Question about RIM BlackBerry Pearl Flip 8220 Cellular Phone
My blackberry pearl 8220 hasa a popup that reads uncaught exception:java.lang.nullpo interexception... i want to reset it but cant get in the menu or even the home screen to get the internet option to allow java, as it says in the previous post
How to fix my blackberry flip 8220 when this appears on the screen Uncaught exception:java.lang.NullPointerException
This is a software problem. It indicates that there is an error on the unit OS. Simply visit the blackberry website download the existing OS on the device install on your PC and connect your device to the PC. Follow the instructions and the unit will be as good as new. Hope this solution has been helpful?
Jun 20, 2011 | RIM BlackBerry Pearl Flip 8220 Cellular...
Java.lang.Nullpo interEception
Do you get this error when you try to browse any website? Or try to install any application on your phone?
It would be great if you can explain your issue more clearly so that i can help you fix it.
Thank you!
May 03, 2011 | RIM BlackBerry Pearl Flip 8220 Cellular...
Apareceu esta mensagem no meu 8220 uncaught exception java.lang.nullp como eu faso para naun apareser mais esta mensagem
Oi,
Receba a Fixya. Fixar o clique de problema no elo abaixo de selecto seu fornecedor e transfere o software.
Download de amora
Se voc? tem perguntas por favor deixa-me saber. Agradece para usar Fixya
Mar 14, 2011 | RIM BlackBerry Pearl Flip 8220 Cellular...
I need your help about my blackberry phone model 8220: Uncaught exception:java.lang.N ullpointer E xception thank you.
hi monreve002 you need to do a hard reset on your phone. You go throught the options to advance settings. security wipe. but please make dure you fo a backup of all your infotmation on thr phone. ot you will lose it all. hope this helps
Mar 01, 2011 | RIM BlackBerry Pearl Flip 8220 Cellular...
My phone will shut off six or more times a day and reboot itself and then a box will pop up and say...uncaught exception:java.lang.nullpo. How can I fix this problem?
first you need to determine if the problem is the battery, chipset, or a software malfunction
battery- see if its loose and is just moving around loosing good conection if so jsut try to put sum small in the back to keep it steady like some folded paper or come cardmoard. sum along those lines.
chipset- if its your chipset then your gona have to take it into your company and have them send it to the repair company
software- try to find an old restore point and set it back (refering to the java error) if you cant seem to find one then use your desktop software to do a system reboot.
Oct 24, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
Describe your Uncaught exception java lang
I need to know how to reset or wipe clean because i cant get jpast this message at all uncaught exception:java.lang.nullpointerexception i cant do anything help
Dec 12, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
I keep getting the message "Uncaught exception Java.lang.null pointer exception" and cannot use the phone at all. Any ideas?
Hi, When attempting to access a corrupted call list database on the BlackBerry smartphone, the Uncaught exception:java.lang.NullPointerException error message appears: Isolate the corrupt data by turning on advanced logging for Intellisync. Turn on advanced logging for Intellisync. Once the corrupt data entry has been isolated, delete it from the desktop email client and the BlackBerry smartphone. I Hope it helped you. Thank you for using ' Fixya ' and have a nice day!!
Nov 18, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Uncaught exception: java.lang.nullpo inter exception note keeps coming up
Hi, you get this error message when attempting to access a corrupt contact list database on the BlackBerry smartphone, BlackBerry Device Software or software application component has failed, or there is corrupt data from a wired or wireless synchronization.
1) Turn on advanced logging for Intellisync.
2) Once the corrupt data entry has been isolated, delete it from the desktop email client and the BlackBerry smartphone.
3) Synchronize again.
Clear the contact list database on the BlackBerry smartphone.
1) Open BlackBerry Desktop Manager.
2) Click Backup and Restore, and then select Advanced.
3) From the Device Databases list, select Address Book, and then click Clear.
4) Return to the BlackBerry Desktop Manager window.
5) Synchronize the contact list with the correct translator in Intellisync.
I hope this information will help you
Nov 17, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Can't check missed calls shows Uncaught Exception:java.lang.null
  1. Turn on advanced logging for Intellisync.
  2. Once the corrupt data entry has been isolated, delete it from the desktop email client and the BlackBerry smartphone.
Nov 10, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
RIM BlackBerry Pearl Flip 8220 Cellular Phone Logo
294 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
