Question about Dyna-Glo RMC-8001SS Heater
Pilot light lights but when turnd on it does not get hot and shuts off in 1or2 minuts
  • 439 Answers
This is normally caused by the thermocouple. This is the part the pilot light heats up to let the heater know the gas is on and the pilot light is lit. The heater will shut off if it thinks the pilot light is not lit for safety reasons. You will need to change the thermocouple for it to work again correctly.
Posted on Nov 12, 2009
Hearthmaster fireplace shuts itself off
So the main burner does fully ignite, but after a minute everything shuts off including the pilot? May just need the pilot cleaned
Sep 12, 2017 | Heating & Cooling
I have a big buddy heater hooked to a 5lb tank. I can get it to run for 5 or 10 minutes. Then it goes out. When trying to restart the pilot light has built up excess pressure and i have to shut tank valve...
sounds like bad regulator.you might be able to add one from a grill to get pressure under control.I'm guessing its turning off because its too hot
Jan 11, 2011 | Heating & Cooling
The pilot light will not turn off after the burner is on... I think it over heats, because it will just shut off after several minutes.... any suggestions? Thank you
The pilot light must remain on, even when the main burner is on, to keep the thermocouple hot. If the thermocouple cools off, the gas flow shuts off. It sounds like something is interrupting the gas flow. If this is an LP heater, try replacing the regulator.
Dec 11, 2009 | Berkeley Forge G-PH001PSS Open Flame Patio...
Oven malfunctioning, not getting hot; smell of "gas"
Check that the pilot is lit., If not, light it after gas is shut off for 10 minutes. Then turn to pilot, hold down, light, keep holding down for exactly 1 minute, then turn gas knob to ON and you should be good. If gas shuts off, then valve is bad.
Sep 16, 2009 | Kitchen Ranges
Main burner too hot & 2nd burner pilot won't
Set t/stat to 250 degrees. If it does not shut off after about 5 minutes, replace t/stat.If shuts off, must be calibrated Pilot may be dirty, flame weak. If flame strong, replace thermopile(pilot generator). If weak, must remove and clean pilot orifice inside pilot.
Aug 29, 2009 | Keating Kitchen Appliances - Others
Bosch WTMC3500UC gas dryer runs but does not heat
my dryer does not put out lint, rather thru the front.
Aug 22, 2009 | Bosch Dryers
After a few minutes of burner heating the water, gas shuts off.
A couple of things to check:
If possible, remove the pilot gas assembly and clean the gas jet and thermocouple - they can get carboned up and stop working properly. Make sure the pilot flame and deflector is aimed properly and making the thermocouple glow red hot. If the problem persists, you may want to replace the thermocouple and also check the propane regulator.
Apr 20, 2009 | RTO Atwood Water Heater - 6 Gal LP
No hot water at all
is the pilot light lit? try to turn the temp up on it useing the dial in the front of the gas valve. check the cold water feed turnd on to the water heater
Dec 30, 2008 | Rheem 40 Gallon FVR NATGAS Low WATER...
Pilot light won't stay lit.
most common cause of the described symptom overheating the thermocouple! a thermocouple produces millivolts of electricity based upon a differential of temperature between the tip and the base. If it gets too hot it will not work correctly. If the pilot flame is too large or the main burner flame is contacting the thermocouple or the thermocouple is too cheap or old all can cause this issue.
Dec 18, 2008 | Heating & Cooling
Dyna-Glo RMC-8001SS Heater Logo
477 people viewed this question
Top Dyna-Glo Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
drifterray
Level 1 Expert
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
