Picture on the monitor shrinks from both sides and also top and bottom
  • 11,896 Answers
On main window screen, right-click, then go to properties, then select resolution size.
Posted on Nov 12, 2009
Picture cut off on sides, how do i shrink picture to screen?
If model listed is correct the problem is in power supply or vertical or horizontal circuits.
If cut off on sides (horizontal) and bowed on sides it is a pincussion problem. IF short top and bottom a vertical issue--if both it is in the power supply.
Model listed is rather old and parts may not be available for it.
May 30, 2012 | GE 35GT740 35" TV
Picture sharink form bottom
This is a technical problem found on PCB (printed circuit board of the Monitor). If you are a qualified electronics technician then you can repair it. If you open the back panel of your monitor you will see the main circuit board where all components are. The soldered side is the side is the one that you have to look at. Usually this problem is caused by dry joints. So the first thing to check on is the dry joints on the vertical oscillator circuit. Check all the capacitors and see if they are not shorted or open. Usually the radial capacitors on the vertical circuit swell at the back, if you see any swollen ones replace them. This should solve the problem. If you are not a technician then refer this to a qualified technician as it can not be done by a lay man.
Oct 22, 2011 | Samsung SyncMaster 753S 17" CRT Monitor
Pictures shrinks.. Panasonic TC-20LM Television
Shrinking picture is a voltage regulation problem in the switch mode power supply, Possibly a cap used in the feedback circuit. Or an over current condition on the B+. This is a very tech intense repair because there is no magic bullet. If it is shrinking on bright scenes then you can bet it is a regulation problem, bright scenes draw more current from the power supply causing this effect. I would not suspect the horiz output because the regulation for this circuit usually comes from the main switch mode power supply. One diagnostic is to monitor the B+ going to the horizontal output and see if it fluctuates. If so you can bet it is a cap or optical coupler in the switch mode circuit.
Oct 10, 2009 | Panasonic Televison & Video
Problem with data cord
Change the data cord if not repaired then change the monitor ,give another companies monitor
Aug 26, 2008 | Philips 105S51 15" CRT Monitor
Shrinking picture
I stopped by a local repair shop a got some helpful advise.
May 28, 2008 | Samsung TXL2791F 27" TV
GE 31
check electrolitc capacitors in horizontal circuit
May 09, 2008 | GE 31GT659 31" TV
NO PICTURE HAS SOUND
When you say small do you mean shrunk up top and bottom as well as from side to side. You definitely have a deflection problem either horizontal or vertical.If the picture just shrunk top and bottom you have a vertical deflection problem. Do you have the service manual for your model? If not let me know and I will email you one. Describe the shrinking issue a little more and I should be able to give you some guidance.
Feb 06, 2008 | Philips Magnavox 9P6034C 60" Rear...
Picture is shrinking from the bottom
Hi you have lose solder in yor vertical section have a tech resolder it or that problem will cost you .hope you have already have it remedied.
Nov 14, 2006 | Toshiba 36A40 36" TV
Shrinking picture
All symptoms indicate a problem in the vertical circuit,the first thing to look for will be loose conection on the vertical output IC,sometimes this IC goes bad completly and it needs to be replaced.If you are familiar with soldering electronics you can take care of it but if you are not too familiar you can play it safe and take it to a servicer ,it will be a lot less expensive than if they come to your house.Let Us know how it goes or if you need more information.
Oct 26, 2006 | Quasar SP-2722 27" TV
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Electro Med Services...
