Question about Acer TravelMate 8200 Notebook
Is it possible to restore data from a dead SATA 120Gb Hard Drive by myself? what tools do I need? From the sounds of the drive, I guess it has mechanical failure. Any cheaper places or ways to restore data from dead hard drive ? I assume it is mechanical failure. Is bigger storage size(e.g. 160Gb) easier to get broken then internal SATA 120GB Hard drive? When installing XP on a replaced (new) hard drive on my ACER laptop, I need to download and install drivers. Do I need to know any password, Serial Numbers from ACER in order to set up all drivers? How long does it take to set up a new hard drive, load XP from scratch and configure all the drivers?
  • 330 Answers
If you want to replace a new hard drive it will good ...for driver you can download from acer download center its fully easy ..... for installing XP and driver it will take only two hours .......
goes through below link to download drivers .....
http://support.acer-euro.com/drivers/downloads_gd.html
Posted on Nov 12, 2009
Testimonial: "To the point. Informational."
  • 54 Answers
Try puting the hard drive in the frezer for 2 to 3 hr and you might be able to get the info off the drive hook it up as a slave hard drive. you should have the restor disk for the new drive, you can go to acer on line to get the drivers you need. hope thats helps. bobg22
Where can I get a replacement board for a Seagate barracuda 7200.7
You want to replace a board on a hard drive. I doubt that this is possible or that you will ever find one
Oct 14, 2014 | Seagate ST3120026AS - 120GB 7.2K SATA...
Sata hdd very slow
hard drive maybe slow 5400rpm not 7200 rpm check drive speed on them
Nov 08, 2013 | Intel D101GGC Motherboard
How To Recover My Data.?
Dear Rabeesh,
I'm guessing that you've formatted hard drive partitions containing Windows 7. If so, the drive will eventually become RAW as it contains the system files and the OS.
You need to run the professional partition recovery software (http://goo.gl/5eEjN), capable to recover RAW partitions from your hard drive. Follow the link mentioned above and try the software. It comes in demo version, so you can try it for free and once assured, you can go for premium version to recover all your data.
Dec 04, 2012 | Toshiba MK2552GSX 250 GB SATA Hard Drive
Is it possible to use ID harddisk and SATA harddisk at the same time?
You can indeed mix IDE & SATA drives on a computer. If installing the OS (Operating System) to the IDE HD, you will only need to instruct the BIOS to boot the IDE HD drive first.
If you decide to install an OS on & boot the SATA drive first; you will need to instruct the BIOS to boot the SATA drive first and may need to provide a driver for the SATA controller - if the OS install does not recognize the SATA drive. The driver should have been included on a disk or diskette with the controller (or on the motherboard driver disk if a built-in type controller). You should see a prompt asking "If you need to install a driver.... press F6" (or similar). Press the F6 key and supply the driver disk - and follow the prompts.
Nov 24, 2011 | ASUS K8V-MX Motherboard
Hard Drive recovery
Have you tried some data recovery software? You can use the Google search tool in this regard. .My Mac Book Pro hard drive has crashed and I'm in the process of replacing it. However, I had a lot of important data on that hard drive that he needs recovered. Then I found this data recovery software that recovers data from corrupt/bad hard drives. And fully supported for NTFS/FAT32 mac files. Mac Hard Drive File Recovery Recover Files from Formatted Mac Hard Drive
Dec 08, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Hard drive replacement. can I use 160Gb other than 120Gb original hard drive? how to recover data from dead hard drive? will Seagate replace the drive if it is over 1 year warranty?
If the drive is out of warranty then no....seagate will not honor an expired warranty. As far as the swapped hard drive yea you can swap for a larger drive as long as it is the same dimention (2.5/3.5 ect) and connect (SATA/PATA/ATA/IDE) as far as loading windows you are gonna have to get your hands on a usb cdr drive....either that or create an ISO image of your operating system on a sd card. Good luck
Nov 12, 2009 | Acer TravelMate 8200 Notebook
I HAVE TRANSCEND 2GB PEN DRIVE WHEN I DOUBLE CLICK OR RIGHT CLICK OPEN/EXPLORE FORMATE MESSAGE COMES IN PROPERTIES FREE AND USED BITE 00
1.
Update Your Windows Operating System.
2.
Check your computer.
with antivirus and antispyware program.
3.
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
3.a) Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2.b) Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Mar 06, 2009 | Transcend USA 120GB Storejet 2.5" SATA -...
Laptop does not boot after changing my hard drive for of 160 GB
My guess is that u need to get in to the bios and set the settings to boot from hdd and only from the hdd since it try's to boot but dont know from where.
Good luck
Nov 26, 2008 | Acer Aspire 5630 Notebook
Recover Data from Internal Hard Drive
I could if I had your drive. You need specialized software to recover data from hard drives.
Nov 07, 2007 | Maxtor Hard Drive
Open Questions:
Acer TravelMate 8200 Notebook Logo
134 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
