Question about Brother MFC-5440CN All-In-One InkJet Printer
How do i connect the wires to my computer - Brother MFC-5440CN All-In-One InkJet Printer
    President:
  • 2,049 Answers
There should be a USB cable that came with your printer. Plug one end into your printer's USB port and the other into a USB port on your computer.
Posted on Nov 12, 2009
I need to no where the red wire from computer goes on fuse box ( had new harness installed and was told the red wire from computer goes to fuss box
Typically the red wire is a Positive voltage wire. If you were told the wire goes to the fuse box, you should get a wire diagram for the wire harness. On the diagram it should show connections marked with numbers and possibly colors. The computer on the wire diagram should show a red wire marked Vcc or Positive or something like that, trace that wire on the diagram carefully to the fuse box on the diagram, the fuse box on the diagram should be marked with a fuse rating at the location where the wire connects. As long as the fuse rating is the same and it's marked as "ECU" or something similar related to the "engine control unit", that is where you connect it. DON"T put it on any other connection with a different fuse rating, it could damage the computer as soon as you turn the key. this should give you enough info to get it connected and if not you can refer to this to explain to someone else. Good Luck.
Nov 26, 2014 | Cars & Trucks
Check connections
The connection of the USB cable
Verify that the USB cable is connected between your Brother machine and your PC.
The connection of the LAN cable (if applicable)
Verify that the network cable is connected between your Brother machine and access point and the machine is powered on.
1.Access point/router
2.Wired Network machine (your machine)
3.Wireless capable computer connected to the access point/router
4.Wired computer connected to the access point/router
The connection of the Wireless network
2.Wireless Network machine (your machine)
Still having Problem Then follow Us For
Brother Printer Support
Feb 20, 2014 | Brother MFC 7840W Printer
How do Connect two computers - one hard wired and the other WIFI
to connect a computer with a hard wired connection just use an ethernet cable and wireless you should see available connections when you click on network icon bottom right of screen then click on your router name and enter password if required.
Jul 28, 2012 | Linksys Computers & Internet
Sony Vaio netbook will not connect to internet - says limited connection
That's usually your router, not the computer. Sounds like your computer is connected to your router, but IT is not connected to the internet.
I would suggest shutting down the computer, shutting down router, then the modem, plug the modem back in, waiit for lights to finish blinking (should be within a few minutes) then your router, once that's finished blinking, then turn on your computer.
Jan 15, 2011 | Sony VAIO VGN-NR160ET Notebook
I have 3 wireless connected and 1 computer that is connected via wired lan to this router. The problem is whenever I use the computer with wired connection, I computers with wireless connection cannot...
On the "wired" computer:
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG /RENEW
Press Enter
Type IPCONFIG /ALL
Press Enter
Note the IP-address assigned to the Ethernet adapter.
Note the date/time at which the router assigned the IP-address to your computer.
Repeat on one of the "wireless" computers.
The IP-address should *NOT* match the IP-address of your "wired" computer, and the date/time should be close, but not identical, to the valuesl from the "wired" computer.
Any error-messages from the 'IPCONFIG /ALL' command?
Sep 26, 2010 | Linksys Wireless-G WRT54G Router
How to connect
Check the wires.
One wire should end with a thin green pin.
Connect the green pin to the green socket on your computer.
If there is a black pin, you have a sub-woofer, and the black pin
connects to the black socket on one of the speakers.
Connect the wire with the 2-prong silver plug to AC power, e.g., to a power-bar.
Test the speakers.
Nov 25, 2009 | Altec Lansing XA2021 Computer Speakers
Internet Connection Problem on One Computer
By any chance, are you trying to use something other than Windows to manage the wireless adapter? If you are, remove it.
Now, Click on Start, right click on Network highlight properties, and click on manage network connections on the Tasks menu.
Your two options will be the icons for your LAN and Wireless Network. Is it enabled and without red or yellow marks? It could be disable, it could be not connected and you can't view wireless networks because the switch is off, or it may just nut see your unsecure network (unlikely).
If the above is clear, right click on the wireless and highlight Properties and left click so it brings up the Networking tab. Highlight IPv4 and click on Properties. Make sure the Obtain dots are ticked. That should work, since you are running unsecured.
If it already is, check the red X or if it isn't click OK and close down the box.
Now, back to where your Wireless card is showing, right click it and you have Disable, Connect/Disconnect, Status, Diagnose etc.
If you're still Disconnected but not Disabled, click on Connect/Disconnect. Does it show your wireless network?
By this time, it should. If it doesn't post back. The other possibility is that you take your computer to a wireless internet cafe, McDonalds, Panera Bread, or motel with WiFi and test it there.
Carl
Jun 21, 2009 | Linksys Wireless-G Broadband Router
Cant connect to internet
How many computers are you using?
Are they all wired or wireless ?
Steps
1. Your modem should be connected to the wired port of the router
2.Your computers should be connected from the the other blue ports on the back of the router
3. Now open up the set up page by typing in 192.168.2.1
4. on the top right hand corner you"ll see your status connected or no connection
5. if status is no connection
6. click on restore factory default and let it reboot
7. now comes one more important question what is the version no of the router
8. it is a 4 digit no like 1000,2000.......7000
9. If ver is 7000 then definately go to the site www.belkin.com/support and download firmware version 9.01.10 for ver 7000 or similar
10. On your router setup page select firmware update and load the file
10.Should resolve your issue specially if your isp connection is cable like comcast etc
11. then reconfigure by using connection type
clonig mac address if cable or entering u/name password if dsl
12. also change the channell to 11 as that gives the best reception wirelessly
Should fix the problem definitely but it could have been easier if i knew your exact version no, modem isp,(cable or dsl) , type of computers (wired or wireless) etc . Make of computers (mac or windows) .You can even access other computers wirelessly but you have to connect to your network on the wireless computer.
Feb 03, 2009 | Belkin (F5D7230-4) Router (587009)
Belkin router54g 75d7230-4
As long as the computer you are connecting has the capability to connect in some form, wireless or wired, you will not have to run the web utility again. However, if you are currently connecting your laptop wirelessly, and you are connecting your other computer with a wired connection, you must make sure that the wired network is not disabled.
May 01, 2008 | Belkin (F5D7230-4) Router (587009)
Brother MFC-5440CN All-In-One InkJet Printer Logo
35 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
