Question about Sony Electronics - Others
Removeable Disk Not Recognised. I have my USB labelled SONY USB 2.0 I GB. once I plug it on my computer never recognised. So am asking you to get better solutions, Regards, charles
  • Sony Master
  • 32,281 Answers
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Posted on Nov 12, 2009
Iomage macmini 1TB not recognised in disk utilities
Check cable. Try different cable. Try different ports you connect the Iomega with the computer with en on the Iomega itself.
Dec 17, 2011 | Iomega MiniMax Desktop - Hard drive - 500...
Computer not recognising hard drive. I have even looked in disk management and it's not recognised there either. The hard drive is lighting up when connected so it is working.
HI sineadkirk1
There are several reasons why your hard disk can not be recognised by the computer
1> usb cable problem
2> usb port problem
3> the problem on a computer virus or hard disk
4> computer problem
5> hard disk problem
do the test one by one to ensure that the root cause
thanks&regards
Jan 09, 2011 | Western Digital Elements powered by WD 320...
When i plug in it shows do not recognised
plug it directly do not use cable. if still not recognized try on another computer. If it still fails, replace USB stick
Jan 01, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
ST300003U2 hard drive powers up ok, power light on, message on pc "usb device not recognised " .one of the usb devices has malfunctioned and windows does not recognise it.
Try to plug it in to another PC to see if you get the same message. See if you can run a scan disk on it from Windows to see if it's bad or going bad too.
To be honest, device not recognised is a bad sign. :(
Dec 22, 2010 | Seagate (ST3320820U2-RK) 320 GB USB 2.0...
My external hard drive is not recognised by my computer, although it was recognised in the past.
Hi
Please can you try your external HDD in another PC, to rule out issues with the drive itslef
Please also try plugging the drive into a different USB port on the back of the PC
Please can i ask that you leave feedback and vote if this has been useful
Feb 11, 2010 | Iomega HDD External Desktop (32660) 80 GB...
Does not get recognised by Desk top or Laptop Asks for Installation and drivers
these drive require a usb 2.0 port.
If you are using XP and do not have a 2.0 port in your computer
you may want to get a USB 2.0 pci card this will help.
if you are using vista, it should install the driver automatically.
also do not use it on a hub plug it into a usb port on the motherboard or a powered card.
Apr 14, 2009 | Western Digital Passport WDXML800UE...
Usb not recognised
the connector of you usb port of your unit kinston is need to re_soldering by using a soldering iron.or need to re-heat by hot-air unit.
kira_ryuk@yahoo.com
Jan 11, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
DSC-F505 does not show as a disk drive
dmangadu
It sounds like the drive letter that the camera wants is already assigned to another device. The link below will help you change the drive letter.
http://www.fixya.com/support/r4183994-change_drive_letter_in_windows_xp
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Feb 15, 2008 | Sony Cyber-Shot DSC-F505 Digital Camera
1. click Start, point to Run, type diskmgmt.msc, and then click OK
2. If you see your drive listed without a letter, right click on it and assign it a new drive letter
if that doesn't do the trick.....
if you have any other computers laying around try it on those.
Connect to windows update and download/install all the updates you can.
Also, connect so sony's website and see if there are any drivers needed to make your system read it.
If all else fails check out their user forumns, help topics... post a topic on their forumns.... or just bring it back to the store where you got it with receipt and tell them you want a new one or a different brand
Jan 07, 2008 | Computers & Internet
Freecom 160GB Hard drive not recognised
Drives do fail Nick. Is it powering up [power supply problem?] Plug it in and go to Start/Control Panel/Admin tools/computer management/storage/ removable storage and disk management. See if the disc is recognised there. If it is not, and if the disk is spinning Try putting it into the deep freeze overnight. Plugging in next morning and if it fires up get as much off as possible before it goes down again.
May 20, 2007 | Freecom (24358) 160 GB Network Hard Drive
Electronics - Others Logo
197 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
 Grubhead
Grubhead
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
