)
you will have to change the region code on the dvd-rom to region 1
2) if you bought the stand alone DVD player in the U.S. it will play region 1 dvds and nothing else(some dvd players will play region code 1-6)
3) to change the code in windows vista you'll have to go under the drive property's in the device manager go to the dvd region tab and set it to what ever the number on the back of the dvd is WARNING you only get 4 changes before the drive locks you out permanently then your stuck with what ever number you put in on the 4th try you've been warned
windows xp/2000/98/me
you'll have to change the region code from your software player again your limited on how many times you can change the region code before you have to reinstall the dvd player software
Feb 02, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Mac dvd drive regency code locked
This is not a feature of the Mac - this is a feature of DVD-ROM drives and is part of the DVD standard.
DVD-ROM drives, once changed 5 times, can NOT be changed.
The only solution would be to purchase an external DVD drive, and set IT to region 2, and leave your internal one set to region 1.
The region settings are legal issues with the DVD standard - the 5-time limit is permanent, hardcoded, and unchangeable.
Aug 03, 2008 | Apple PowerBook G4 Mac Notebook
Unable to change the DVD 1 Command Mode back to DVD 3 (DEFAULT) SETTING
Had the same problem when I changed the factory settings by mistake. There is no "cancel" button in the remote or the set. What worked for me was to follow the directions on P. 22 of the manual and change the remote settings to DVD 1. This is done by holding the "Enter" button and pressing number 1 on the keypad simultaneously for more than 5 seconds. Then, you go back to the "Settings" screen with the "Settings" button, change the control back to DVD 3, and reverse the setting in the remote by pressing "Enter" and the number 3 this time. Remember to hold them down more than 5 seconds. Good luck!
Aug 02, 2007 | Sony RDR-VX555
Region
coby 514.
power up. put disc in tray
press set up
then vol+ vol- vol+ vol-
code appears in top right 1
change altering left and right buttons
leave on 255 multi region (all discs)
press set up.
Coby DVD-514M
Turn unit on with remote
NO DVD in the tray (mine was closed, but opened might work)
Press TITLE then 1 then 9
Gray box will appear in the center of the screen with number 1 in the middle
Using up/down arrows change to desired region (0 for REGION FREE)
Jun 12, 2007 | Coby DVD-514 DVD Player
Sony RDR-VX560 DVD Recorder/VCR Logo
290 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
