Question about Apple iPhone 3G
My iphone is not connecting to any wifi network it doesn't seem to find my home wifi
    Problem Solver:
  • 6 Answers
Make sure the software is up to date. try resetting the network settings, if that doesn't work you can try restoring the phone to factory settings. If that doesn't work take it to an Apple Retail Store or call tech support. If your phone is still in warranty you may be able to get it replaced.
Posted on Nov 12, 2009
Connect iphone 5 to wifi
To connect your Iphone to home wifi you should go into the 'Settings' app then there should be a option where you can click on 'Wi-Fi'. If the wifi is on you should see green next to wifi. Under 'Choose a network' select your home wifi. If it is password protected it will ask you to put in your password, if not it should automatically connect.
May 31, 2015 | Apple iPhone 5
Tip
How to connect an iPhone to the Internet
Connecting your iPhone to the internet is an easy process. You just simply use any application on your iPhone which uses internet service.
Your iPhone can either use WiFi or Cellular for internet access.
- A WiFi network is simply a wireless network. You can find them at coffee shops, libraries or even at your house if you a router setup for wireless access.
- Cellular data networks allow Internet connectivity over the cellular network. Check your carrier's network coverage in your area for availability.
When you use an application on your iPhone that requires internet service it will either connect to the last WiFi network used, or if that network is not available it will list all available networks in range. You can simply tap on the network you wish to join and it will connect. If the network requires a password it will show a lock icon. If no Wifi networks are available your iPhone will connect over the cellular data network and fees may apply.
To see all the Wi-Fi networks in range, from the Home screen choose Settings > Wi-Fi. Tap a network to join it.
I hope this article was informative. You can check out more of my tech articles by clicking here then going to the Tips section.
Regards,
G33k
keywords
how to connect iPhone to the internet, connect to internet, iPhone internet, connect iPhone internet, how to use internet on iPhone, iPhone internet application, iPhone wifi, iPhone wireless internet connection, iPhone no internet, internet not working iPhone, iPhone 3g,
on Jul 09, 2011 | Apple iPhone Smartphone
Iphone 4s no network coverage at home
By no network coverage do you mean no cellular signal or can't connect to your home wifi? If wifi trouble push settings button on iphone. Select and turn on wifi. It will search for available wireless networks. Choose your home wifi, should be the strongest signal, most bars. If you don't know your ssid , look on the sticker on the modem. For instance ssid at&t 2345. Once you select your ssid you need to enter password which is also found on the sticker on modem. Enter password and select join. You should now be connected to your wifi. This will always reconnect automatically when you leave and come back home. If not wifi issue, are you just too far from cell tower to get good signal?
Sep 06, 2014 | Apple iPhone Smartphone
I phone 5
What Type/Brand of router ?????
Apple's iPhone is a multimedia connectivity tool.
As such, the iPhone employs a sophisticated system to keep you connected to the web via WiFi signals so that you can stay up to date with email, mapping and media.
To use the iPhone's WiFi feature just follow these steps.
Tap a network.
If you have not yet used your iPhone's WiFi or if you're in a new WiFi area, the iPhone will show you a list of available networks.
Tap the network that you want to connect to in order to connect.
If there is a password required a little lock icon appears.
Enter the password to connect to locked networks and continue to surf the web.
Monitor your signal.
As you use your iPhone, especially if you're moving around, you should take a look at the signal strength of the connection.
The strength is indicated by a small, black broadcast symbol that stacks arches, or rounded bars, on top of one another.
The more bars there are the better the signal.
Make connecting to WiFi automatic or manual.
The iPhone is equipped to automatically search for available networks and connect you to one.
If you do not want the phone to search for networks, select the "WiFi" option on the phone's menu.
Then select either the on or off option of the "Ask To Join Networks."
Turning this option off requires that you find networks manually.
Forget a network.
Once you connect to a WiFi network once the iPhone automatically remembers the network and connects you to it at a later opportunity.
To forget a network so you don't get automatically connected choose the "WiFi" option on the menu.
Then tap the right arrow button next to one of the networks that the iPhone already remembers. Then tap "Forget This Network" to erase the phone's memory of the network.
Troubleshoot Wi-Fi Connection Problems on an iPhone
If you experience Wi-Fi connectivity issues on your iPhone, you may need to reset the Wi-Fi connection.
Your connectivity issues could be caused by the wrong password if you are having trouble logging into the Wi-Fi network or from a problem in your iPhone's settings.
By resetting the Wi-Fi connection, you are clearing out the previous settings created when you first connected to the network.
Tap the Settings icon on the iPhone's home screen, and tap the Wi-Fi tab.
Swipe the switch on the Wi-Fi tab to ensure Wi-Fi is enabled on your iPhone.
Tap the blue arrow button on the network tab you are connected to in the network list, and tap "Forget this Network."
Tap the "Forget Network" button that appears on the pop-up menu to confirm the action.
Tap the Wi-Fi Networks tab in the upper-left corner to return to the previous screen, and tap the network's tab in the network list to re-join it.
Press the Home button on the iPhone, and tap the Safari icon on the home screen to test the Wi-Fi connection.
Tap the blue arrow icon on the network's tab if the connectivity problem persists, and tap the "Renew Lease" button at the bottom of the network's window.
Tap the "Renew Lease" button on the pop-up box to confirm the action.
Tap the Home button on the iPhone, and tap the Safari icon on the home screen to test the network connection.
Nov 11, 2013 | Computers & Internet
My Iphone 3G won't connect to home wifi after working well for months. In settings, it searches indef. for networks. 3G works fine. My husbands iphone works fine. Any suggestions?
you can try to set your wifi same as your husband's one, check the wep code and wifi shold be enabled.
try this and give feed back!
good luck
Jun 30, 2010 | Apple iPhone 3G
My IPhone 3gs connects to my home network but doesn?t actually send and receive data. It shos the wifi on the top cannot able to acess the internet.
Check, is your PC has connected properly on network?
You have to also allow this application in Firewall Exception list. If firewall blocked it then unlock it.
Your problem must have to solve now.
Thanks.
Happy to help you.
Apr 25, 2010 | Apple iPhone 3G
I cant seem to connect wifi onto my iphone
try forgetting the wifi connection and then try connecting to it again
Nov 11, 2009 | Apple iPhone 3G
Wifi on iphone 3g is not picking up wifi signal
it may be finding it but not showing the passcode screen to enter your wep key.
tap the wifi settings and set you network information and the wep network key which is located on your router.
If you put any other code in your wifi won;t connect.
Jun 10, 2009 | Apple iPhone 3G
Connect to wi fi at home from iphone. fring skype to skype calls
you need a wifi router at home with internet connection
daniel
http://rylwy.com/
Nov 15, 2008 | Apple iPhone Smartphone
Iphone wifi
You need to select the 'Settings' button on the home screen, then make sure that the 'Ask to Join Networks' option is turned on. Choose your network, and then enter in your password. I've had the same problem before, and it turned out that my phone wouldn't connect without setting the computer to require a password. If this doesn't solve your problem, please let us know.
Feb 20, 2008 | Apple iPhone Smartphone
Apple iPhone 3G Logo
192 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
