Question about Dell Inspiron 9300 Notebook
When I start my Inspiron 9300 the Dell symbol appears andI get a dark scree with a short line near the top left of the screen. Help I tried removing the battery and restarting.
  • 439 Answers
This is the dos screen before start up. Normally your motherboard and cpu go through a quick self test and then your hard drive and os start up. What is happening with yours is it is not passing its self test. What you should do is remove and re-seat the memory cards and hard drive in your computer and then try and start it up. If this does not work it means either *********** board or your cpu have failed.
Posted on Nov 12, 2009
How do I find numerical lock button on Dell windows 8 keyboard?
On the Dell 0Y3740 for the Dell Inspiron 500M or Latitude D800, the Num Lock (Lock replaced by a symbol) key is on the top row of keys. It's a short row and the Num Lock is the third key from the left (or the fifth key from the right). In blue, the key has Scroll and the lock symbol.
On a slightly different model, the key may be in a different spot. However, it will probably have a similar placement near the Print Screen and Pause/Break keys. (Usually these keys will be near the function keys or just above them for a keyboard without a separate 10-key area.)
I hope this helps.
Aug 21, 2014 | Dell 0Y3740 Keyboard
Dell Inspiron 9300 Vertical lines
Try re-seating and cleaning, the connection between the display and the Motherboard, (Electronics cotton swab and rubbing alcohol, be sure not to leave any of the cotton fuzz on the connectors.) It will be below the keyboard. If that doesn't result in any improvement, the display will probably need replacing. You can find the complete tear-down guide here:http://support.dell.com/support/edocs/systems/ins9300/sm/index.htm
Jan 04, 2012 | Dell Inspiron 9300 Notebook
My dell 9300 have line appear in monitor?
Hi three its a problem on the screen. Display damaged. If you use it another few month the line will be increasing. No way for repair. Only replacement is solution.
Jan 22, 2011 | Dell Inspiron 9300 Notebook
My dell inspiron 9300 has a thin yellow line running down the left side of the monitor. some weeks it will be there, sometimes it won't. help!
Reseating the video cable eliminate those lines that appear.
If your not familliar in tearing down the laptop, try bringing the computer to a local tech and have the video cable reseated. They can open the hinge cover/panel in order to access the video cable at the back portion of the laptop.
^_^
Jun 13, 2010 | Dell Inspiron 9300 PC Notebook
Dell Inspiron 1545 Broken Screen?
The LCD is definitely shattered, looks like pressure was applied from the back of the screen (Pressed on, laid on etc) and the LCD will need to be replaced.
Several are available on Ebay
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=Inspiron+1545+LCD&_sacat=See-All-Categories
Service instructions are here
http://support.dell.com/support/edocs/systems/ins1545/en/SM/display.htm#wp1183775
Feb 07, 2010 | Dell Inspiron 1545 Notebook
Numerous, bright, multi-colored vertical lines on 9300 screen
Try taking out the Ram memory first one stick at a time. Sometimes when Ram goes bad or overheats, it first affects the display. If that is not the issue, here is the link to your service manual.
Oct 09, 2009 | Dell Inspiron 9300 PC Notebook
LThin ines appear on monitor screen
Hi Steve... You didn't mention what type of monitor you have, so I'm assuming its a laptop... if that's true, I've had this happen on my HP Compaq Presario v2000 before. It usually indicates a BIOS problem. Do this: clear the CMOS memory by removing the battery from the mobo for five minutes. Then, before replacing battery, press and hold the power button down for no less than 30 secs. Then, replace battery back on mobo, reassemble and start up laptop... Your problematic lines should be gone... If not, you can email me at bigvalleyelectronic@gmail.com or do a search on same.
Mar 18, 2009 | Dell Inspiron 9300 PC Notebook
Vertical lines in my laptop screen
Try connecting an external monitor to the Dell Inspiron 9300 and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.
Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 19, 2008 | Dell Inspiron 9300 Notebook
Dell Inspiron 9300 Notebook Logo
157 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
