I upgraded to win 7. did not back up my cpu. lost all toshiba settings and features got back eco mode, fingerprint scanner etc. all i need is high performance mode so i can run my cpu at its max. pleaaaaaaasssseeee help. its a toshiba u500
  • 691 Answers
Check with the Toshiba website, got support then click drivers & downloads
put in the model number and see if there is any Win 7 drivers
Richard
Posted on Nov 12, 2009
Tried to update win 7 to win 8 but when loaded receive message OXOOOOOO5D nowcan,t start computer
windows 8 is far better than windows 7
To install Windows 8 on your PC, the processor (CPU) must support the following features: Physical Address Extension (PAE), NX, and SSE2. Most CPUs have support for these features, so if you receive this error, it is likely because the NX feature is not enabled on your system. To resolve this error, follow manufacturer guidelines to enable NX ("No eXecute bit"), or the equivalent XD ("eXecute Disabled"), feature within the BIOS settings. This feature is typically found in the Advanced or Security tabs within the BIOS settings, and can be referred to by a variety of names, including but not limited to: • No Execute Memory Protect • Execute Disabled Memory Protection • EDB (Execute Disabled Bit) • EVP (Enhanced Virus Protection) If the BIOS setting for the NX (XD, EDB, or EVP) support option is not available on your system, you may need to contact the manufacturer to update the BIOS. Note that some very old processors may not contain these features and will be incompatible with Windows 8 Release Candidate. A whitepaper has been published with further details about the PAE/NX/SSE2 requirement for Windows 8, error cases and scenarios that customers encounter when machines fail to meet the requirement, and what to do to install Windows 8 on their PC's. You can download the whitepaper at http://msdn.microsoft.com/en-us/library/windows/hardware/hh975398.aspx
Jan 18, 2013 | Computers & Internet
How to get Drivers Updates after Windows 8 Upgrade for Toshiba C660D Laptop Please
This is a common problem with a new OS upgrade. Try to use Win 7 drivers. Modtify the drivers to be compatible with Win 8. Most times this will work, not always. Try here for Win 7 32 or 64 bit drivers: http://uk.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp?service=UK&mode=allMachines&action=search&teddProduct=6017&selShortMod=1041
Dec 03, 2012 | Toshiba Computers & Internet
Finger print reader not working.....??????????????
@touchcoat
Try re-installing the following and reboot:
For Windows 7
1. Toshiba Fingerprint Utility (for Windows 7 (32/64) click here,
2. Upek Fingerprint Driver (for Windows 7 (32/64) click here,
For Windows Vista
1. Toshiba Fingerprint Utility here or here.
If above steps won't work, the issue is most likely a hardware issue. To make sure that it's not, I recommend trying to do a full system recovery (if you don't mind starting from scratch - turn the computer OFF, hold the 0 key then turn the computer ON).
If you still encounter the same issue, call Toshiba support and have the unit serviced at 1-800-457-7777 (for US) or 1-800-663-0778 (for Canada).
Good Luck.
Sep 04, 2011 | Toshiba Portege M700-S7002 Tablet PC
I use a D-Link DWL-G122 USB Wireless adapter on my laptop, but I recently upgraded to Windows 7 and now the driver which was more for Win XP doesn't work very well. Is there a newer driver that is for Win...
you can try to see if there is a Windows & driver for your Air Plus adapter at the D-Link site if not use the windows compatibility feature to load the drivers for you device.
2. you can also use this feature :
Install and use Windows XP Mode in Windows 73.check the windows "help and support" link under the Orb in Windows 7 to get full instruction set to install and use Windows xp mode in Windows 7.
Apr 24, 2011 | D-Link AirPlus G DWL-G122 (DHDWLG122)...
I installed windows xp on my toshiba tecra m4. How stylus pen works?
Toshiba Tecra M4-S435 is Tablet PC. Windows XP (Profession) has no option of touch screen.
In order to use the feature, you need to install Windows XP Tablet PC Edition or you may install Windows 7, which supports this feature and you would definately be able to use stylus and touch screen, as I have installed Windows 7 and its working fine with all the drivers etc.
Hope it helps! Good Luck!
CreativeTECH
Apr 23, 2011 | Toshiba Tecra M4-S435 Tablet PC
Have a toshiba sat. A500 and just installed Win7 now the reader says it will not connect
you have to update drivers for win 7 check thosiba site for suport or google for it
Mar 23, 2010 | Toshiba Fingerprint Reader
Samsung t240 monitor lost pic
This problem with the T240 (t240M or T240 HD depending on the coutry) monitor on Windows 7 and maybe on Vista
is due to Samsung´s driver witch is not updated to Win 7. You will have to lower your video
resolution to 1600X1024 (higher resolution accepted) be able to use your monitor. Unfortunately it will not work on Full HD mode on Win 7,
until Samsung releases an updated driver for win7.
I had the exact same problem here and found this information together with the samsung people.
As yet they have no idea when the needed update will be available. Hope soon, till then no Full HD resolution for us.
Cheers from Brazil
Mar 04, 2010 | Samsung SyncMaster T240HD 24" TFT LCD...
After upgrade from Win Vista, the screen dont work on Win 7
One word DRIVERS. This is ya whole problem... simply Win 7 doesn't have the correct drivers for your PC. Unless ya have the correct drivers ya gonna always have problems. Find suitable drivers for everyone of your devices and store in a Directory, when you install, then, ya will have the correct drivers and hopefully Win 7 will install fine. Remember also Drivers can be installed in "Computability Mode" for XP SP2. Otherwise stick with Vista?
Jan 26, 2010 | Computers & Internet
Window7 installation
1) you have to make sure that you have ALL the required Windows 7 drivers for your Laptop AND additional devices/application (eg. Wifi adapter, Modems, USB DTV, External Keyboard, etc). 2) get and install a 'Windows 7 UPGRADE' for your current Operating system. (Check for free upgrade?) 3) Windows XP mode (and native Virtual PC) is only available if you upgrade to the Professional or Ultimate versions AND your CPU and BIOS support 'Hardware Virtualization' ... even my Intel Dual Core T4200 processor does not support this feature!!!
Hope it helps: let me know how you go!
Jan 01, 2010 | Toshiba Satellite A100-S8111TD Notebook
I have H P Pavillion DZ6500 which I just upgraded to Windows 7 Professional. The Verisoft Access Manager that drives the fingerprint scanner is not compatible with Windows 7. Any suggestions?
Hi:
I fought the same thing with another fingerprint scanner, and even spent some quality time speaking with Micro Soft Technicians....It seems they are not really supportive of fingerprint scanners,And forget getting any support for Window 7, 64 Bit version. My fingerprint scanners were Microsoft brand, and still no 64 bit support...
Nov 24, 2009 | HP Pavilion tx1000z Notebook
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
