Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Cant get back off to remove paper jam on our copier,printerMFC-260C Brother
  • 677 Answers
I know it is hard to remove, but you push down on the bottom and lift a little up, and pull , it should help.
Try not to break it off. Keep jiggling it and it will help.
Good Luck.
Posted on Nov 12, 2009
I cant fix the paper jam problem. every time i take the paper jam out it jams again
I have had paper jams in five different places on this machine. It has jammed at the pickup point from the tray, in which case you have to remove the paper tray and pull the jammed paper out. It has jammed at the manual paper feed tray, in which case you just have to pull the jammed paper out of the feed rollers. It has jammed at the toner/drum, in which case you have to open the front cover and pull the toner cartridge out to remove the jam. It has jammed in the back of the machine where the paper feeds through to the output tray, in which case you have to open the small back panel and remove the paper. And it has jammed in the output rollers, in which case you have to reach inside the output tray and remove the paper. Then once the jam is cleared there are times when the machine has to be unplugged for up to 8 hours to reset before it will function properly.
Aug 16, 2010 | Brother MFC 8840D All-In-One Laser Printer
Paper Jam whilst doing a multi page scan
The rollers that pull the paper through could need a cleaning. With general usage these parts do get worn down. By having your printer cleaned by certified technician it would resolve this problem.
May 28, 2010 | Brother MFC-260C All-In-One InkJet Printer
Paper jam
you should take it to your local service agent as if you remove the cover your self then you will loose you warranty, also if the paper jam is in the paper feed then use a lamanated peace of cardbored
Nov 13, 2009 | Brother Multi-Function Center MFC-240C...
Printer papper jam cant see any papper mfc-240c
Did you remove the rear cover and check for paper there? If it still shows a jam and there's absolutely no paper inside the printer, you may have to shut it off (or unplug it if it won't turn off), wait a few seconds, and turn it back on to clear the jam detection.
Sep 05, 2009 | Brother MFC 240C All-In-One InkJet Printer
Cant access jammed paper in Brother DCP-150C
do you see a snap-in lock at the back or the lower part of your printer? if yes, try clicking it and you might easily check and remove the papers left inside.
Oct 19, 2008 | Brother DCP 115C All-In-One InkJet Printer
Brother 2040 paper light .. continuous red
If you removed a piece. But more remains it must also be removed. Look closely along the paper path for something that will release to provide access to the path.
May 03, 2017 | Brother HL-2040 Laser Printer
Paper Jam
Open all the doors and remove any removable assemblies. Use a flashlight and some compressed air to try to locate the paper shard.
Jan 15, 2008 | Brother Multi-Function Center MFC-240C...
Paper jam on brother HL5140
You will have to take the printer apart if it's stuck in the fuser on the back, if you can grab a small part of the paper turn printer on while lightly pulling on it in the direction of the paper path, if not, Carefully take the cover off and remove it
hope this help
Good luck
Jan 02, 2008 | Brother HL-2040 Laser Printer
Brother fax 2820
Out of the lower paper tray when you go to print? Try this, remove the cassette tray and use a water dampened cloth and clean the gray paper pickup roller off. A lot of times this has paper fiber build up that causes the paper not to feed. The printer has a certain timing pattern for when paper should reach a certain sensor, and if it doesn't, then a jam error will occur.
Jul 18, 2007 | Brother IntelliFax-2820 Laser Fax
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
63 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
