Question about HP LaserJet 4 plus Printer
How can i clean hp printer it looks ink spill inside. is it normal or not? it was hp all in one printer.
  • 105 Answers
If you have a microfine filter for your vacuum, just vacuum it out. You can also remove the fuser and the toner, then blow it out with LP air. (reverse vacuum or canned air)
Posted on Nov 24, 2009
How can I fix my printer problem? after changing my ink cartridge it stills tells me that the cartridge is empty and to load a new one. There is ink spilled inside the cabinet
I have had this problem HP as well.
Be sure the protective cover on the bottom of the cartridge has been removed.
Some printers have a "sensor" built into the cartridge that "tells" the printer when it is empty. If you are using a generic cartridge that might also be a problem.
Hope this helps.
Sep 21, 2014 | HP Officejet Pro 8500A Plus Wireless...
5610 hp printer shows insert cartridge on right when i changed to new cartridges. they are new cartridges and are inserted correctly
try this
- Remove the cartridge that is not working. - look for a lint free cloth "coffee filter" then dump w/ water - clean the copper contacts of the cartridge - make sure that the air vent is open; if not pinch it a bit - remove all the cartridges - check if there are are inks spills - use lint free cloth to clean the part where you are have trouble with - install the inks again - run alignment and clean cartridges on the panel
if still nothing works, call HP tech support and ask for replacement of the ink.
note: they will do the same steps again for troubleshooting and documentations. the reason why this happens: - that the copper contact does not touch each other - cartridge air vent is sealed - not an orig HP ink - Print head problem, needs cleaning
Jun 05, 2011 | HP Officejet 5610 All-In-One InkJet...
How do I clean an ink spill in my HP Photosmart HP C7180?
Depends on how much you spilled, but Q tips would be a good start.
Oct 29, 2010 | HP Photosmart C6180 All-In-One InkJet...
Ink spilled inside
It may be too late. That ink is caustic to the circuit board. To get to it is a real chore and probably not worth the effort.
Jan 24, 2010 | HP PSC 950 All-In-One InkJet Printer
Ink cartridges will not slide due to leaking ink underthe printer
Sorry to hear about the mess. Let's start with the clean up of the ink. Use a dry cloth or paper towel to wipe up the ink that has spilled out of the cartridge. Wipe gently so you don't do any damage to the internal components of your printer. The ink will likely color the inside of your printer - That's okay. Just make sure you get anything that puddles. It should not look wet.
On to the non-moving cartridge carrier. The standard fix for this is to do a hard reset on the printer. Follow these steps.
1. Unplug the power cord and remove the paper from the paper tray.
2. Move the carriage all the way to the right, close the lid and reconnect the power cord.
3. The printer will make some noise as it starts back up. Wait until it stops making noise.
4. Open the printer lid. The carriage should return to its normal position.
5. Try printing again.
If this does not work, then damage has been done to the internal components. You will need to get the printer serviced by a repair person.
Jul 20, 2009 | HP DeskJet 952c InkJet Printer
Ink spill inside InkJet Printer
Hi, You need to strip it from the top, use normal dish wash soap and hot water. TRy to work around the mechanical parts, this is kind of advance to strip. There's should also be a sponge that you can wash.
Thank you
Dec 24, 2008 | HP PSC 750 All-In-One InkJet Printer
Printer cartridges
Dispose of the leaky cartridge. Clean the contacts in the machine with a little rubing alcohol and a q tip (don't soak it-just moistened it a bit) Make sure the Printer is turned off while you are doing this. While you are doing this I will look up your cartridges and what they are for. I suspect that you have a color cartridge/a regular black cartridge/ and a black printing only cartride but I will check. Don't ever use a leaking cartridge they can damage your printer.
Aug 15, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Jet ink on printed invoices
Clean inside for toner spills
check fuser may be worn
check drum ( green Cylinder of toner cartridge) --Rotate--
Jul 15, 2008 | HP LaserJet 2430 Printer
New black print cartridge not working
I only use refill HP inks. When the cartridge prints gray instead of sharp black it means the ink well is clogged. Yes, that can happen on a new cartridge. Sometimes it happens when they put too much ink in the cartridge, or even heat can make it not work. Also streaking black lines is the problem of the ink not coming out properly. Easiest thing to do is go to a refill station like Cartridge World and have them test it or clean it out. You can also make sure the printer, not the cartridge is clean. Ink builds up an pools. Get some Q-Tips and clean up all that spilled ink. Sometimes in the software it says you can clean the print head, do that too.
Sep 14, 2007 | HP Photosmart 2610 All-In-One InkJet...
HP LaserJet 4 plus Printer Logo
71 people viewed this question
Seeker5211
Seeker5211
