Question about Dell Inspiron 1525 Notebook
Dell 1545 not detecting my harddrive - Dell Inspiron 1525 Notebook
    President:
  • 414 Answers
This problem to an i/o device happens mostly when itz defective/faulty..
check the following:
(to take data backups u gotta connect the hdd to another pc/laptop, for such cases a hdd-case is available in the local spare market, it'll make behave ur hdd to act as an external removable drive)....
1)if ur hdd is making any humming noise (like 'tic tic' or 'kirr kirr')..if so it is likely to be replaced..
2)check for bad connections..
3)update/flash the bios..
4)check for firmware update and or raid drivers (as applicable)..
if u r not a professional, try contacting ur system admin/vendor....
Posted on Nov 12, 2009
Ethernet driver
It takes time because dell has many options for this model. trial and error is the best method if you do not do dell system detect. Sometimes dell detect does not find you hardware, therefore, be prepared to try all of the available drivers from the dell website for you laptop.
Feb 05, 2014 | Dell Inspiron 1545 Pentium Dual-Core T4500...
My dell inspiron 1545 laptop web cam isnt working with skype anymore
Check in your Device Manager from the Control Panel. Look for the WebCam under Imaging Devices. Delete it and allow the system to reinstall it by using Scan For New Hardware. If it's detected, open a browser and go to TestMyCam.com (yes, it's safe). If you have video there and not in Skype, remove and reinstall Skype. If it's not redetected in the Device Manager, it's likely broken (yep, they do break).
Aug 26, 2013 | Dell Inspiron 1545 Notebook
Why won't my dell laptop cannot read the primary internal harddrive?
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.
Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 08, 2012 | Dell Inspiron 1545 i15-143P Jet Black PC...
Dell inspiron 1545 laptop wont boot. Error unable to locate hard disk drive
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Jan 21, 2012 | Dell Inspiron 15 1545 Notebook
My hard drive in my 1545 inspiron is shot. I am getting a code of 2000-0146, a harddrive error. should I reinststall the OS and start over or do I need to buy a new harddrive. I can't even run safe...
If you can get to your BIOS settings, change the hard drive settings from SATA to AHCI SATA and see if does anything for you. If not, then the hard drive needs to be replaced. Any 2.5" SATA drive will work. You will need to re install your OS, drivers, and all when or if a new drive is installed. If you have a back up CD it shouldn't be hard, but you are going to loose any data that you had saved.
Aug 10, 2011 | Dell Inspiron 1545 Notebook
Ran Dell diagnostics and SATA Disk Confidence test failed, Error Code 0F00 1332,Disk Block 30819848(etc)IRQ did not set in time. Dell Inspion 1545 laptop with SATA disk s/n 5VC2W51X
consider to replace your hard drive, your hard drive detected crash on your bios so you have to replace it. your hard drive can be use to external hard drive buy some external hard drive case 2,5"
you can re partition your hard drive and maybe if you are lucky the harddrive can be use again on your laptop
Jan 16, 2011 | Dell Inspiron 1150 Notebook
My dell inspiron 1545 has a pop up coming on before the log in screen it says the instruction at 0xfbd0584d referenced memory at 0x00000008. The memory could not be read. I can't get passed this screen to...
I would call Dell, being that your computer is still under warranty. It will save you time and hassle, hopefully! ;) Heres their number for you
Don't Lose Your Peace of Mind!
Call 1-866-777-1542
Lori
Oct 12, 2010 | Dell Inspiron 1545 Notebook
Opened laptop to find ' internal hard drive not found ' i did a reseat on hard drive , still not working. ran f5 test and tests all ok bar hard drive not found. laptop was working 10 mins before error came...
Please make sure if you open the back part of the laptop check the Harddrive if it is firmly connected. bacause it is possible that the reason why the laptop doesn't detect it is because of the physical connection.
Oct 01, 2010 | Dell Inspiron 1545 Notebook
The speed of my laptop when it starts take longer then the desired time....!!! config of my laptop: dell-1545 3 gb ram 320 hd vista home basic
  • Hi, go to the Control Panel, In the Programs category, select the "Change the Startup Programs, only start essential programs at "Boot-Up," you can "stop certain "Services," and "Processes in the (Task Manager) from running during start-up aswell. You may need to "Backup Files, and do a Defragmentation of the HardDrive, open the Computer from the Desktop, select Properties, choose the (Tools), you can use "Clean-up Disk" to make more "Space," all of these will improve the perform, and speed-up the "System." If the solution helped, "rating it is appreciated, thanks."
Mar 07, 2010 | Dell Inspiron 1545 Notebook
Dell Inspiron 1525 Notebook Logo
276 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
