Question about Car Audio & Video
Im looking at a DUB AUDIO DUB2502 1100W AMPLIFIER it puts out 350 x 2 rms will this be good for 2 cvt12 2ohm subs
  • 117 Answers
It should be fine long as the amps to subs ohms are correct
Posted on Dec 01, 2009
DUB2502 550w 2-channel a/b mosfet amplifier 1000 watts maual
not 550 watt,,250 x 2 ,,
  • 2-Channel Class-A/B Amplifier
  • RMS Power (4 ohms): 250 watts x 2 chan.
  • RMS Power (2 ohms): 375 watts x 2 chan.
  • Bridged RMS Power: 500 watts x 1 chan.
  • Min. Impedance Unbridged: 2 ohms
  • Min. Impedance Bridged: 4 ohms
  • Brushed Aluminum Chassis
  • Top Mount Controls with Blue Illumination
  • Cooling Fan
  • Chrome DUB Fan Grille
  • Glass Epoxy Circuit Board
  • PWM MOSFET Power Supply
  • THD: 0.02%
  • S/N Ratio: 95 dB
  • Input Sensitivity: 200mV - 4V
  • Frequency Response: 10 Hz - 40 kHz
  • Variable 18 dB/Oct. Hi-Pass / Low-Pass Crossover: 50 - 250 Hz
  • Bass Boost: On/Off 12 dB
  • 4-Way Protecion: Thermal, Short Circuit, Overload, and DC Offset
  • Dimensions: 8-1/4" W x 2-1/8" H x 10-3/4" L
  • Authorized Internet Dealer
Audiobahn DUB2502 2 Channel 250W 2 Class Amplifier at Onlinecarstereo com
http://www.audiobahn.com/index.php/help/tech-support/manuals/category/1-amplifiers
Feb 26, 2014 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
I have a dub audio 2502 amp, do i use 4 or 8 gauge wiring ?
Despite the fact that they claim that the amplifier is 500 watt RMS if you look at the fuse it has on it, which should be one 30Amp fuse it means that the max that you might get out of this amplifier is 300 watt RMS. So an 8 Gauge cable will be more than enough for it. However, saying that, using a 4 gauge cable will not harm it in any way. what you should check before buying a 4 gauge cable is if it will actually fit in the allocated 12V terminal. Respectfully dreamsystems
Feb 03, 2011 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
Amplifier For Powering Sony Xplod xs-l121p5
Pump the brakes!
You need to know the RMS power rating of the sub you are powering.
Dont exceed the RMS power rating of the sub by more than 25%.
If you see a peak power rating on either the sub or the amp, ignor it, means nothing. Always compare RMS ratings.
Example: a Sony 12" Xplod sub, boasting 1200 watts, will only handle, 350 watts RMS, so the amp you choose to power the sub should be 350 watts RMS as well, and should not exceed more than 25% of the RMS power handling (487.5 watts).
Bottom line, know your RMS numbers, not Peak.
Byron
www.distinctbeat.com
Dec 06, 2009 | Sony Car Audio & Video
Had same problem, here was my deal...
AND MY FRIEND BASE ON WHAT AM READING AS LONG AS YOU HAVE THE SYSTEM YOU WILL BE SPENDING MORE TIME FIXING INSTEAD OF LISTENING YOUR SYSTEM IS NOT WIRED PROPERLY TO ACCOMMODATE WHAT YOU HAVE TO HANDLE THE IMPEDENCE FROM YOUR AMP THAT IS YOUR MAIN TROUBLE
Jul 05, 2009 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
Infinity 1211a @ 2 Ohms
Hello monkey_flea, Your subs will share the amp output. And if you are not careful, you'll end up blowing them. The amp puts out 1300 watts RMS at 2ohms, the subs have an RMS power range of from 75-350 watts, and you'll be driving them with 650 watts each. A better power match would be to series the subs to present an 8ohm final load. This will reduce the output power to a level the subs can handle. Or you could buy 2 more 12.1's and connect them series-parallel for a 4ohm load and each sub would still be getting 325 watts RMS, just about the maximum they are rated to handle. Hope this helps.
Jun 03, 2009 | Infinity Reference 1211a Car Audio...
Rockford fostgate p500-2 amp overheating pls help!
Your Amplifier:
125W x 2 @ 4-Ohms RMS
250W x 2 @ 2-Ohms RMS
500W x 1 @ 4-Ohms bridged RMS
Your Subwoofers = Dual 4 ohm
Possible wiring configurations of (2) Dual 4 ohm voicecoil subwoofers are:
2 ohm Stereo
1 ohm mono
4 ohm mono
That amplifier is not 1 ohm mono stable.
You need to put a 4 ohm load on the "bridged" terminals of the amplifier
Your best wiring configuration is going to be Series-parallel.
CLICK HERE to see the pic Larger
4721108.jpg You can also get the same result (power) by having the subs wired in parallel independently. Put both + on one sub to one + on the amplifier and both - on one sub to the - of the same channel of the amplifier.
Repeat for channel 2.
This will be a 2 ohm stereo load.
You should only use this method if the subwoofers are in seperate enclosures... not one big cavity.
Thanks for using FixYa -a FixYa rating is appreciated for answering your FREE question.
May 03, 2009 | Rockford Fosgate Punch P5002 Car Audio...
Is it enough to power to 12 volge=ahagen 12oowatss dual 4 ohms
your Volfenhag 12" subs are rated at 1200 watts they are only 600 watts rms and the Rockford punch p4004 is only 200 watts rms so the answer is yes it will work but if you get a amplifier that pushes out 500 - 600 watts rms you will love the sound from subs
there is nothing wrong with the Rockford amp it just wont pound out the bass as hard but the good news is you will never blow the subs with it
when buying amps or subs make sure to look at rms rating that is the true power they actually have ie. (sub box says 1200 watt you think powerful but if you divide it in 1/2 you actually get 600 watts rms) don't get me wrong that's a nice rating. for a sub but you will want to match that number with the amps rms rating or lower. The RMS is what makes the car pound the higher the RMS the better
hope this helps
Mar 05, 2009 | Rockford Fosgate Punch P4004 Car Audio...
Adjusting wattage on kenwood kac 9103 class D mono amp
That amplifier is 900W x 1 @ 2ohms.
If your subs are 4ohm SVC wired Parallel, resulting in a 2 ohm load, each sub will only see 1/2 of the rated power. (450W ea.)
Your gain (sensitivity) setting should be between 75% and 85% to max. You will be fine.
Jan 02, 2009 | Kenwood KAC-9103D Car Audio Amplifier
Car Audio & Video Logo
157 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
