Question about Kodak EasyShare C763 Digital Camera
When i try to take a picture its a black screen, no matter what i turn the dail to its always black. How do i fix that?
    Genius:
  • Kodak Master
  • 1,099 Answers
Are the pics also black?
Repair.
If OoW. 48,44 pounds.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Nov 12, 2009
Sony KPR-53EXR15 pictures fades in and out
Sounds like possibly it could be connection related between any AV/Cable ports. Worst case would be the capacitors of the motherboard leaking. It's possible to fix anything. Just make sure you have the knowledge and the right equipment.
Mar 31, 2017 | Televison & Video
Pictures turn out too bright or too dark...
Go into the menu and find "reset"...follow the on-screen instructions.
Feb 05, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
The top of my picture is cut off.
Change the video output to wide screen
Oct 15, 2009 | Sony Televison & Video
Screen is black on playback & picture mode
Have you tried taking pictures when the screen is black? Do the pictures also come out black? If so, try putting it in any mode other than auto and turning off the flash (don't want to blind yourself for the next step). Next look down the front of the lens and take a picture. You should see a little flicker in the center of the lens as the shutter opens and closes. If you see this flicker, and you're still getting black pictures, then you likely have again encountered failure of the CCD. Canon will fix this again for you for free. See the following:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
But if no flicker or movement is seen down the center of the lens when you took the picture, then you likely have a stuck shutter. Canon will not fix this for free. But no matter, there are a couple simple fixes for this that don't require opening the camera: http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 21, 2009 | Canon PowerShot A75 Digital Camera
BLACKNESS?????
It sounds like you have lcd sensor that is gone out. You can either send it to Nikon to have it fixed, if its under warranty or you can send it to the camera doctor
http://www.cameradr.com/
He is a friend of mine and can fix it faster than Nikon.
Jan 02, 2009 | Nikon Coolpix S51c Digital Camera
Panasonic PV-L453..... Black screen
If it is not a setting problems, and if the black picture is only on LCD and not on picture files, then it is a problem with the LCD. Probably just the ribbon cable not well inserted into the connector.
Camera must be taken apart to fix this problem. Better to have the job done by a technician at a camera repair shop.
Aug 12, 2008 | Panasonic Palmcorder PV-L452 Camcorder
Black screen when trying to take pictures
i just got a new camera the dimagne x50
and i brang it out today and it was working fine it didnt drop or anything
i took a picture then turned it off then i turned it on agian and when it was on the camera format the light kept on blinking yellow for the longest time and wouldnt let me take a picture so i tried the video format and it worked so im just wondering why the video format is working and not the camera ?
has this happened to you? is there any way of fixing it?
Apr 02, 2008 | Kodak EasyShare C643 Digital Camera
Programme dial again
yes thats your problem,the reason it wont unscrew is because of things caught inside ie coins gunk you will have to take out machine turn on side,there are two sometime four screws at front of machine where black dail is remove these,when machine is on its side you can acess pump from underneath,there is a black rubber hose which goes from drum to pump which is held on with a circlip remove this at pump end you will need a vicegrip,remove all gunk coins ect, refit all back to machine ,,problem solved......the reason dail was turning was because it was looking for progam to release water which it couldnt because of blockage,after tou unblock you will find that black srew on cover on front can be removed(always better to check for blockages every few weeks hopes this helps
Dec 18, 2007 | Hotpoint BWM12 Front Load Washer
View is Black & White "Negative"
There is a Black Dail by the Eyepiece, try unjusting that, and should do you.
Happy Holidays
Bobby
Dec 08, 2007 | Konica Minolta DiMAGE Z10 Digital Camera
Picture Freezes and Black Screens
Reset by unplugging the TV for 2 minutes and the going from there. Maybe a bad digital board since thats the only way images can et frozen on a TV.
Mar 10, 2007 | iLO 3200 32 in. LCD Television
Kodak EasyShare C763 Digital Camera Logo
106 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
