Question about Echo Garden
I have an Echo Backpack Blower PB46-LN that is leaking black oil out of the muffler, its easier to start when its cold but when its hot it difficult to start, also I dont even need to prime it to get it to start, my concern now is the leaking of black oil from the muffler when its running, what can cause this and how can i fix it?
  • logicalg Nov 14, 2009
    Now I guess its starting fine (on second hard pull), but, white smoke comes out while running and doesnt stop, also it makes a clackering noise while its running, what might these 2 problems be from?
  • 486 Answers
This senerio is an 'over-rich' condition, most often caused by an improper fuel/oil ratio mix, and the 'exhaust screen' or 'spark arrestor' on the outlet of the muffler is plugged. Cleaning the screen may be all that is needed to correct the problem. **Make sure this screen is clean, and operate engine for at least 5 minutes before making any of the suggested adjustments below.
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
Overfuel or 'rich' condition
Basics to check:
b) is there spark
3) Check Air filter for fuel saturation
4) Allow engine to run for 5 minutes to excess fuel from muffler
5) Fuel mixture ratio: Make sure the oil mix is per your manufactures recommendations
6) If after the above the engine is still smoking and blubbering:
Adjust carb mixture screws to a 'less rich' setting
*NOTE: only move mixture screws 1/8 of a turn at a time,
and try operation before any more adjustment
Posted on Nov 12, 2009
Testimonial: "Now I guess its starting fine (on second hard pull), but, white smoke comes out while running and doesnt stop, also it makes a clackering noise while its running, what might these 2 problems be from?"
Improper mixed fuel has caused my hasquvarna back pack blower to lock up,how can i unlock it.
Johnny, You can try removing plug and muffler and squirt some oil in to try and free, I would disassemble and replace scored or damage parts. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Repairing Seized Engines
Echo Backpack blower
Fixing seized up echo weed eater
Mar 24, 2016 | Garden
Like the motor is locked up
pull muffler off look at piston if all scard up its bad by a new one and add more oil to your gas you ran to hot only fix but new one
Aug 05, 2014 | Echo PB-500T GAS-POWERED BACKPACK LAWN...
Blower bogs down and kills at full throttle
Check the following, then clean or replace:
  • Fuel Filter - Located IN the fuel tank
  • Spark Plug
  • Spark Arrestor - at muffler port, creates resistance of exhaust flow, engine then bogs
  • Carburetor - may need a rebuild kit
Then watch this...
and...
Mar 31, 2013 | Echo Pb265l 25.4cc Gas Powered 158 Mph Low...
My echo backpack leaf blower pull start seems stuck it wont crank
Without getting to involved with it, did you always mix the correct fuel/oil ratio? or has someone else possibly put straight gas in it without oil? Another possibility is that the recoil could be broke. I would try to determine if the piston is seized in the cylinder. First remove the spark plug and try to pull the starter rope while listening closely for any strange noises from the engine. If it pulls fine then, replace the spark plug and try to start it again. If that doesn't work then I would remove the back cover and remove the muffler so you can look at the cylinder. You will need a phillips screwdriver and a set of metric allen wrenches. Hope that helps.
Aug 30, 2011 | Echo Pb - 413t Backpack Blower
Have an Echo backpack blower that has been difficult to start and found that the air filter is soaked with gasoline. Just letting the blower sit it is actually leaking gasoline from the air filter. What...
hi there
pauly 46 here sounds like tank breather and carby problems ?
have you checked that the muffler and ex port are not blocked ?
have you checked that the tank breather is working, and that the fuel pump diaphram is ok - no holes or damaged / stiff , and also that the metering diaphram and needle valve are ok and are not sticking open, or the lever setting is too high or the diaphram is just too stiff and holding the needle open
either way check tank breather and carby diaphrams , and needle valve and lever and the muffler and ex port for blockage
i assume compression and spark and timming and induction system are all ok
if its still hard to start and everything checks out as good might have a air leak
only way to know is to pressure and vac test crankcases
might pay to let your local shop do this because you need some special tools
but cover the basics 1st
cheers pauly46 hope it helps
May 14, 2011 | Echo Gas Blower 204 MPH765 CFM Blower...
I have a Echo PB-260L Blower. It starts fine then gradually loses power sometimes completely shutting off. I have replaced the fuel filter spark plug air filter and have cleaned the screen.
Check the exhaust port upstream from the muffler and make sure it is not restricted with carbon. Mine was less than half way covered over with carbon. Scraped out carbon, checked muffler and screen(ok), back-blow the fuel line harness including the fuel filter and fuel tank vent and took carb apart and blew out all passages, not replacing anything and now runs fine. Would not rev past high idle before. Be sure gas is FRESH and mixed at 40-50 to 1. Hope this helps.
Jul 14, 2010 | RTO Echo 25.4 Cc Backpack Leaf Blower -...
It starts but will only run for one minute or so before shutting off
check your spark arrester screen on the muffler , it might be clogged
Mar 21, 2010 | Echo Inc. 25.4 CC Backpack Blower
After getting hot the blower will blow very hard at full throttle and then loose power and then back to full throttle after 2-3 seconds. It does not do this when it first starts off cold. I have relaced...
Basics to check:
b) is there spark
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 15, 2009 | Echo Inc. 25.4 CC Backpack Blower
Garden Logo
731 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
