PT53WX52F PANASONIC HALF MOON AT BOTTOM OF THE SCREEN. LOOKS LIKE A CD SPINNING. REPAIR GUY SAID 300-400.00 TO FIX. CAN I DO IT MYSELF
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
It sounds like convergence problem--red or blue skewed and will not adjust--what is called 3 D like picture.
If you can solder and are handy here are the instructions for PT53WX52 with this problem:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} What you will need;
Two new STK-392-110 convergence Ic’s
Solder
Liquid solder flux
Desoldering braid or wick
A good soldering Iron
Some denatured alcohol
A small toothbrush
A Philips screwdriver or screw gun to REMOVE SCREWS
A PAIR OF GLOVES
  1. UNPLUG TV SET.
  2. Remove back cover of TV set.
  3. Remove entire front speaker grill on set(it pulls off and may resist being removed)
  4. Locate and unplug speaker wires (they are plugged into the main circuit board).
  5. Locate three cables with wires that come from the Front keyboard—two of them have to be unplugged from the main board(all plugs are different sizes but note where they go)
  6. Remove 2 long philips silver machine bolts from the front of the set (behind the grill).
  7. Remove 4 more in the back of the set; two are located at the extreme back edge of the plastic frame and hold the chassis down; two more are located on either side and also go straight down; note which are which and set them aside.
  8. Using gloves pull the entire metal box (it is called a light box) out of the set; there are hand holds on either side—careful as the metal has sharp edges.
  9. Remove the box from the set and locate the two Convergence IC chips; they are located on identical metal heat sinks with fins and they should have the STK-392-110 number clearly printed on them in white (they are black)
  10. Turn the light box over on its side and UNSOLDER ALL 18 PINS ON EACH IC. It is a good idea to apply liquid solder flux to the pins on both chips now. I recommend using a de-soldering braid for this—get all the pins completely de-soldered.
  11. Inspect the dozen or so light blue resistors in front of them; most are marked 2.2 ohms—if any are white in the middle you will need to replace them at the same time; best way is to check all of them like checking a fuse----they protect the set if one of the STK’s shorts in any way.
  12. With the STK’s completely unsoldered turn the box upright and remove the two screws on each IC. If the chips have never been replaced you will need to tap them loose with a putty knife or flat bladed screwdriver.
  13. Remove both IC’s.
  14. Apply heat sink grease to the two new IC’s and install them one at a time; this part can take some time and it is important the pins on the new IC’s are perfectly straight---once you get them in, Hand tighten both the screws on each IC---do not use a screw gun—you can strip the screw holes out. Clean the bottom of the circuit board where the chips were soldered with some denatured alcohol and apply liquid solder flux to all the pins.
  15. Presuming you have already found/replaced any bad resistors turn the box back over and solder carefully both of the two new IC’s in, --do not short any of the pins to each other when you do this and when you are done it is a good idea to take a close look at both to make sure all pins are soldered and not touching each other with soldering you have just done. I suggest you do clean the pins on the bottom of the circuit board again with denatured alcohol.
  16. Slide entire light box back into the cabinet.
  17. Reconnect the plugs you removed when you removed the box. At this point take a lens cloth or a paper towel with glass cleaner sprayed on it and clean the three large black lens-if they are dusty the picture will be darker and not as clear as is should.
  18. Position the box so it is all the way in place and none of the wires or plugs are pinched.
  19. I usually at this point turn the set on before I replace the Six bolts that hold it in—2 from the front and the four in back----this way if you have a problem you can remove the box faster.
  20. If the set comes on and now has normal Convergence go into the customer menu and adjust the convergence in the multi-point mode----CAREFUL! THE FIRST OPTION this set usually offers is a green cross in the middle of the screen—do not adjust Green!
  21. Once you have the Red and Blue in the center adjusted find the second convergence mode---it will give you 8 or nine points on the screen with instructions on how to change from blue to red---use the original remote with the thumb wheel or cursor buttons to adjust.
