Question about LG VOYAGER VX10000 Cellular Phone
How do i select one of my songs to be my ringtone
Set my fav tunes as ringtone ?
Ringtones or songs downloaded or copied to your storage card are not automatically added to the ringtone selection menu. You need to go to the Music application and set a ringtone or song in your storage card as your ringtone. To do that top up arrow and Music then tap the three paralel lines at the bottom-left corner of the screen to go to the Library. Play the song that you want to use as a ringtone and on the Playback screen, press MENU and then tap Set as ringtone.
To change the ringtone press MENU, and then tap Settings. Tap Personalize > Default ringtone. The Phone ringtone selection menu then opens and you can scroll through the available ringtones and tap the ringtone you want to use then tap OK.
Feb 14, 2011 | HTC Wildfire Cell Phone
I have not an icon to personolise mij htc desire so i cannot change my ringtone for calling or sms How become i that
To change the ringtone press MENU, and then tap Settings. Tap Personalize > Default ringtone. The Phone ringtone selection menu then opens and you can scroll through the available ringtones and tap the ringtone you want to use then tap OK. Ringtones or songs downloaded or copied to your storage card are not automatically added to the ringtone selection menu. You need to go to the Music application and set a ringtone or song in your storage card as your ringtone. To do that top up arrow and Music then tap the three paralel lines at the bottom-left corner of the screen to go to the Library. Play the song that you want to use as a ringtone and on the Playback screen, press MENU and then tap Set as ringtone.
Feb 01, 2011 | HTC Desire Cell Phone
How do I use one of my songs as my ringtone ? Please help !
  1. Open iTunes.
  2. Find the song that you want to make into a ringtone.
  3. Listen to the song and find the part of it you want to use. The chorus may be a good place to start.
  4. Write down the start and stop times of the clip.
  5. Right-click the song and select "Get Info."
  6. Click the "Options" tab.
  7. Type in the start time of your ringtone in the text box next to "Start Time" in the minutes:seconds (i.e., 2:01) format.
  8. Type in the end time of your ringtone in the text box next to "Stop Time." Make sure the ringtone is no more than 40 seconds long.
  9. Click "OK."
  10. Right-click your song again and select "Convert Selection to AAC." Wait for iTunes to convert your song. It will create a duplicate version.
  11. Right-click the ringtone and select "Delete."
Jan 15, 2011 | Apple iPhone 3G
I want to download an app to download songs and ringtones
Method 1:
Transfer the song(s) you want to set as ringtones onto the microSD card either by connecting to pc via USB or using an SD adapter. Next, Tap on the Music Player, open the music list, press the menu button and select PLAY ALL, this will scan your SD card for music/audio files. Once all your songs have been added to the list, select the song you want to set as ringtone and click MENU key, choose SET AS RINGTONE and that will take you to the RIngtone Trimmer, make the ringtone 30 seconds or less, select Trim and you're done.
Method 2:
Root your HTC Hero, create a directory in your C: drive and name it HeroRIngtones, HTC, or whatever and put there all the ringtones you want to be added (30 seconds or less), then open Command Prompt; make sure your device is connected and already visible. Run the following command "adb push directoryname/myringtone.mp3 /system/media/audio/ringtones" and press enter. Do same procedure for all the audio files you want to set as ringtones.
Method 2 is not available for non-root users.
Dec 17, 2010 | HTC Hero Smartphone
How do i set my music as a ringtone on iphone 4
It's a very tricky method. Follow these step precisely, and you should have your own custom ringtone like I have.
Please rate this solution if it helps you.
1 Open iTunes.
2 Find the song that you want to make into a ringtone.
3 Listen to the song and find the part of it you want to use. The chorus may be a good place to start.
4 Write down the start and stop times of the clip.
5 Right-click the song and select "Get Info."
6 Click the "Options" tab.
7 Type in the start time of your ringtone in the text box next to "Start Time" in the minutes:seconds (i.e., x:xx) format.
8 Type in the end time of your ringtone in the text box next to "Stop Time." Make sure the ringtone is no more than 40 seconds long.
9 Click "OK."
10 Right-click your song again and select "Convert Selection to AAC." Wait for iTunes to convert your song. It will create a duplicate version.
11 Right-click the ringtone and select "Delete."
12 Click on the "Keep Files" button.
13 Find the file. It's usually in your User folder under "Music > iTunes > iTunes Music" and under the band's name. It will have an extension of m4a.
14 Replace the m4a extension of your ringtone with m4r. You can either double-click slowly to rename your file, or right-click and select "Get Info" on a Mac or "Rename" on a Windows PC.
15 Click "Use .m4r" or the PC equivalent when the system warns you that the change may affect the use of your file.
16 Double-click the ringtone file. ITunes will automatically add it to your ringtones folder in your iTunes Music Library.
17 Connect your iPhone and sync your ringtones.
Oct 27, 2010 | Apple iPhone (16 GB) Smartphone
Blackberry 8320 has absolutely no audio out. Can
Please follow the troulbe shooting steps given below.
press menu key, select profile, Under that select advance, press menu key, click on edit, select phone, you will get all the option, Click on ringtone, select Browser, under that select music you will list of songs, select anyone those songs for you're ringtone you will be able to hear the ringtone for you're selected songs.
Oct 28, 2009 | RIM BlackBerry Curve 8310 Smartphone
G1 Tone Problems
Like most (if not all) phones. when setting a ringtone you can only select the song you want ! the only way to have a certain part of a song as your ringtone would be to use Audio editing software on a PC and then crop the song how you want. enabling you to have a ringtone of a certain part of the song.
hope this helps
Greenie UK
Oct 26, 2008 | HTC G1
Memory crd
ring settings select memory card data an select the song
dont forget to rate me
Aug 16, 2008 | Palm Treo 650 Handheld
Bluetooth
to assign a downloaded MP3 Ringtone as the handset Ringtone follow the steps below:
  1. From the MP3 side, while in standby mode, press the Menu soft touch key
  2. Select My Contents
  3. Select Ringers
  4. Highlight the MP3 Ringtone, using the navigation keys
  5. Press the right soft touch key for Options
  6. Select Set As..(2)
  7. Select Voice Calls (1)
  8. Highlight either With Caller ID (1) or No Caller ID (2), using the navigation keys
  9. Press the m620%20center%20navigation%20key-mp3%20side%5b1%5d.jpg key to confirm setting the MP3 ringtone as the handset's Ringtone
May 04, 2008 | Samsung UpStage SPH-m620 Cellular Phone
How can i add mp3 songs to my ring tones?
go into my stuff then choose storage card press select then choose my music and press select then select the artist that has the song you want as a ringtone, highlight that song and then press the menu key,tab down to "set as" option then press select, then highlight the ringtone and press ok . this will convert it to a ringtone for you.
Jul 16, 2007 | Samsung Blackjack SGH-I607 Smartphone
LG VOYAGER VX10000 Cellular Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
