Question about KitchenAid KESC307 Electric Kitchen Range
I have a Kitch Aid range model KESC307HBS4. The infinite switch for the LF burner went bad. The K-A part number is 9751758. The factory replacement part is a Whirlpool 8203536. What I need is to know is which wires to connect to the correct connection.
3 Suggested Answers
  • 184 Answers
SOURCE: need wiring solution for replacement part
NORMALLY, THERE ARE 5 WIRES TO A STANDARD SWITCH. L1 AND L2 ARE THE POWER GOING TO THE SWITCH, NORMALLY RED AND BLACK. LOOK AT ANOTHER SWITCH ON THE RANGE TO DETERMINE WHICH IS WHICH.
THE H1 AND H2 ARE THE OUTPUTS ( ARE B1 AND B2 ON SOME SWITCHES). THESE ARE THE OUPUTS TO THE ELEMENT. THEY ARE INTERCHANGEABLE. THE "P" ON THE SWITCH IS THE PILOT AND GOES TO THE INDICATOR LAMP THAT TELLS WHEN THE SWITCH IS ON.
Posted on Mar 31, 2008
Ok....Just replaced the Left Front "dual burner" switch on my Kitchenaid Supurba.
Original switch symptom:
Burner was stuck on all the time. We had to switch the circuit off in the main breaker box in the basement.
New switch problem:
The new replacement switch did not work properly. The element would come on and would never cycle on and off. Thus, the net result was if you turn the burner on, it was on "high". It didn't matter where put the heat setting at...It's on high for both the inner element and the larger outer element.
I ended up taking the old switch apart and found that one of the contacts was mis-aligned and wedged itself in the "closed" position. I un-wedged the mis-aligned contact and bent it back into alignment. I took out the new switch and put the old one back in. It works perfectly.
Meanwhile, I had to figure out why the new switch was not working. The new switch comes with re-wiring instructions because it is not an exact replacement as the old switch. There is a chart that tells you what wires go to which prongs on the new switch. The new switch also includes a "jumper wire" that must be installed. Here's where I went wrong. The instructions say to jump S1 to P1 (which I did). But, I did not route it exactly as the picture shows and the brass crimp end actually hits against another unused connector. So be careful when routing the jumper wire.
Old Switch Number: 9751758
New Switch Number: 8203536 (Made by FSP Appliance Care Products - A Whirlpool Corporation)
Now for the wiring:
Description Wire Color Old Switch New Switch
& designation Terminal # Terminal #
L1 Black (RL1) 2 P1
H1 Red 3 4
H2 Orange (LFA) 4 4A
P Dark Red 5 S2
N or L2b Brown (LFN) N 2
N or L2b Red (RL2) N P2
On the new switch, use the supplied jumper wire to jump S1 to P1 as instructed.
Yes, on the old switch, 2 wires connect to a common connector (the Brown LFN & Red RL2).
Unfortunatley, I did not document the red wire (LF3)...Sorry....
Hope this helps.....
Posted on Apr 05, 2009
My kenmore flat top stove front burner quit working. I replaced the 9" element and it still will not work. Any suggestions.
your burner switch is wattage rated ( as all burners are ) you want to check H1 and H2 for voltage 220vac and replace it with the correct switch Rf,Rr Lf Lr some shafts on controls are colour codded
refer to your model number and proper switch and element location
Cheers
Dec 11, 2013 | Kitchen Ranges
Can any one help me replace the infinite switch for the warming drawer on my GE gas range JGB920bec2bb Spectra XL44. Switch part number wb24k10006. Thanks. I think I need to remove the burners and top...
Hello & Welcome to FixYa
Please view this video to follow the step by step instructions in order to replace the infinite switch in your GE Gas range:
Please get back to me if you have any other questions.
Kevin
Jun 15, 2011 | Kitchen Ranges
Lg flat surface stove burner
Replace your infinite switch for this (your lf burner switch). Call a parts supplier with your model number, try and get an exact switch, not a generic switch. Do not replace the switch without unpluggin your range first. Good Luck, Appliance Specialists
Jan 28, 2010 | Kitchen Ranges
I need the part number for the left rear burner switch on model Kitchenaid KERC607HWW8
The part number for the infinite switch that controls the left rear burner on this model range is 9751364. This is a 1500W rated switch that lists for about $33 at appliancepartspros.com. I hope this helps you.
Nov 23, 2009 | KitchenAid KERC607 Electric Kitchen Range
Surface burner won't turn off when turning control knob to off.
your infinite switch on the control board is bad
with the exact model number
and which burner i can send you the part numner and how to get to it
Oct 24, 2009 | Kenmore 92022 / 92024 / 92025 / 92029...
GE electric stove problems, our stove has 3 small burners and one big burner. When we use the big burner at medium heat it does fine then all of a sudden it starts glowing bright red and burns whatever is...
Replace the infinite heat control switch for that burner. (the burner switch that you turn with the knob to select the temp setting) If you list a full model number (usually behind the lower drawer panel on the frame of the range) I can look up the part number for you. It is not a very difficult repair.
Oct 11, 2009 | Kenmore 95592 / 95594 / 95595 / 95599...
Wiring hookup for a replacement part
hopefull yyou havent disconnect old switch yet. whirpool and kit aid are same Co. same parts used. assuming the correct part was sent for the corrrect burner. diffrerent element will require different rated swties(ie. small , large, dual and so forth.), the indivudal switches are labeled, on the swithc itself ( L1,L2,H1 H2, P1 andso forth, so although the switches looke differnet they should stil have the same lettered terminal to plug into .
Mar 15, 2008 | KitchenAid KESC307 Electric Kitchen Range
Need wiring solution for replacement part
New switch problem:
Now for the wiring:
L1 Black (RL1) 2 P1
H1 Red 3 4
P Dark Red 5 S2
KitchenAid KESC307 Electric Kitchen Range Logo
181 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
