Question about Garden
Can't get cover off of my fource wipper snipper. the cord will not go back in , can you help me please Ray
evwood
  • 50 Answers
SOURCE: pretensioning starter cord on ryobi whipper snipper.
This was answered in a previous solution
Posted on Jan 03, 2009
  • 17 Answers
SOURCE: cord stayes out motor not running
Take it back to place of purchace.
We get these all the time if its the cheap bent sharft with starter between shaft and motor. the easy start spring gets jammed and needs replacing.
Posted on Jan 08, 2009
SOURCE: my stil wipper snipper starts and runs but only on
Most Stihl's are the same...Sounds like you need to adjust your mixture screws on the carby. you will need a small flat blade screwdriver (usually these are supplied with the wipper snipper from new and they have a little arrow on the top), H is for the High speed mixture screw, L is for the Low speed mixture screw. Turn the screws clockwise in until they seat (do NOT tighten!!) then turn them anti-clockwise the recommended amounts of turn on the cover around the holes. Careful not to lean the mixture out too much, but if it is the newer type they have a restictor on the High Speed that stops it at 3/4 of a turn. start it up and hopefully it will fix your problem, if not you will have to take it to a professional. Further info majority of STIHL high and low mixture setting are fine tuned via the respective rev settings , you'll have find out the particular setting from your STIHL dealer(sorry)
Posted on Nov 21, 2010
rycgl
  • 1545 Answers
SOURCE: how to set air fuel 323l wipper snipper runs for 2
Here are 2 links for adjusting the two popular brands of diaphragm carburetors:
http://www.zamacarb.com/tipspage.html
http://tech.flygsw.org/walbro_tuneup.htm
Posted on Dec 12, 2010
  • 640 Answers
SOURCE: My wipper snipper has no spark, Ihave bridged out
The switch is a kill switch that grounds out the spark, at least that is how mine is. So assuming you have it correct, and new plug, that leaves the ignition coil. Only component left.
Posted on Sep 18, 2011
Manual for wipper snipper tu26pfd-211
see a dealer locally , perhaps they can find one for you
May 20, 2018 | Garden
Manual Ryobi model RCT3160E wipper snipper
makers website. and download
Oct 21, 2014 | Garden
I want to know how to install a blade on my husqvarna wipper snipper 128ldx trimmer
The only blade acceptable on this trimmer is a grass blade. Part number is 578 44 40-01
Jun 23, 2014 | Husqvarna 28cc Gas Line Trimmer
Refrigerator overflows from evaporator pan
you have a blocked drain from the rear of your refriderator to the motor drip tray
the heat from the motor evapourates the water,
get some wipper snipper cord and push though the rear drain located inside
the refridgerator behind the plastic captulator and it will open the bockage
Dec 27, 2011 | Refrigerators
I Have a stihl fs 38 wipper snipper. I am having trouble setting the carb jets. Can you help me?
Even touching carb jets is the very last resort, if u absolutely have too, turn them closed, b mindful do NOT over turn. Turn jet 1/4 turn and if needed 2nd 1/4 turn. no more than 1/2 turn.
Sep 02, 2011 | Garden
My stil wipper snipper starts and runs but only on low revs.it will not rev up
Nov 21, 2010 | Garden
How to fit whipper snipper line
Hold the snipper upside down so the petrol leaks onto the kitchen floor. Take 6 metres of line and untangle it eventually. Stick it through the two holes and wind the cord in opposite directions so it jams together and tangles. Stick the unit head back together with two feet of line sticking out each side. Start the trimmer and jump backwards as the line rips itself to pieces. Use it on weeds until line breaks within 20 seconds. Slam the end of the trimmer into the concrete and shout **** fuckey **** ****. Then tear off the head cover and start again. I have done this for years and it never fails. Hope this helps.
Oct 18, 2008 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
