Question about Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping
I have a Toyo Lazer 30. Often times it doesn't run for a few days (I also use wood heat). So then when I go to start it up (after a few days) or if the thermostat tells it to start, it might run for a few minutes and then it makes the ticking noise, quits, and usually gives error code EE6 (sometimes EE2). Then I have to turn it back on, push the red restart button located on the side a few times and then it will run as it supposed to. My oil tank is full, new filter, tank outlet is 24" above stove, stove filter is clean, etc. So, all I have to do is push the red restart button on the side and it will run fine. The problem is I can't leave the house and rely on the Toyo to turn on if it hasn't been running for a few days. It's like it's loosing it's prime or ?? Make sense? Can you help? Thanks, Jason
  • 57 Answers
Ticking is a sign the heater is not getting anough fuel to keep running. Check your manual and see if there is a valve inside your heater that controls fuel flow. Make sure it is open all the way. Also check to see if you have the valve on your fuel tank open wide enough to allow fuel to flow like it should. Another tip. Instead of turning your heater off all the way when you are using wood heat, why not just turn the temp on the heater lower then you know your home would get to with wood heat running. Adjust the temp to where you need it when you want the heater to run. (That way your heater stays primed.) The heater doesn't draw that much electricity. ;)
Hope I have helped.
Diana
Posted on Nov 16, 2009
What does set back mean on a toyo lazer 55
I means the same thing on all thermostats. The set back temp is the temp that the unit will go to on its program of unoccupied times.
Oct 24, 2011 | Heating & Cooling
My toyo lazer 30 won't start, and the EE2 problem comes up.
With an EE2 message you have a problem with the stove igniting during start up. If you continue to try you will end up with an EE22 and the stove will be locked out. If so, un plug for 20 minutes. While you are waiting check out you fuel system. Low fuel, no fuel, dirty filter on tank and stove. Be sure to bled the air off the top of the filter when you change it.
Keep us posted.
Tom
May 14, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
TOYO TA-09CHS aircon problem
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem.
Jun 09, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
Toyo stove laser 30
EE22 means that your Toyo failed to ignite 3 times in a row. You need to unplug it for 30 minutes to reset the circuit board. Then plug it back in, push the red reset button on the right hand side in the little hole towards the back and push the Power button. Your Toyo should ignite after that barring some other problem caused by running out of fuel.
I am assuming that you ran out of fuel which caused the EE2 error code originally. Sometimes, when you run out of fuel you can get water, ice, debris in the fuel line causing an obstruction or limited fuel flow. You may also get an air lock. You may need to crack the fuel line at the back of the Toyo where there is 3/4 nut and bleed the line. If you see no fuel or a small quantity of fuel then you will need to thaw and/or purge the fuel line in order to get fuel to your Toyo's fuel pump.There is also a screen in the sump which can get plugged with rust, debris from the bottom of the fuel tank so you may need to clean the screen in order to get fuel to the pump.
Nov 12, 2008 | Rinnai Toyostove Direct Vent Heater:...
Toyo stove, Lazer 30 model
EE22 is a lockout code.
Unplug unit for 30 min.
You need to findout why you still get EE2 or EE6
Check fuel and filter
Still have problems call me I'm in North Pole
Dave 4889179
Apr 10, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Have you tried to disconnect the power and then reset the clock. If it doesn't fire after the first time push reset for a period of one second. If that doesn't work email me back and i will call rannia tech support and find out some more information on the heater. What kind of fuel are you using
Apr 08, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Lazer 56
Hi EJAKFbanks,
I believe by your description and my 8 years experience with Toyo Stove repair that you are missing part of the firing sequence. The firing sequence for a Toyo Stove L 56 is to blink on the burner light for 7-9 minutes, then it clicks up to the medium light (amber-yellow color). The medium light blinks and that is when the fuel pump kicks on and starts to pump. If the stove ignites, the medium light will glow for a second and then drop down to the low light (green) The low light will burn for awhile and at this time you will see a blue flame in the newer heat chamber models or a red glow, and perhaps some blue flame in the older heat chamber models, then the stove will kick up to the medium light for a bit, and then to the high light. An EE6 error code will show only when the flame is extinguished after actually taking place and a burn did occur in the chamber on low. An EE6 is usually one of 2 things: 1. There is an inadequate fuel supply for the stove to maintain a low cycle burn, or the medium, or high. Each cycle consumes more fuel than the prior one. Inadequate fuel supply can be due to a restriction in the fuel line such as icing like cholesterol in a persons arteries, or a plugged sump screen, blocked fuel line or filter, too low a quantity of fuel in the tank, or a fuel line that is not all gravity feed, as in, the fuel line runs down, down, and then up a few feet to get to the Toyo. In that case, the fuel has to rely on head pressure to get to the stove. Head pressure is the atmospheric pressure pushing on the fuel in the tank to force it up against the earth's gravity forces. Solution: You can find any restriction in the line, replace the filters, clean the sump screen, put heat on the fuel line to thaw any icing blocks. 2. An EE6 can be caused by a carbon chain developing from the burner ring, flame sensor or chamber wall to any metal part in the burn chamber. A carbon chain essentially "shorts" out the ground for the unit and the Toyo will shut off on EE6. Solutions:You can bang the side of the Toyo (Old frustrated Alaskan solution) which really just jars the carbon chain loose, clean the flame sensor, clean the fuel nozzle with a straight 3 inch wire, and stick a screw driver in the igniter (red wires) hole and rattle it around real good (another old Alaskan trick). Often, those three things will get your stove running again if it is a carbon chain. The problem will likely occur again, but it will buy you some time until you can get a tune-up done. Most likely, you need a tune-up. Question: When was your last tune-up? Toyo's should be tuned up every 2 years. Tthe book says every one year, but in my experience, every two years is the best bang for the customers buck. The three year mark usually begins showing signs of metal fatigue in other parts of the burn chamber/heat exchanger system so the costs rise a little each year, unless you are a lucky Toyo owner and for some odd reason, your stove can go 3 years between cleanings without any ill effect. If you get your stove running, run it hard on High for about 2 hours to clean and burn all the carbon out. Good Luck! toyotech, North Pole, Alaska
Feb 12, 2008 | Rinnai Toyostove Direct Vent Heater:...
EE2 code for toyo laser 56
Hi sammysamual,
My business is Laser Heating Service in the North Pole/Fairbanks areas of Alaska. An EE2 error code is usually fuel related. What does your Toyo do before the EE2 code shows up? If you let me know the sequence of events, I can trouble shoot the problem for you. toyotech
Dec 13, 2007 | Rinnai Toyostove Direct Vent Heater: Laser...
Toyo L-30 Start up noise
before the heater starts up, the combustion blower starts to purge the chamber of unburnt gases, then the solenoid pump, pumps fuel onto the burner mat, shortly thereafter the ignitor turns on and ignites the kerosene. what you are hearing is the combustion blower. its a small motor with a rather large vacuum impeller on it. it sounds like a jet engine when it first starts. there are two bearings on this motor shaft. yours evidently are dry - no lubrication. replace the motor or if you have the equipment purchase two sealed ball bearings and press them on the shaft.
Nov 05, 2007 | Rinnai Toyostove Direct Vent Heater: Laser...
Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping Logo
254 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
