Question about Abit IC7 Motherboard
No sound and i have no disc - Abit IC7 Motherboard
    President:
  • 414 Answers
Though itz unclear to me of wat os u r using..
assuming that u r using win xp pro sp2..n directx installed..
check if Audio device is enabled in bios..
howevr, download microsoft kb888111update n install it..u need to re-install or update the devicedriver (may b manually)..logon to internet n seek the package/audiodriver..along wid the company, there will b a list of such site ndriver downloadlinks if u search by the model name on a search engine (like google)..
http://www.nodevice.com/driver/IC7/get40801.html
downloadthem onto a location; if the driver is in a zip format, unzip it,if itzin .exe form, just run it; if done manuallyit'll ask for the correct driver and location; relocate the path and a.inf file (wat it'll ask for)....goto the device manager n verify, ifinstalled properly..!!
also download n install "k-lite mega codec pack"....
ifnot fixed try using a standby pci snd card (in such case it'll b aconfirmed case of ur system board is likely to b defective)..
but always better to consult ur system admin/vendor....
Posted on Nov 12, 2009
No sound and keeps skipping
Does this happen with any disc or a disc? Playing a contaminated disc can cause heads to get dirty causing above results. Make sure discs are clean when inserted. (Young children can handle discs improperly and get fingerprints and other stuff on discs, resulting in dirty DVD heads) Purchase and use a DVD head cleaning disc. May have to use it a few times initially. Then make sure disc is clean before inserting. Wiping gently with paper towel dampened with water or vodka generally works to remove contaminants. Wipe only the bottom, not the top until it appears shiny.
Feb 16, 2016 | Sony BDP-S300 Blu-Ray Disc Player
No picture, no sound
see the troubleshooting index:God bless you
No sound
1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
2. Check if the TV, DVD player and Amplifier are connected properly.
3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Sep 23, 2013 | LG 32cs460 32" Inch Widescreen 720p 60hz...
BD30 makes a grinding sound when loading discs,
in most cases its a bad disc but if all disc are doing it then your glide tray needs to be re alined
Jul 04, 2010 | Panasonic DMP-BD30K Blu-Ray Player
I want sound driver how to download plz guide me
If you have driver disc,insert the disc in the dvd R-W and follow the instructions given by driver disc.When the disc starts the installation click on the sound driver before installing.And then follow the instruvtions.
Apr 04, 2010 | Intel Sound Blaster Live
Disc drive not reading
Update the O/S,
Type DXDIAG in the run box, to check your audio.
Device manager, disc drive properties, roll back or update the driver, let it search the internet for it.
Same for sound, device manager, sound,video and audio devices properteis, roll back or search for updated drivers, let it run.
Reduce hardware acceleration poss too for sound.
or poss drive failure.
should be good.
Hope this helps
Ric.
Apr 18, 2009 | ASUS Z92M Notebook
Denon DCM 370 5 disc changer does not show all discs!
Probably drive belt that rotates the carosel inside is not lining up properly,or the belt that moves the laser mech into position,sounds like its just not lining up properly
Jan 04, 2009 | Denon DCM-370 5-Disc CD Changer
I can´t find the bus driver for the sound card
You have to install the PCI drivers and motherboard chipset drivers before it will properly recognise the card. Find the driver disc that came with the computer or the motherboard and install all of the drivers for the system. If you don't have the disc, you can get the drivers from the computer or motherboard manufacturer. You should also go to the sound card manufacturers site and get updated drivers for the card. If it is an integrated sound card, the drivers will be on the same disc or site that the system drivers are on.
Cheers.
Dec 21, 2008 | Computers & Internet
No sound to back channel speakers
The disc menu and sometimes the box will say if has 7.1 sound. Look under the Audio options on the disc menu.
Only your receiver will convert 5.1 sound to 7.1 if it can do so. The disc will either have the option for 7.1 or not.
Jun 12, 2017 | Marantz SR4002
Abit IC7 Motherboard Logo
136 people viewed this question
Top Abit Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
