Question about Jenn-Air PRG3010 (NP) Gas Kitchen Range
Jenn air pro range 36" prg3610np
The top burner that is on of the simmer burners the the electric pilot wants to keep lighting the gas even after the burner is lighted.
  • Anonymous Sep 24, 2008
    My gas cooktop keeps trying to light the pilot even after the burner is on. Also, you can see the pilot flashing and continuing to attempt to light the other burnrs by constantl "snapping" even after the front burner is lit.
  • 943 Answers
Hi after the burner ignites turn knob until it stops trying to ignite thanks
Posted on Sep 23, 2008
Igniter switch on top burner will not shut off
try thoroughly cleaning the burners, particularly the holes in the ring that the gas come through. The gas come through to heat the ignitor so that the ignitor knows to stop trying to light the burner ; if the holes are clogged the ignitor doesn't heat.
The burner is easily disassembled from the top by removing a thin bolt, and you can clear the holes with a paper clip.
Sep 21, 2013 | DCS RGS-305 Professional Gas Kitchen Range
Jmy gas stove wont stop clicking and all burners are turned off
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Aug 26, 2011 | Jenn-Air 36 in. CCG2523 Gas Cooktop
We just bought an older house with a jenn air cook top but the pilots are out. How do we light them?
First, you need to look below the cooktop to find the gasline. There is supposed to be a shutoff valve on this gasline. Turn the handle so it is parallel with the gasline (perpendicular is closed) to open it. Before lighting anything, smell around high and low around the cooktop and make sure you do not smell any gas. You can also spray soapy water on all the gasline fittings to detect leaks by looking for bubbles that form. If all is safe, using a long butane lighter, light the pilots for the cooktop. There should be 1 pilot for every 2 burners. You will probably have to remove the grates and metal spill covers to light the pilots. The pilot should be approx 3/8" tall or less. Test each burner individually to make sure they light off the pilot. If they do not, you may need to clean the vertical holes on the side of the burner (where the lighting tunnel connects) by poking them clean with a needle. If the horizontal burner holes are clogged, clean them as well. If there is also a built-in wall gas oven, be sure to light that pilot on that as well. Good luck. Douglas
Sep 28, 2010 | Jenn-Air 36 in. CCGP2720P Gas Cooktop
How do I utilize the self cleaning part? Do I just press ''clean
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
GE Profile Gas Range oven light doesn't work even after changing
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Spark module will not stop after lighting burner
The module might not sense the flame: check electrical connections: wire (and its contacts0 and conections by fryer chasis; to be sure please bond with 18AWG wire pilot burner with spark module green wire.
MarKor
Mar 09, 2009 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
How to replace spark igniter - Jenn-Air SEG196 gas-electric range
took off the knob to the ignition system to clean and spray got onto the ignition under the dial and now the two front burners won't ignite unless I turn on one of the functional back burners then turn on the front burner. How do I repair this?
Jan 22, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Jenn Air Pro Style gas range - ignitors on 2 burners (same side) click but don't light
I had a problem in which only one burner refused to light with the electronic ignition, even though the same ignitor (they are shared) would light the rear burner on the same side, and the problem burner would light with a match. On inspection, the spark occurs at a central point and there is a tube which apparently leads gas from each burner to the ignitor. There are two groupings of 3 holes each on the sloping part of each burner, facing toward the ignitor. After lighting both burners (the front one with a match), I saw that the lower group of 3 holes had tiny flames on the burner that worked properly, but not on the other. I carefully cleaned each of these holes with a small pin, and the problem appears to be solved.
Apr 27, 2008 | Jenn-Air Kitchen Ranges
All the Burners click when I just turn on 1 knob
The manual tells you this will happen. Just adjust the flame for your intended use and start cooking
Dec 01, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Jenn-Air PRG3010 (NP) Gas Kitchen Range Logo
564 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