  22. NOTE: SOME of these sets need to have the Convergence adjusted in first: full/4:3 and second in the other two zoom/wide zoom and third on the HD input with a HD signal coming in. There is also an option at this point to go into the Technical menu and fine adjust the convergence all over the screen—if you need this I can give you instructions based on the model you have—most of the time adjusting the set in the customer mode will produce a good result.
  23. I know all this may seem complicated to you, but this repair should take about an hour or so and just take your time when you get to adjusting the set.
  24. If all looks good turn the set off and Unplug it; install all 6 of the chassis bolts back; replace the back cover and the Speaker grill and plug the set back in.
  25. You may find it useful to go over the convergence Adjust again—to get all the points as good as you can. There is a hidden Tech menu that will allow a finer adjustment of the entire screen----it is somewhat difficult to access and there are a lot of buttons on the remote that then do different things.
  26. Most of the time adjusting in the customer menu will give you a very acceptable picture.
If this has helped you, rate this solution as I do this here for free.
Posted on Nov 12, 2009
Green half moon at bottom of screen, then no picture or sound
likely a convergence problem which has gotten worse
May 14, 2012 | Hitachi Televison & Video
PT53WX52F three blinking light
short protection: one of the several 2.2 ohm blue resistors in front of the convergence chips is burnt/discolored and bad.
Both chips would have to be replaced.
Do it yourself if you can solder and I have instructions for this repair.
photo of chip attached.
Let me know if you have questions.
Mar 04, 2012 | Panasonic Televison & Video
Model PT53wx52f had a pop then the picture looks warped the colors are warped. Is there a way to fix this?
If you look here on the site under "tips" you will find I have posted start to finish and step by step instructions for this under "Panasonic do it yourself convergence" repairs.
If you have specific questions post a comment here and I will help--I have fixed hundreds of these sets--if you have some minimal skill you can do the whole repair for under 30 dollars parts cost(I can tell you where to get the parts).
SD TECH
Apr 13, 2011 | Panasonic Televison & Video
Picture looks like it is warped at the bottom and top of the picture. Have picture, no problem there, just not a centered picture anymore. Looks like the top of a half moon on the top and botom.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some images of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Or goto the site www.TvRepairKits.com for the parts and instructions on how to fix it yourself.
Dec 28, 2010 | RCA HD52W59 HDTV Projection Television
My Panasonic PT53WX52F has a sideways hourglass picture with the green scroll running in an arc with the same red scroll running straight across. Is this the convergence chip you talk about?
There are two common problems with these sets.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 23, 2009 | Panasonic PT-53WX52 53" Rear Projection...
I have a panasonic rear projection lcd, it has a yellow tint around center of screen. Help
My PT-43LC14 has a yellow tint on 3/4 of the bottom to top. the top 1/4 seems normal. I removed the bulb assembly and it looks OK. Any ideas. Is there anything I can doe myself. and if so what is the p/n I can buy?
Mar 18, 2009 | Panasonic PT-43LC14 43" Rear Projection...
My Xbox 360 stopped spinning the CD and playing the games.
i myself have the same problem and currently working on it. go to youtube and type in "how to fix a broken xbox360 dvd disk drive" this guy is amazing and helped me out with the red rings of death. all u have to do is buy a new disk drive for about $50 and take some parts apart.
Mar 14, 2009 | Microsoft Xbox 360 Console
Ckeaner drags on carpet
This unit has the outer window, and a half moon window behind it. Check to make sure the 2 screws holding the half moon window are tight and that the plastic hasn't broken. The 2 windows at the bottom cener merge together, they may have come apart. Usually when one or the other window is out of place, it will cause a drag. You may have to replace the half moon window.
May 17, 2008 | Bissell 1699 ProHeat Clear View Upright...
Panasonic- 47wx42f
the convergence ic's are at fault need replacing,call a service shop and ask for estimate to repair .should be under $ 300.
Dec 09, 2007 | Panasonic PT-47WX42 47" Rear Projection...
Televison & Video Logo
235 people viewed this question
Top Televison & Video Experts
