Question about Pioneer Car Audio & Video
A wiring/pin identification for old Pioneer GM-4 Amplifier. Has the large DIN type plugs
  • slatteryse Nov 13, 2009
    Stripped the sheath away on the tape deck and discovered most. Found an old post with a pic of a GM200 amp din plug, and it made sense. Centre pin is the shield/earth, as is the bottom left pin. In clockwise direction from bottom locating lug (tape deck male plug) I found-
    Shield/Gnd
    Shield of R/L cable
    Right Channel (red)
    Left Channel (white)
    Yellow wire (unused??)
    Red wire (remote on/BTB?)
    Orange wire (acc?)
    centre pin main shield
    Ive cut off the plug from tape, and will fit connectors + RCA and use the amps and equaliser on a new car CD player. That the plan anyway.
    Sorry it doesnt look right as the wires were on a new line each so no comma or seperation other than the capital letters. Hope it makes sense.
Can most probably,can't remember so clearly.Tell me how many wires ther are and what's all the colours.If you could send a pic as well.
Posted on Nov 12, 2009
I need wiring for pioneer gm 3000 amp?
Here is the pinout. You need to solder your own connections.
Oct 15, 2014 | Pioneer Gm-3000t Car Amplifier
HOW do I install my Pioneer 4 channel power amplifier GM X 84 along with my pioneer DEH-17 cs player .? A wiring diagram is needed
If you are using two amplifiers used one the amplifier to power a sub woofer on you though frequency the other amplifier willpower the rest of speakers make sure your power wires are separate and the both run at 15 to 20 A
Aug 09, 2014 | Car Audio & Video
What is the wiring diagram for realistic 211173 mic to cobra 25ltd
first,a realistic plug is a 5 pin D.I.N. type and a cobra 25 is a 4 pin screw on . If you are trying to save $$ by using an old mic then let me say that you can get them prewired real cheap.
Nov 24, 2013 | Cobra 25 LTD 40-Channels Base CB Radio
How do you wire it in? Orion 300 prq equalizer
the prq can be used after a head unit before crossover and amps. it is a preamp/equilizer and you must have an orion amp in the signal chain that uses the 5 pin din plug to provide power to the prq via phantom power. if you have a crossover it must be a brand with the same 5 pin din pinout input and output. the din pinout is 1\+15v, 4\r. ch input, 2\ground, 5\l. ch input, 3\-15v. left to right or clockwise on din. the power can be supplied to the prq with an optional 100 pps power supply unit. rca from head unit feed the input and the 5 pin din is the output .
Aug 09, 2013 | Orion 2500D Car Audio Amplifier
Logitech z3 wiring
I have a logitech z3 subwoofer with a mini-DIN-9 connector socket. It also has a volume control and 110V power cord. As best as i could trace the circuit, and using the TDA7377 stereo bridge amplifier chip datasheet, the pinout for the mini-DIN is as follows (untested):
1: L in (to vol.)
2: R in (to vol.)
3: Power (12V from transformer)
4: Standby (5V to play, 0.05mA; 0V to standby)
5: L out
6: R out
7: Ground
8: Ground
9: Ground
Connecting 3 to 4 with a large resistance (~20K ohms) should enable speaker. Pins 1 and 2 might be swapped; pins 5 and 8 might be swapped. Mini-DIN socket pin holes are numbered right to left, bottom row to top row:
9 8 7
6 5 4 3
2 1
Sep 03, 2012 | Logitech Z3 2 Speakers
Amplifier wiring diagram, pioneer gm-x944
These amplifiers are universal. You have the speaker positive negatives, power "Red", Ground "black", and remote off/on "blue". Thanks
Jun 05, 2009 | Car Audio & Video
I need a wiring diagram for a Pioneer GM-A200 Amplifier
For a Pioneer GM-A200, pls use below wiring scheme:
  • Green & Green/Black - Left Speaker;
  • Gray & Gray/Black - Right Speaker;
  • Yellow - Illumination B+12;
  • Red - ACC B+12;
  • Orange - Always ON B+12;
  • Black - Ground/Chassis.
For the 8P INPUT DIN connector:
  • 1 - SWD +B;
  • 2 - Left Input
  • 3 - Audio Ground
  • 4 - Mute
  • 5 - Right Input
  • 6 - UN SWD +B
  • 7 - Illumination B+12
  • 8 - NC
  • Body - Ground
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 23, 2008 | Car Audio & Video
I have a pioneer gm-x404
The wiring is fairly straight forward. Along the top row of the ten pin plug =
(Left to Right)
Front Left positive,
Front left Negative,
Control wire from your stereo head unit should be thin blue wire sometimes listed as Remote Wire this switches your amp on and off via your head unit so you don't run your battery flat,
Front Right Negative,
Front Right Positive.
Bottom Row=(Left to Right)
Left Back Positive,
Left Back Negative
Centre Nothing
Right Back Negative
Right Back Positive
These are all inputs from your head unit.
To bridge from 4 channel to 2 you connect
one left speaker to Ch B Left Positive and Ch A Left Negative
one Right speaker to Ch B Right Negative and Ch A Right Positive
Ten Switching the Input Select switch to 2CH
Alternatively if your unit has RCA's on the back of the Head unit you can use them to run your subs.
Hope that helps.
Feb 28, 2008 | Pioneer GM-X4 Car Audio Amplifier
System Remote Control Wire.
Wal Mart generally has 4g wiring kits for ~$40. Some of the kits contain everything you'll need to install your amp (including RCA cables, fuses and fuse holders).
If you want to understand more about car audio installation, read through the following site:
bcae1.com
Read the following pages specifically:
Installation Primer
Wire
Fuses
Amplifiers
Head Unit
Dec 28, 2007 | Pioneer GM-5100T Car Audio Amplifier
Car Audio & Video Logo
672 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
