Question about Canon ImageRUNNER 3570 Copier/Printer
I want to install printer & scanner on my pc in connection with ir3570. i need the software.
  • 79 Answers
How do I get the scanner to work on my computer
your printer probably has a software to install.
this software has the mode to scanner and to scan. the pc has a printer connection right? and.... how to scan should be on the software for the printer. it recognizes the printer and it's looking for a scanner, this is why is telling you scanner connection under the scanner connections but if the use is with the printer as a scanner, it must've a software. maybe the printer a scanner button so the pc recognizes it as scanner.
Jan 22, 2015 | Office Equipment & Supplies
Ir3570 lines coming
Hi Mashhoor,
please clean the printer head with its software.
and try.
printer head is dirty or printer head connecting flex cable loose connected with circuit board.
to fix that go for a technician,
regards,
nuwan
Jan 16, 2014 | Canon Office Equipment & Supplies
Need to scan docs from scanner to pc
You have to install scanner and printer software came along with the HP 3030 model.Once setup complete it will try to do self diagnose the scanner connectivity.Then when you press the button on the scanner ,scanner will send the data to pc to activate the scanner software automatically.
Nov 26, 2012 | HP LaserJet 3030 All-In-One Printer
Canon 272 scanner software
You need to install the software then connect the scanner & open the software. Put the paper in scanner & then click scan option in software for scanning. Select before scanning your choice. Jpeg /PDF format u want.
Aug 09, 2012 | Office Equipment & Supplies
Error code e0000007
solution E732 scanner communication error
May 25, 2012 | Canon ImageRUNNER 3570 Copier/Printer
I have an HP psc 2410 photosmart all in one Printer but the scanner is not set up. It used to work but my PC has had problems off & on and I guess when the problems were fixed we didn't check to...
Unplug the cable from the printer to the pc, then go to HP's website (www.hp.com) and click on support, and then download software/drivers. Enter the name and model of your printer and download and save a copy of the software/driver to your pc but do not install it yet.
Go the the control panel on your pc, and open install programs. Find your Photosmarts software thats install on your pc and uninstall it. Then go to printiners in your control panel and delete your HP printer.
After all of the above is complete, then install the software you save to your pc from HP's website. Connect the cable when the software tells you to do so. Taht should fix your problem.
Jul 12, 2011 | Office Equipment & Supplies
I download hp 5590 drivers from hp.com i tried to install it, the proces eend normaly, but if i connect the scanner, windows xp show the new hp connect like its not installed yet. I check at add remove...
FIRST UNINSTALL YOUR PRINTER COMPLETELY
REMOVE ALL CABLES OF PRINTER (USB)
REBOOT YOUR SYSTEM
HAVE DRIVER CD
PUT IT IN ROM(CD/DVD)
INSTALL PRINTER SOFTWARE
DONOT PLUG THE USB CABLE UNLESS & UNTILL PROMPTED
PLUG USB WHEN ASKED
FINISH INSTALLING PRINTER
NOW YOU CAN FIND THE SCANNER
Feb 15, 2011 | HP Scanjet 5590 Flatbed Scanner
I have new Hp photosmart C4385 all in one scanner, printer, copies. The printer was initially onstalled. Working w/ wireless HP pavillion. It print & copies fine. Scan does not work. When I enter...
I had a similar problem recently... You have to actually install the scanner software. You probably only installed the print drivers, but not the scanner software. If you don't have the CD handy, go to www.hp.com/#Support. In step one select "Download drivers and software (and firmware)". In step 2 enter your model number (photosmart C4385) and then press "go". It will lead you to a page to select your operating system. Follow that link to download the entire CD (large file).
When you are installing the software, make sure to install the scanner software too.
John Lox
Apr 14, 2008 | Computers & Internet
Canon ir 3570
Can anyone pls let me know the procedure to scan a document using Canon IR3570?
Mar 28, 2008 | Canon ImageRUNNER 3570 Copier/Printer
235 people viewed this question
old marine
old marine
