Question about Kitchen Ranges
Fujutsu mini-split 'discharge termperature abnormal' error code
I have a Fijutsu mini-split ductless system (AOU15RLQ) that was installed in summer and worked great. Just changed it over to heat and almost immediately received the error code 7 red flashes on operation light and 2 green flashes on timer light. I found a Fujitsu service manual and it says that the code means the problem is 'discharge temperature abnormal.' What is that about? The unit is only 6 months old and is otherwise in great shape.
    President:
  • 1,515 Answers
This unit is what is called a Heat-Pump.It has a reversing valve in the condensing unit outside which switches you're system from cooling to heating via this valve.It has a ball bearing inside this that opens a port, and slides to close off another port to reverse the flow of freon from one season to the other.If your code indicates discharge supply air temp. abnormal, you are having a problem of some kind in your out door unit.Even though its new, I have seen these ductless split systems fail within a month. I'm am not saying that you have a lemon, just pointing out they do have problems with main board failures, Freon leaks at line connections because they are not brazed like systems with ducts. But, being this new, you should have this unit still under warranty!! For me to trouble shoot this online would be a long task, I would have to be on site. Call the Contractor now and get them out to make repairs right away. Compressor is normally a year warranty unless you get the 4 year Extention.Failures happen like this on all units, not just yours. It could be many small things that would cause a low discharge air temp. Get them back out!
Sincerely,
Shastalaker7
Posted on Nov 12, 2009
What does E2 code indicates on a Winchester brand ductless air conditioner?
Try turning the power off for 15 minutes.
Tech Tips: How to Resolve E1 and E2 Error Codes - YouTube
? 1:48
https://www.youtube.com/watch?v=COIxQBT-J2k
Oct 14, 2015 - Uploaded by MitsubishiHVAC
In this Tech Tips video, Jeff explains the E1 and E2 error codes, possible causes and some ways to resolve ...Missing: winchester ‎brand
Error Codes - Room Air Conditioner - LG
www.lg.com > Home > Support > Product Help > Help Library May 19, 2017 - An error code on the display of the room air conditioner can usually be ... P2 or FL; CH34; E1 or CH02; E2 or CH01; E3 or CH03; E4; E5; F1,F2, ...
Pioneer Air Conditioner AC Mini Split ERROR CODES And ...
https://removeandreplace.com/.../pioneer-air-conditioner-mini-split-error-codes-and-tr... Jun 19, 2017 - Pioneer AC Ductless Wall Mount Mini Split Indoor Unit Error Code = E2 What Does The AC Error Code Mean? = Zero-crossing signal detection ...
QSHX-242 24000 BTU Mini Split Air Conditioners With Multi-Fold ...
https://www.pinterest.com/pin/542894930052841690/
Panasonic S22NKU-1 Cooling Only Wall Mounted Ductless Mini Split ..... Room temperature, set point temperature and status codes are all indicated on the ... The Goodman brand is well known for affordable pricing covered by some of the ..... Winchester Air Conditioner Quick Connect System 4rac36q-30 - 36000 Btu 13 ...
Sep 27, 2017 | Heating & Cooling
The control card is displaying error ch-01
PDF]SERVICE MANUAL R?410A Ductless Split System Air ...
dms.hvacpartners.com/docs/1011/Public/.../42108920400_ICP_26610.p...
421 01 9204 00 1/03/13. SERVICE MANUAL ... Consult local building codes and National Electrical Code. (NEC) for special ..... 18000 (5970-22350). Heating Capacity (Min. - Max). Btu/h. N/A ..... Error Messages Displayed Front Panel. S.
Oct 08, 2015 | LG 18000 BTU Dual Zone Mini-Split Heat...
Carrier ac E4 error
If this is a ductless mini split e4 appears to be an air temp sensor on the indoor or outdoor unit that is sensing an abnormal reading. Check air filter and both I.d & o.d coil cleanliness. Its hard to troubleshoot without a model number. If its a 38g or 40g in the model number its a discharge temp sensor reading high temp situation (dirty o.d. coil, low freon, refrigerant restriction. Again, need a model #
May 29, 2015 | Carrier Heating & Cooling
Mini Split GE model AE1CD20DM. Not cooling. Why is the power light blinking green 6 times and stopping, repeating over and over?
This should be a "trouble code". In the owners manual or installation manual you should find a list of trouble codes that help us determine what may be the lead malfunction.
May 20, 2015 | GE Quiet-Aire Ductless Mini Split System...
I am not able to get the unit to change from air conditioning to heat
Unfortunately these units are not user fixable , beyond checking for power and checking battery in remote. You would need to call a pro who is able to get service information and has special digital logic meters to diagnose and repair .
Oct 04, 2014 | Mitsubishi MXZ-2B20NA-1 Mr. Slim Dual Zone...
My mini split system had an E2 code...replaced indoor pipe sensor...indoor unit works but outside unit does not...no other error codes, just motor not working outside
Check the outdoor unit to ensure power is available to it, and the contactor is closing on a call for cool 24-28 volt is present at the contactor coil to activate it.
Aug 24, 2013 | Continental Electric CE-AC7581 Ductless...
LG Ductless Mini Split System LAN125hv: Heat pump doesn't run.
First check your circuit breaker or fuse that supplies power to the outside unit. It's probably separate from the inside unit. Then try to turn unit on. If the fan and compressor just make a humming sound then turn it off and check the capacitor if you have a multimeter. You can also look at it and see if the top looks expanded. That's a good sign its bad, but not all bad one's look expanded. Tomorrow I will have access to an LG service manual and can let you know what the code means. Sorry I can't get it sooner. Let me know what you find.
May 02, 2010 | LG LA185HV Split System Air Conditioner
Ductless minisplit in old mobile home
ductless mini split units are a very good choice!  they are obviously quieter, more efficient and easier to maintain than window units. the downside is the initial expense of buying the unit, but this is paid back in eletric savings and peace of mind. Good luck Peyton
Mar 07, 2009 | Soleus KFR12GWD 12,000 BTU Heat & Cool...
Kitchen Ranges Logo
1,784 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
