Question about Sony 1GB Memory Stick PRO Duo Memory Card
My memory stick has stopped working, nothing shows up when I insert it into the computer...I need some of the files which are stored on it, do you know how I can fix it?
I have a Memory Stick PRODUO of SONY of 1GB, i have an important data in this, when i insert this into camera , it shows a message" Reinsert Memory Stick- Error shows C:13:01" Please help me. Thanks
Posted on Dec 10, 2009
  • s2003 Dec 02, 2010
    Did you ever find out how to fix this issue? This happened to me the other day after an attempt to force the prostick into the SD slot on a Wii.
  • hydro48 May 16, 2011
    does anyone have an answer? I did the same thing and got he same error. I really need these pictures. Please if you know the answer post thanks
  • Sony Master
  • 32,281 Answers
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive this program may help: -
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
Posted on Nov 12, 2009
How Can I read my Memory Stick Pro Duo MARK 2 on my Computer? MY problem is I cannot read my Memory Stick Pro Duo Mark 2 on my computer but my computer is showing another Removable Disk(F:),which is my...
    • 1 Visit the Sony Support site (see Resources) and download the Sony memory card software. You will need to specify your operating system. Save the file to your desktop.
    • 2 Double-click the downloaded file to launch the installer.
    • 3 Follow the onscreen instructions to install the Sony memory card software. Restart the computer after completion. Once the computer starts back up, it will recognize the Memory Stick Pro Duo when inserted into the computer's memory card reader. You can browse the files using Windows Explorer or the installed x-Pict Story software.
May 31, 2011 | Sony 4GB Memory Stick PRO Duo Memory Card
MY SONY CYBER SHOR DSC-W270. IT SHOWS SYSTEM ERROR WHEN TURNED ON.
The System Error message displays when the files on the recording media have been copied or deleted repeatedly on a computer. Backup the files on your computer, then format the recording media in the camera to resolve this issue.
Formatting the Memory will erase all the data stored in the Memory Stick.
If the error message displays after formatting the Memory Stick, then try using a different Memory Stick media. Once the Memory Stick is inserted, perform manual power reset of the Camera.
To reset the Camera, turn off the Camera and remove the battery pack.
Then, allow the Camera to remain without power for 30 seconds.
Later, re-insert the Battery pack in the Camera to resolve the issue.
Thanks for using FixYa.
Jan 10, 2011 | Sony Cyber-shot DSC-W270 Digital Camera
My dsc-w80 keeps saving all of my pics to the internal memory
Set camera on playback mode, you will see any saved picture in internal memory. Insert memory card and lcd screen will show you either blue screen if memory card has no picture files or will show you picture in memory card. That means memory card is intact with camera and ready to store fresh picture.
Set camera to camera mode and take few fresh pictures and check them in playback mode.
Let me know if you have additional question.
Thanks.
Jul 20, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
How do you store thing on to the memory stick for a samsung s5230
to store data on a memory stick, use instruction below.
Insert memory stick either in phone or in a card reader,
For phone, install phone software, and connect cable to both phone and PC,
Go to my computer, open memory card file,
Copy file from source and paste inside the memory stick file.
Eject when you finish transferring file.
Using Memory stick , you can use the same process.
Take care
Jul 02, 2010 | Samsung SGH-S5230 Cell Phone
1GB Memory Stick PRO Duo Memory Card: i have a memory stick pro duo card .... but now we...
Hi sir
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • May 17, 2010 | SanDisk 1GB Memory Stick PRO Duo Memory...
    How do i use a memory stick
    How to use a memory stick or USB
    I will assume you are using windows. as you can see your USB memory stick has a metal connector with a plastic insert; that was made to fit in the connector on the back or sides of computers. the computer has several places to insert the memory but this device will fit properly in just the correct jack and it will go in in just one position, you can not turn it over and insert it.
    after you do that windows will install the driver (software) for the device and it is going to open a window asking what do you want to do at this point you can click on any option but if you want to see your files or save files, click on the folder that says view files.
    that opens the device, if it is brand new there would be no files. At that point you can drag all kinds of files in to the memory and store them.
    the other option after you insert the memory, close the asking window and click on my computer from here you can see your memory stick, click on it and it will open, drag files to it or out of it in to your computer.
    when you are creating documents or files you can save them in to your memory stick. Just click on file--save as--computer--memory stick (name or model)--save or ok.
    when you are ready to disconnect your memory stick go to the clock area on the right corner, there is an icon of a connector with a green check mark click on that and then stop device, select your memory stick-stop, wait for confirmation and then you can unplug it >>>>failing to do this may damage your files or memory stick<<<<<<
    if it works for you don't forget to rate me
    thx
    Apr 28, 2010 | Gateway Essential 400 PC Desktop
    Problems loading image files onto memory stick pro duo
    You probably emptied the memory stick in the download, if the OS sees the memory stick as a removable device then a simple drag and drop will put a copy of the files back on the stick. If MS not see by OS then you cannot get them back on. Trick is that the operating system must see the memory stick as a device to exchange data. Some programs allow retrevial but do not make provision for storing.
    Jan 07, 2009 | Gateway 507GR PC Desktop
    Sony handy cam memory stick pro duo
    If the mem. stick doesn't work in anything else then your memory stick may be physically damaged. Just open the card in any computer using a card reader and format it using the FAT file system.
    Jul 26, 2008 | Sony PlayStation Portable (PSP) Console
    PSP videos
    The problem can be the memory stick or within the PSP system itself. Try inserting another memory stick into the non functioning psp. If the problem still persist that means the memory card reader cannot read the files try formatting the whole psp system. If that doesn't work you will need to get it repaired take to an electronics store that sells video game systems preferably game stop they will swap out the memory card reader
    Apr 28, 2008 | Sony PlayStation Portable (PSP) Console
    Memory stick duo not showing pictures
    It may be that you actually have the pictures stored on the camera's onboard memory and you may have to plug the camera in directly to access the pictures. Or Sony may have a strange way of accessing the files on the device (they have done the same with their MP3 players), so you may be limited to using their software to get the pictures off the camera (or memory stick).
    Sep 06, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
    Sony 1GB Memory Stick PRO Duo Memory Card Logo
    2,834 people viewed this question
    Top Sony Electronics - Others Experts
    Sandy Moore
    Sandy Moore
     Grubhead
    Grubhead
    Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
