Question about Kenwood KDC-MP538U Car CD/ MP3 Player
How do you reset due to protect screen on - Kenwood KDC-MP538U Car CD/ MP3 Player
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Kenwood Master
  • 2,226 Answers
Try disconnecting power to the radio. either unplug the wire harness or disconnect the battery.
Posted on Nov 12, 2009
Belt lube flasing on screen the tread mill not working what to do
1) RESET the machine with the reset button.
2) LUBE the machine , this happens to due the lack of maintenance according with the instruction manual, this produce shut down for to protect the electronic system.
see the video and proceed with common sense. Try to RUN the software calibration for easy diagnose, troubleshooting and fix it.
God bless you
Sep 06, 2012 | Exercise & Fitness
How do I enter the Test Mode on my RISO 790 duplicator?
Do you mean into the unprotected mode?, if so
Turning OFF Protect mode in a Riso MZ 790u (and other models I'm sure).
1. Go to Admin Tab on the main console screen and scroll to the "Protect" button.
2. Select (press) the "Protect" button on the screen; printer will go through a reset function (takes about 3-5 seconds).
3. After printer is finished "resetting", pull out one of the master disposal boxes (doesn't matter which one).
4. Press the "Protect" button again.
5. the screen should say "Protect = Off"
6. You're done and your machine should be un-locked now.
May 11, 2011 | Office Equipment & Supplies
Can't record due to screen flashing "Protection"
i would have thought that the setting might have been change on a accident you should take it to a shop and ask them!
Apr 13, 2009 | Samsung SC-D103 Mini DV Digital Camcorder
Protected card flashes on my screen and I can't take a picture
Take out SD memory card. Move switch to opposite position (unlock). Try in camera.
Mar 17, 2009 | Fuji FinePix S2000hd Digital Camera
How to reset my epson stylus dx5050 printer
If your Epson printer needs resetting you can download the latest software Version of the SSC Service Utility (V4.3) from this link.
Install it and run it, click on configuration, select your printer from both lists ('x' is replaced by a number), close the program with the red cross. The program will run in your task bar, click your right mouse button on the icon for a menu. You can use the appropriate utility for your needs, if your printer needs maintenance due to ink pad being full, select Protection Counter and Reset Protection Counter. If your printer has locked out because you ignored the warnings and continued printing, first select Protection Counter and Clear Counter Overflow, then select Extras and Soft Reset, wait 5 minutes, then select Protection Counter and Reset Protection Counter.
Sep 23, 2008 | Office Equipment & Supplies
Touch screen not responding correctly
The Axim touch screen is extremely sensitive to the placement of the protecting plastic sheet. Check that the the plastic sheet is oriented correctly - the small bended corners must bend downwards. If that wasn't the problem then remove the protection sheet and pick gently directly on the screen with the stylus to see if you get a response. Most often this is due to a problem with the screen protecting plastic sheet.
Aug 08, 2008 | Dell Axim X51v Pocket PC
PROTECTIVE SCREEN
I need to buy protective and projection screens for my 65" hitachi hdtv due to tare in both sreens done by maintenance people.
Mar 26, 2008 | Hitachi 65S500 65" HDTV-Ready Rear...
Display screen says protected
By your description it looks like an internal protection has tripped. The reset will not work if the unit is fried. Did this happen when you were pushing the unit really hard or distorting it? You may have to have it repaired, or replace it. Repairs can sometimes take a couple of months so be wary of this.
Aug 16, 2007 | Samsung MM-DS80 System
Protection displayed on screen
See my post "HT-DB120 - PROTECTION due to shorted output stage "
Nov 08, 2005 | Samsung HT-DB120 System
"Memory card is protected"
This error message indicates that the memory card is locked. The switch on the memory card is in the write-protect position. Reset the switch as shown on the camera screen.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Kenwood KDC-MP538U Car CD/ MP3 Player Logo
133 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
