Question about Cameras
My cannon mvx200i won't accept the tapes any more. There is a red symbol of a tape flashing on the screen. it was working fine, everything else seemed to be working fine, I took one tape out and from there it wouldn't accept the tapes. What is the problem?
  • 4,472 Answers
First off how long have you owned the camera? I would suggest you contact canon and have the camera serviced. There is most likely a broken/defective part in the camera. Follow this link to find the nearest service center. I am assuming you are located in europe.
http://www.canon-europe.com/Support/Consumer_Products/services_locator/index.aspx
Thank you,
Lee
Posted on Nov 12, 2009
Red light blinking won't accept tape
If a tape "hung" up and it won't accept one you have a loading issue.
The unit may use a belt to drive the tray or a geared mechanism.
In any case someone needs to open the unit up to "see" what is happening. Most of these a tape can be inserted with power off and manually cycled into the unit to see the issue---we usually use a old cassette with the tape inside removed to avoid issues.
If you cannot do that consider looking for a shop who will (some no longer work on this type of equipment.)
Dec 05, 2012 | JVC BR-DV3000U DV/Mini DV VCR
Canon zr700 won't play tape
That is the pinch roller. If it does not press the tape against the capstan, then the tape will not pass the read/write heads. Replace it.
Jun 25, 2017 | Canon ZR700 Mini DV Digital Camcorder
Tape cannot be removed
However, any cameras in which you can insert a video tape (camcorders,...) will NOT work with coriander. These cameras record compressed DV video on the tape, while the IIDC specify uncompressed, on-the-fly video flows. If you wish to use a camcorder you should have a look at Kino instead.
Jun 23, 2010 | Canon MVX200i Mini DV Digital Camcorder
Canon MVX200i Mini DV Digital Camcorder: Remove the cassette
I got the same problem, does nobody has a solution. Please help!!
Eduard Mendlik
Jan 01, 2010 | Canon MVX200i Mini DV Digital Camcorder
PIXMA IP4200 won't 'accept' Pigment black--vent blocked?
if you still have the old tank load it in. an than try the new one again. or tank could be bad.
Mar 27, 2017 | Cannon Canon i960 Photo Printer
Flashing red symbol like a bowl crossed out
it means you have no back up battery installed to save time/date info. I know on the GL2 if you open the LCD screen there is another small plastic tab you can open and insert a relatively small battery. Do it and the icon will disappear. Otherwise its no big deal. If you dont need time/date stamps on your tapes then there is no need to install the battery unless you are just annoyed.
Feb 22, 2008 | Canon GL2 Mini DV Digital Camcorder
Deck will not accept DV tape
most likely problem is a defective cassette housing. I've replaced about a dozen of these in AG-DV2500s.
Jan 12, 2008 | Panasonic AG-DV2500 DV/Mini DV VCR
C-31:21 code eror
C:31:21Winding S reel fault when counting the rest of tape. Load the tape again, and perform operations from the beginning
The tape may be faulty
Oct 26, 2007 | Sony Handycam DCR-PC101E Mini DV Digital...
Canon mv700 not loading tape
if you hear the cylinder drum running to fast try take out the connection of the drum at the circuit and back it again...try this in you can open your camera....
Aug 08, 2007 | Canon MV700 Mini DV Digital Camcorder
Elura 60
Hi, When you say you're "using a tape for a while", can you define "while"? The thing about these little cameras is that they don't like to re-use DV tapes. If you are recording over tapes that have previously been recorded on, then your camera could be fussy about that. You can clean the heads, but if the tape is dirty, then it will transfer that dirt back to the heads and youp;ll end up in the same position. The problem is, that the heads will wear out if you clean them to often. In the long run, it's best to use new, clean tapes. And when you are using the tape cleaner, make sure you are following the directions very carefully. NewMediaMan
Jan 14, 2007 | Canon Elura 60 Mini DV Digital Camcorder
Cameras Logo
15 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
