Question about Hotpoint WF430 Front Load Washer
Water appearing on bottom left hand side,can find no obvious cause
  • 11,896 Answers
Either the pump is leaking or front door seal or tub is leaking. The hoses internal and external connections can leak as well.
Posted on Nov 12, 2009
Testimonial: "Gosh,that was quick!many thanks."
Have an LG washer WM3001HRA and there is water leaking below the filter, bottom left hand side. have cleaned filter re-installed it tightened it and within 2 loads there is water on the floor. what ne
The drain pump motor and water recirculation motor connected to a hard plastic "housing" is in that area of the machine. The hoses connected to those parts along with the motors and housing will need to be visually inspected. That involves removing the top and front of the machine to get down there and see if there is any obvious cracks or holes in those parts. LG Washer Disassembly Parts for LG WM3001HRA ACREEUS Section 2 Parts
Jan 16, 2015 | LG Washing Machines
Why is condensation in fridge?
Good afternoon friend, thank you for your post!
I understand that your Frigidaire refrigerator has moisture forming underneath the bottom panel of your freezer and that is causing water to drip onto your shelves. Would you be able to provide me with your model number that way I could research additional information for you please? You can locate your serial tag (which lists your model number) on the inside cabinet of the fresh food compartment normally on the left side of a top mount. On a side by side it can be found on the right hand side. I look forward to your response. -Matt
Jul 16, 2014 | Frigidaire Refrigerators
Shadow on Sharp Aquos LC32GA6E
Unfortunatley, they don't make TV sets as dependable as they used too because they don't want them to last. Your problem with this unit is that your panel is going out. Sharp does not supply panels because they are not cost effective to replace. I hope this helped your cause.
Apr 10, 2012 | Sharp Aquos Televison & Video
My watch is stuck on military time somehow. I would like to know how to change it back to normal time. My watch is a Armitron Alarm/Chrono WR 165 sports watch. The number on the back is 45/6915. Thanks for...
Welcome to Fixya,
The Armitron WR165 is a digital watch that includes a 24-hour alarm, hourly chime, stopwatch feature, countdown timer and is water resistant up to 165 feet. With a rubber wristband and rugged style, the watch is meant for outdoor enthusiasts and athletes. The WR165 can be found online, in some sporting supply stores and in certain department or general home stores. Setting the Armitron WR165 only takes a few steps to perform properly.
1 - Push the top button on the left-hand side of the watch until the seconds flash on the display.Press the top button on the right-hand side to zero the seconds.
2 - Push the bottom button on the left-hand side of the watch until the hours flash and then the top button on the right-hand side of the watch to increase the hour on the watch display. Note that "PM" will appear on the watch display for PM times, but there is no "AM" indicator on the display.
3 - Press the bottom button on the left-hand side of the watch until the minutes flash on the display.Press the top button on the right-hand side of the watch to increase the minutes on the display.
4 - Repeat to set the month, date and weekday on the watch. Press the top button on the left-hand side of the watch to return to time mode.
5 - Press the bottom button on the left-hand side of the watch to enter the stopwatch mode. Press the top button on the right-hand side of the watch to start the timer. Press one more time to stop timing. Press the top button on the left-hand side of the watch to reset the stopwatch to zero and the bottom button on the left-hand side of the watch to return to time mode.
6 - Press the bottom button on the left-hand side of the watch twice to set the alarm. Press the top button on the left-hand side of the watch until the hours flash on the display. Press the bottom button on the left-hand side of the watch until the alarm number flashes. Press the top button on the right-hand side of the watch to choose Alarm Time 1 or Alarm Time 2. Push the bottom button on the left-hand side of the watch again until the hours flash. Push the top button on the right-hand side of the watch to choose the alarm hour, followed by the bottom button on the left-hand side of the watch to change to minutes. Press the top button on the right-hand side of the watch to advance the alarm minutes. Press the top button on the left-hand side of the watch to set the alarm time and the bottom button on the left-hand side of the watch to return to time mode.
I hope this will help you.
Thank you for usinf Fixya.
Feb 21, 2011 | Watches
Not filling with enough water
If you remove the lid and looking at the front of the d/w take of the lefft side panel, at the right bottom on the side you should see a pressure chamber with some micro switches and a red lever. This is possible blocked along with the hose that is attached to it (to the right, behind the chamber) clear them both and retest with the side panel off to check for good flow and to make sure you have not created a leak.
Good luck
Jul 08, 2010 | Neff 24 in. S5555X0GB Built-in Dishwasher
How to put key code for office 2007 that is already installed
When in Office 2007 click the circle icon in the top left hand corner, then click word options that is shown at the bottom of the box, another box will appear and in the list on the left hand side click resources, then activate in the options that appear. :)
Jun 19, 2010 | Office Equipment & Supplies
I have a 1998 Buick Regal supercharger that is leaking antifreeze under the engine. What are the possible causes and repairs?
I would start by checking the water pump. Look at the bottom of it and see if coolant is running down the front of the engine from the hole in the bottom of it. If that appears to be okay look at the sides of your engine. There are 3 frost plugs on each side about halfway between the oil pan and the heads.They will occasionally rust out and leak too. I assume that you have already checked the obvious rad hoses and radiator for leaks. Hope this helps.
Oct 29, 2009 | 1998 Buick Regal
Dell 3000CN Laser Priner
Removed the fuser unit and also removed the left hand side panel to access the gearing mechanism.
Manually rotated the gearing a number of times thru 360 degress. This appears to have cleared whatever was causing the printer to detect a paper jam although there was no obvious sign of bits of paper or even dust build up.
Dec 28, 2008 | Dell 3000cn Laser Printer
Hotpoint WF430 Front Load Washer Logo
181 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
