Blue sreen error when ever starting system
Hi...
in begning my pc was too slow and i replaced my 128 mb ddr1 ram to 512 mb ddr1 ram.
after that my pc work good for few days, and then it start showing error massages like ***stop: 0x00000007e(0xc0000090, 0x004b4bd8, 0xee25885c, 0x00000000),
***stop: 0x000000001,
***stop: 0x000000005....etc.
each time new error WHICH HANGS MY PC OR AUTOMATICALY RESTART IT.
i search on google for this and performe some tasks also like disabling all start up servieces using save mode utility, scanning system, fress os installation etc...
but not got any sollution .
then i came to know that this is problem related to bios updation.
when i started searching bios update i havent found it any where not even on award website.
bios info.
type - phoenix-award
date - july 23, 2003
id - 07/23/2003-i845G-ITE8712-6A694X3LC-OO-NONE
VER. - 6.00 PG
OEM - INTEL845GL/GV,-007-6.00PG
CHIPSET - INTEL 2560 REV 3
MOTHERBOARD - i845G-ITE8712
PROCESSOR - CELERON 2GHz
I WILL BE VERY THANKFULL TO YOU ALL .....
PLZ SOLVE THIS PROBLEM.
REGARDS
ABHAY...........
    President:
  • 414 Answers
Probably ur system's software is corrupted or ram is faulty..proceed with the following step(s) only if u r a professional..
1)a) open it/them, rub itz teeth gently with a eraser, toremove any
oxide and or carbon formed..resit them again into theslot(s)..
b) replace the ram with a standby n see..
2)reinstall os..
3)alsocheck for defective capacitors(esp above 1000mfd) & mosfets &the circuitry around the South Bridge on the main/mother board..
the above often take place with some error message(s)/blue screen..
butif there's no such displaying, esp if hangs/stops/power off duringinstallation..
[plz give priority to step1(b), it may b the sole cause]..
there are also exceptions, where it is found that any hardware component on the system is loose or incompatible (see addon cards, the ram(s), the hdd, all data cables n power cords), may b dusty, cpu overheating etc..
when u get into the os, plz do the following:
hv a licensed and UPDATED antivirus installed (i prefer avg/kaspersky, remember, without updation a full version antivirus is useless)..
download, install n run microsoft kb890830..http://www.microsoft.com/downloads/details.aspx?FamilyId=AD724AE0-E72D-4F54-9AB3-75B8EB148356&displaylang=en..
download n run Startup Control Panel..http://download.cnet.com/Startup-Control-Panel/3000-2094_4-10039330.html..'remove all the unnecessarystartup items from here..(if u can't find what to remove, post me/us inur comment with all the items listed in each n every tabs herein)..
remove all unnecessary software from add/remove programs..
download, install n run 'Advanced System Care Pro'..http://download.cnet.com/Advanced-SystemCare-Pro/3000-2086_4-10399324.html..
contact ur system admin/vendor....
Posted on Nov 12, 2009
  • 37 Answers
Actually, I think you may have a memory problem. Those look like memory addresses that you listed. Did you find out whether your motherboard requires memory to be installed in pairs or can you just install one chip with 512 MB? Did you check the speed that motherboard can handle as well as the maximum amount of RAM it can handle? Did you take your old RAM chip to the store with you when you bought new RAM? Those questions are always good recommendations. RAM comes in different amounts and different "speeds". If you purchased a speed that your motherboard cannot handle, then the BIOS chip on that motherboard cannot handle it either. I have the 845GV motherboard myself in one of my PCs. The motherboard has Intel chipsets but mine is made by a company call EliteGroup. According to my motherboard manual the motherboard can only handle "unbuffered DDR SDRAM with speeds of 266 or 333. Sometimes it is easy to find the speed printed on your old RAM chip, but other times you have to read in the manual. A good place to find online manuals is www.motherboards.org. Also there is a possibility, although rare, that you purchased some bad RAM chips. I have purchased bad RAM before. Double check your specifications to make sure that you have the correct type of RAM. If you do have the correct RAM, I would put your old RAM back in the PC and boot it up. When everything boots correctly (if you have changed a lot of things, then in the BIOS find the option to load "factory settings" or "default options" and load them, then you may or may not need to reinstall Windows), power the computer and remove the old RAM. Take the old RAM and the new RAM back to the store purchased from and tell them the RAM doesn't work in your PC and that you wish to exchange it. If you purchased the RAM online then call the company and tell them that you need to exchange the RAM, that it does not work properly in you computer. When you install good, correct RAM, then you should not have any errors. If you had no problems before installing the RAM, then always double check what you changed before doing other things. Please update on your status as you go along.
I wish to know if DDR2 RAM can be used on the motherboard. The vendor has supplied me with one DDR1 RAM 512MB DDR400 CL2.5. I am having 2 pieces DDR1 RAM from my old machine 128MB EACH. I wish to know if...
No you cannot use it .... *********** board will not support DDR2.... but if have the slot for both DDR1 then you can use DDR1.. but i will suggest you to use Ram for same memory .. But you can use 521 & 128 together , no problem.
thanks for rating Good luck
Jan 14, 2011 | Asrock 939SLI32-eSATA2 Motherboard
Thankx for ur reply this is my ram config. i think it is compatible to each other. 512 MB DDR PC3200 128 MB DDR PC2700 Maximum Memory Capacity: 2097152 MB Currently Installed Memory: 640 MB Available...
I am glad to hear that your PC is running well. If you need any help again in the future we will be here. This is something we like to do, so there no having to tolerate at all. Only us helping you to understand your problem.
Nov 12, 2009 | Baby Gear
I conect 2 x 512 mb 400 the memory still 512
check in bios may be some memory still shared for graphic.
May 24, 2009 | Computers & Internet
RAM increment
yes just pur chase 1 128 MB or 512 MB or 256 MB ram but check first *********** bord ram module
check your old 64 Mb ram if it has 1 notch it is ddr1 or ddr2 if it has 2 notch it iks sdram
then pur chase from shop.
then fix it on secodn slot
Apr 24, 2009 | Compaq Presario 5000 PC Desktop
Want to upgrade ram pc2700 128mb to 512 mb , so i purchased a 512mb ddr1 400mz ram and put it in parallel port but my computer does not boot so i remove the 512 mb ram but problem was as it is now what...
first you check that your ram version.... i means it is compatible with your motherboard...if still prob remains then remove your all ram insert 128 mb ram then restart the system....... upgrade ram should fallow frequency of 512 mb RAM are same as 128 mb ram freqency........if mismatch is occured then it did nt wrked correctly...
Mar 30, 2009 | Computers & Internet
Old computer ram upgrade without manual
564 mhz means it is a Pentium 3 or equivalent. This also means that the motherboard does not support DDR2 RAM which is exclusively for Socket 775 and Pentium 4 chipsets. Pentium 3 usually support SD-RAM, also but very rarely DDR1 RAM. Sorry but DDR2 will not work in your PC.
Mar 02, 2009 | Intel Motherboard
RAM cuantity
The motherboard you mentioned supports DDR1 RAM.
For windows xp and general application 512 MB is enough.
But if you use memory intensive applications like image/video editing then you can opt for 1-2 GB RAM.
Nov 24, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
Recommended memory for p4i45gv R5.0
IF UR RAM IS SDRAM THEN U CANT UPGRADE TO DDR BUT IF ITS ON DDR RAM THE U SHOULD B ABLE 2 UP GRADE 2 1GIG OV DDR RAM RUNING AT 400MHZ
Dec 25, 2007 | Asrock P4I45GV R5 Motherboard
Computers & Internet Logo
219 people viewed this question
David Payne
David Payne
