Question about Canon PIXMA MP210 Photo All-In-One Printer
I am unable to set my Canon M155 Printer for the Copy function.
I am unable to set my Canon M155 Printer for copying. The only result I get in the output is the first 3/4 OK across the page followed by 1/4 all black from top to bottom.
I followed the simple instructions. 1. Press ON 2. Press Start (Black button).
    President:
  • 787 Answers
Try scanning and check the image.If it's same the problem is in ribbon cable of scanner.
Posted on Nov 12, 2009
NOT SCANNING OR COPYING
These problems occurs when the scanner is unable to take a copy of the image that you are trying to scan.You can go to settings and run a scanner motor test on the scanner.Just check out the results of the scanner motor test.If the scanner motor test results are positive,then please clen the scanner bed with a cotton cloth and then perform a power drain on the printer.
Now in order to perform a power drain you need to keep the printr powered on n unplug the power cable from the back of the printer.And then press the power button down for 30-50 secs n then release it.Then plug in the power cable n turn on the printer. The scaner will respond. But if the scanner motor test results are negative, then the scanner needs to be fixed by a hardware technician
Dec 16, 2013 | Canon Imageclass Mf8080Cw Wireless...
Copy result is blurred
Does the printer scan OK?
Is the platen glass clean?
Dec 10, 2013 | Epson ME OFFICE 620F MULTIFUNCTION INKJET...
I get "system error e000" message when i copy
1) Press the "Additional Functions" key.
2) Press the "#" key.
3) Press > to the "#7" printer function.
4) Press the "Set" key.
5) Press > to the "#4 Printer Reset".
6) Press "Set".
7) Press 8) Unplug printer, plug it back in, and turn it on.
Mar 14, 2011 | Canon Image Runner 1630 Copier Copier
Cant get my canon mx330 printer to work
Multifunction devices usually require two separate inks to acquire functionalities. For example, an empty ink cartridge especially the color ink may still produce copies without multi ink features. However, any attempts to dismaunt the ink cartridges would require restorations from the computer settings. First, inspect the printer for empty accessories that require replacements. After acquiring and replacing ink cartridges makes way for the next processes. Second, connecting the printer that has been restablished would produce display results requesting printer copy allignments. Attempt to print a document to produce the results for alligments. Goodluck
Jan 12, 2011 | Canon PIXMA MX330 Multifunction InkJet...
Unable to do fax can print but unable fax
Canon PIXMA MP250 series serves with PRINT + SCAN + COPY function. No FAX function
Jun 10, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
Need drivers to install in vista program
Canon does not support Vista at this time.
But you can set your MultiPASS to print only mode in which case it will be recognized as another model printer and you'll get basic printer function.
Press the buttons in this order. Menu-Scan-Copy-Set-Set
Restart you computer and it will recognize the printer as Canon BJ S630 This should provide basic print functions.
Apr 14, 2010 | Canon MultiPASS F50 All-In-One InkJet...
Can i copy from printer to Computer
No you can't.
Canon Pixma iP45500 is a sigle function printer. That means it just prints to paper.
What you want to do requires a multifunction printer: a printer is also a scanner/copier functions and which which is capable of acquiring an image and transfer it to the computer.
single-function printer
Jul 27, 2009 | Computers & Internet
Copyer problem
Go to the Control Panel, open Printers and Faxes, right click on the icon for your Canon, choose Properties.
Since the offered settings can differ from one model to another, you may have to look at any tabs shown to find the default setting for paper type but it will probably be under 'Advanced.' Check through the various settings and you should find settings influencing which paper size the printer should use and expect.
Oct 18, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Won't copy
try this...
start, programs, canon scangear toolbox,
A little box like this should appear
press on the cog icon
Select the copy tab and ensure that the "link to" is set to DRIVER, and press the SET button and select the printer you want to copy to from the dropdown, then OK, OK
post back results and if required I will give more ideas to try
Jul 05, 2008 | Canon CanoScan LiDE 30 Flatbed Scanner
Canon PIXMA MP210 Photo All-In-One Printer Logo
43 people viewed this question
old marine
old marine
