Question about Fisher and Paykel GWL11 Top Load Washer
Our Eco Smart will not pump out the water. The pump is working but it will not pump out the water in the tub
    Genius:
  • Fisher and P... Master
  • 1,474 Answers
Check /clear filter
Posted on Nov 12, 2009
My F and P Eco Smart top loader gets to the rinse cycle then stops. An electric hum is heard, then the warning signal goes off. It wont go any further than that.
You need to unplug that machine and not use it again until you figure out the issue. I would say it sounds almost 100% like you have a bad water pump. If the pump is getting wet or has a short in the coil, it will get hot and shut down. Bail out any water that is in the tub currently, and inspect that pump ASAP. if you continue to use it like this, you risk burning out the motor controller.
Jan 07, 2011 | Fisher and Paykel IWL12 Top Load Washer
I've got Fisher and Paykel Excellence Top loader 7.5 My problem is, it won't unload or drain water. What do i have to do?
Hi, The washer wont unload or drain water until the drain pump is working. Get the pump off and look for debris. To remove the pump you unlock the tab and twist the pump a hair. The pump is on the bottom of tub.
Apr 13, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
My fisher paykel eco-smart washer is filling up with water at the same time it is pumping the water out the drain.
My washer is filling up..but not very high and at the same time it is pumping out water into the sink. Will not spin or rinse
Jan 01, 2010 | Fisher and Paykel WA37TG1 Top Load Stacked...
Eco smart won't drain, smells hot
hi
you commented on hearing water in the machine after the wash , i know that f&p spin bowls have a liquid inside the actual spin bowl system i think it aids in the spin operation of the machine, but if you had something in the drain network then that will stop the machine from emptingout as it all works on a time basis check and see that you are not getting any leaks from the bottom of the machime as your new pump won't last long if it gets wet also if there is water leaking that can be the main seal on the motor shaft failing
cheers grant
Oct 19, 2008 | Fisher and Paykel GWL11 Top Load Washer
Help
YOU NEED TO CHECK IF THERE IS NOTHING STUCK IN THE PUMP AS NOT DRAINING ALL THE WATER IS A SIGN THAT THE PUMP IS NOT DRAINING COMPLETLY.GOODLUCK. MOHAMED
Sep 18, 2008 | Fisher and Paykel IWL12 Top Load Washer
Washer not spinning
fisher& paykel eco smart mn gwl11 ser no. myn 603195
Apr 14, 2008 | Zanussi FJS1225W Front Load Washer
Washing machine not draining and finishing cycle
I had the same problem.... It would stop on the rinse cycle and beep.  Check to make sure you can hear the water pump running or if you can just hear an electrical hum and then it quits, it may be a problem with the water pump.The water pump can be accessed by removing the tub, reach down the center of the agitator and remove plastic bolt, remove the stailess steel tub and then remove the plastic oval shaped cover at the bottom of the main tub to access the pump impellor.  Make sure the impellor turns freely, if it does not you may have a problem with the pump motor.  We had a gold chain go missing and it showed up wrapped around the pump shaft causing it to bind at times.  It took me two tries to fix it but now it runs 100%.
Oct 31, 2007 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
160 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
