Question about Motorola Mobility Karma QA1 Cell Phone
It won't connect to the internet. It says Network Error and suggests to type in a different URL, but to no avail. I have 5 bars of 2G service...
How do i fix error 404 on internet explorer windows 7
do the latest updates for windows and try again and if this does not reslove the error try contacting the webmaster of that page
Nov 27, 2014 | Microsoft Windows XP Home Edition
Tip
Error 404
Hi.<br /> <br /> 404 error page not found means that the computer is connected to the Internet, but that it cannot find the page linked to the domain name (that www.something.com, aka URL), or linked to the IP address typed into the browser (eg. Internet Explorer) address bar.<br /> <br /> The error is usually displayed because of either one of the following reasons:<br /> <br /> 1) The web page does not exist or the website does not work. In this case the web page requested will return error 404 from any computer. Test using at list two different computers and two different network connections.<br /> <br /> <ol> <li>This usually translates in one of the following:</li> <li>You wrote the URL in the wrong way.</li> <li>The web page requested does not exist.</li> <li>The web server hosting the website is down.</li> <li>The domain name is not linked to the website anymore (setting problems or subscription expired)</li></ol> <br /> 2) Your computer's DNS or network settings are wrong.In this case the web page requested will return error 404 from this computer. The same page will be displayed using a different computer or network. One example of this situation is when some malaware disables access to Websites like Microsoft by changing DNS service. If this is the case the same page will be displayed using other computers, but you will get error 404 with this particular computer.<br /> <br /> If this is the case, ensure that you have installed an efficient and updated antivirus. Run a virus scan.<br /> If that is not enough to fix the problem, try the following reset:<br /> <br /> 1- Click Start &gt;&gt; Run &gt;&gt; regsvr32 /i browseui.dll&gt;&gt; enter<br /> <br /> A dialog box with a confirmation message will be displayed. Click OK.<br /> <br /> 2- Click Start &gt;&gt; Run &gt;&gt; regsvr32 /i shell32.dll<br /> <br /> Wait for the dialog box, then click OK.<br /> <br /> Regards.<br /> <br /> Ginko.<br /> <br /> <br />
on Jan 07, 2011 | Microsoft Windows XP Professional With...
How to increase connectivity and strength of 2G and 3G network
@Surendra
It's based on dBM and asu and not the bars you actually see. Even if you may see fewer bars you could have equal quality. The phones, based on different OS may be calibrated a little differently. It's best to contact your service provider and verify....
1. Your SIM is properly programmed.
2. Your PRL is updated
3. You have a recent SIM
Mark
Motorola Support
Nov 04, 2014 | Motorola Mobility XT912 Droid Razr Verizon...
I reinstalled windows xp and i go on to the internet explorer and it says the page cannot be displayed What can i do to fix it and i do not have internet
If NO Internet = NO Internet Service
You are perfect and I.E.8 is functioning properly.
Internet Browser ( I.E. 8.0 ) requires an active internet account and access to the internet. " Page Cannot Be Displayed " = no connection to the URL address in the address bar.
If you have active Internet Service =
Sounds like you have no connection to your router / modem
Confirm the following connections : LAN = network cable, or Telephone line, or Wireless network connection and password ?
Once connected to your Internet Service Provider
IF you're system is ( only ) " Auto-Updating " ?
Try this.. manually check for updates. When window opens, check for all types of updates ( default selection is " important ", "Recommended " etc )
Select the other ( optional ) choice. When the next window appears ...
on the left side default (1st choice ), Software (2nd choice ) Drivers / other (3rd choice) 2nd " Software " = contains "optional" network update drivers and software = after downloading and installing updates ... machine re-start will be required for completion ...
REPEAT PROCESS EACH OF THE THREE TYPES OF UPDATES
Windows would continually find additional auto updates after each optional installation ... additional optional updates will become available, as a result of auto updating adding more updates ...
( " Lather, Rinse Repeat " ) Repeat processes, until all updates ( auto, optional, drivers ) show "0" available.
The system will now be updated.
please excuse, if the exact word of the choice is not exact, XP has been replaced 3x over.
If you find this was helpful, please remark positively
Nov 24, 2013 | Microsoft Internet Explorer 8
Dns error laptop
Instructions
    • 1 Refresh the page that failed to load. If the page reloads, you just had a momentary lapse in service that happens with most providers. Between each following step, try refreshing the page to see if the problem is resolved.
    • 2 Check the page address you typed into the address bar to make sure it is spelled right. An error in the URL address could cause this error message.
    • Sponsored Links
    • 3 Go to your connection settings and make sure the settings match those of your Internet serviceicon1.png provider or local area network. Do this by clicking on Tools on the toolbar, then Internet Options. Under the Connections tab, click Settings.
    • 4 Click the "Detect Network Settings" link on the Interneticon1.png Explorer page accompanying the error message to let Windows try and find an optimum connection.
    • 5 Download DNS error fix softwareicon1.png off the Internet if no other option works (see Resources). The software is free on some websites and should be able to identify the problem and correct it.
Nov 21, 2013 | Lenovo Computers & Internet
HTTP Error 404 - File or directory not found. Internet Information Services (IIS) this error message appears while i am tring to open my work account
This is most likely caused by not having a working internet connection or typing in the wrong URL. Verify that you are connected to the internet. This can be done by Control Panel then to Network connections or a closely named icon. Here it will show you if an adapter is enabled and connected to the internet. Also, verify that the URL is correct. After verifying both of these and still having a problem, if possible, try downloading another browser or using another browser if already installed.
May 12, 2011 | Computers & Internet
That's normal error code when a web page is no longer available or is experiencing heavy traffic.
Jan 07, 2011 | Computers & Internet
Will not connect to internet. connection shown as excellent, set up disc has been inserted to try and fix the problem but still will not connect. Item is 4-5 yrs old
There are many reasons we lose wireless connectivity. I would first start by clearing your cookies,history, and Temporary Internet files under tools menu if using IExplorer. Then do a disk cleanup.
Make sure your switch is on. You may also want to unplug your modem and restart both your pc and modem. Does your pc recognize any available networks at all. Make sure you don't have 2 firewalls going. Make sure your wireless card is active. you may want to activate it under CONTROL PANEL, ADMINISTRATIVE TOOLS SERVICES, then go to Wireless Zero Configuration. under recovery tab make sure all drop down menus say restart the system under all failures apply. Also try typing a different url in address bar. Hope this helps,
Dec 23, 2009 | Toshiba Satellite L10 Notebook
IPhone 3G reception problem
This problem is with the phone and not the network. Takie your complaints to APple and have them fix the antenna for your device.
Jul 17, 2008 | Apple iPhone 3G
Internet access for samsung e250
Check your internet connections on your phone. And ask samsung customer care and make themselves to set your fone's internet settings. All the best.
Oct 05, 2007 | Samsung SGH-E900 Cellular Phone
Motorola Mobility Karma QA1 Cell Phone Logo
79 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
